Two artisans don't make a right.
Person9 wrote:
First, i really like you photograph! Very interesting lighting, composition and geometry.
Second, I am not familiar with the 40mm Artisans lens (I think you may mean 60mm), but, if i may, I have some comments about the sharpness of your image, or lack thereof:
There's actually two completely independent companies.
TTArtisan makes the 40mm f/2.8 macro: https://www.ttartisan.com/?list_10/129.html
7Artisans makes the 60mm f/2.8 macro: https://7artisans.store/products/60mm-f2-8
Looking at the optical designs, the 40mm appears to be more sophisticated than the 60.
Looking at the mechanical, the 40mm is either a fully unit-focusing (all groups move together) design or a minimally floating-element (some groups move on one helicoid, the rest move on a second helicoid) design, while the 60 is either massively floating element or has a fixed rear group, so it doesn't deliver the working distance you'd expect from a 60.
Side-by-side reviewers tend to give the 40 the prize for image quality.
It looks like there is some motion blur; even the sharpest parts in the center are not sharp, and I don't think that is a lens defect nor the fault of the Raynox, which is a fine optic. Motion blur can come from many sources:
It's a 3-element achromat. When used with a lens with a focal length near its own, the simpler lens dominates the optical quality equation, so with the 125mm Raynox in front of a 43mm Panasonic, the end result is going to look more like the 3 element Raynox than the 10 element Panasonic.
a) For shots like this, a tripod is a necessity.
Or a flash.
b) A remote release or self-timer should be used to avoid camera shake.
c) wind or vibrations through the floor can cause problems.
Since aperture was f/18, I don't think it is a depth-of-field issue, since nowhere is it sharp.
f/18 is a dang small aperture on a uFT camera: equivalent to f/36 on FF. I'd never expect that to look sharp.
In the long run, focus stacking will make a major improvement, giving you "limitless" depth-of-field. The 7Artisans macros lenses are fine, and you could do focus stacking by carefully turning the focus ring in very small increments to make each slice of the stack (waiting between shots for the camera/tripod to settle down).
That would make a mess. It results in anomalous perspective: the entrance pupil moves a greater distance than the shift in the focal plane. Generally, you only get good results by focusing "internal focus" designs.
An alternative would be to use a focusing rail.
"Alternative" being "the only way to really make it work".
For what it's worth, I don't think that today there is a "bad" or "poor" or even a "so-so" macro lens. They generally differ only in features, such as manual or autofocus, image stability or none, automatic or manual aperture control, and maximum magnification.
And working distance, focus breathing, field flatness (still a problem in 2023 with some lenses, believe it or not), and ability to focus stack using the lens's own control without making a focusing rail mandatory.
The term "mirrorless" is totally obsolete. It's time we call out EVIL for what it is. (Or, if you can't handle "Electronic Viewfinder Interchangeable Lens" then Frenchify it and call it "LIVE" for "Lens Interchangeable, Viewfinder Electronic" or "Viseur électronique").
Stanley Joseph Wisniewski 1932-2019.
Dad, so much of you is in me.
Christine Fleischer 1947-2014.
My soulmate. There are no other words.
Rahon Klavanian 1912-2008.
Armenian genocide survivor, amazing cook, scrabble master, and loving grandmother. You will be missed.
Ciao! Joseph
www.swissarmyfork.com
