R5/R7 and RF100-500mm thoughts for those who use both
Started 1 week ago | Discussions
tsinvest
tsinvest Senior Member • Posts: 1,600
I have used the RF100-500 on both my R5 and R7 and actually get great results with each body.  I am referring to the longer end of the lens.  Shooting birds at a distance, I think my results are equally as good with either camera.  It would be interesting to see if others with these setups feel the same or do you prefer the 5 over the 7 or the 7 over the 5 with the RF100-500 lens?
Thanks, Tom
my Instagram gallery...
https://www.instagram.com/tom.sicora
 tsinvest's gear list:tsinvest's gear list
Canon G7 X III Canon EOS R5 Canon EOS R7 Canon EOS R10 Canon RF 35mm F1.8 IS STM Macro +6 more
Emile15 Senior Member • Posts: 1,768
Re: R5/R7 and RF100-500mm thoughts for those who use both
I have too, but the jury is still out on this one in that I am not sure yet whether the combo with the R5 gives me a higher hit rate.
 Emile15's gear list:Emile15's gear list
Fujifilm X100T Fujifilm X-T4 Canon EOS R5 Canon EOS R7 Fujifilm XF 55-200mm F3.5-4.8 R LM OIS +12 more
tsinvest
OP tsinvest Senior Member • Posts: 1,600
It's funny, I don't favor either one and I always feel I will get similar results with each.  It looks like perhaps you may be in agreement with this.
Thanks, Tom
RDM5546
RDM5546 Senior Member • Posts: 3,654
I have both. I get similar results for sure. The R7 weighs less and has newer autofocus EV behavior like the R3. I use the R7 with the RF100-500 but more often with the RF100-400 & the 1.4X TC. I like low weight for cases when there is lots of light the R7 and RF100-400 X1.4 is lighter, easier to swing in heavy action and does a great job. The R7 1.6 crop sensor reach can be precious some times,
Does this mean FF is dead and do not like the R5. No. Not at all. I am keeping them both for what they are slightly better at. Low light and bokeh is for the R5. I would prefer the R5 with big aperture RF glass (50f1.2, 135f1.9, 15-35f2.8, 24-70 f2.8 and 70-200f2.8) for indoor sport in low lit gyms.
I value having the right tool for right job.
 RDM5546's gear list:RDM5546's gear list
Canon RF 100-500mm F4.5-7.1L IS USM Canon G5 X II Canon EOS 70D Canon EOS 7D Mark II Canon EOS 5D Mark IV +47 more
tsinvest
I agree with you, less weight is always a plus. I may buy the 1.4 extender as you mentioned and give it a try.  I've never used extenders and it may be about time I try. Thanks for your comments 🙂
Thanks, Tom
chrisis
chrisis Forum Member • Posts: 63
I have both and, while the results are often quite similar, I do find that i tend to use different combos in different situations.
If the objects (usually birds) are way off then I do tend to prefer using the R7/Rf 100-500 L combo, as I find that the extra 1.6X “reach” of the R7 is very useful in those situations (and yes, i know the difference between angle of view and actual reach, and i know i can crop, etc., etc. but I suspect most people know what i mean).
If the objects are closer, even if they are quite small, then i tend to use the R5 combo, simply because I find I get better Bokeh/ Out of Focus backgrounds from that combo than the one with the R7.
One other factor is that my R5 typically hads a Battery Grip on it and so it’s much heavier than the same combo using the R7. That’s an issue if I am doing long walks, especially on sand (beaches) or going up hills.
Chris
Against stupidity the gods themselves contend in vain
 chrisis's gear list:chrisis's gear list
Canon EOS 7D Mark II Canon EOS M6 II Canon EOS R5 Canon EOS R7 Canon RF 24-105mm F4L IS USM +5 more
tsinvest
This is a very good observation.  I never considered this however I always noticed very good Bokeh with the R5 but never compared it to the R7.  Good point!
Chris
Thanks, Tom
RogerZoul
RogerZoul Veteran Member • Posts: 3,243
I have both.  I feel the R5 wins every time for birds in flight, but the R7 isn't bad if the light is good or if the bird it perched. Also, I prefer the r7 for butterflies and dragons, or any insect life and for macro, with a macro lens. The r7 is great with the 1.4x TC and the 100-500 when photographing tiny butterflies at very close range.  Hard combo to beat for that application and it the reason I will keep it.
For me, the r7, even with its beefed up AF system compared to the R5, still can't track like the r5.  I have had many birds in pretty close range and the R7 would fail to lock on or give me shots that seemed to be slightly oof, when doing BIF, when I know from experience that the R5 will nail such a shot (as I have done time and time again).  Frankly, I had similar results with the 90D and even the 7DM2.  I personally think QC on the lower priced Canon bodies is not consistent.  Also, I see a similar situation with my RF 800mm F11 lens.  Several of my Canon shooting buddies have this lens, but my copy not only "pulls" to the right sometimes when shooting a burst, but it is not consistently sharp.  On some occasions, usually at close range, I have gotten really sharp results from that lens. But most of the time and greater range, it loses it sharpness.  I find it too "iffy" to use and now just use my L glass.
 RogerZoul's gear list:RogerZoul's gear list
Canon EOS R5 Canon EF 500mm f/4.0L IS II USM Canon RF 35mm F1.8 IS STM Macro Canon RF 100-500mm F4.5-7.1L IS USM Canon RF 800mm F11 IS STM +31 more
MarshallG
MarshallG Veteran Member • Posts: 8,951
Chris
The R7 has higher pixel density than the R5. So in those cases when you cannot fill the frame on an R5 at 500mm, the R7 results will be better.
 MarshallG's gear list:MarshallG's gear list
Canon EOS R5 Canon EF 50mm F1.4 USM Canon EF 85mm F1.8 USM Canon EF 16-35mm F2.8L II USM Canon Extender EF 1.4x II +4 more
tsinvest
These are all good points to keep in mind.  Thanks for sharing this information.  I need to get the 1.4x TC.  I've never used a TC but after a few responses about how well they work I think it's time for me to try one.
Thanks, Tom
Bramble9 Regular Member • Posts: 211
I have both R5 and R7 w/ 100-500L, RF100-400, and 600mm f11.  I'm rapidly approaching "Geezer Class" i.e. 80 y.o. and now mainly shoot yard birds during the day and moon-shots at night, conditions permitting.  And for those two purposes, I almost totally rely on the  R7 + 100-500L.  I add the 1.4 xTC for the moon shots.  I also like the R5 w/ the 600mm for yard birds as the focal length is "right on".
The 32 MP sensor of the R7 seems to be a sweet spot for me with plenty of room for cropping and file sizes still easy to work with.  I do use the R5 for anything low light and grand kids duty w/ either 24-105L or 24-240 for outdoors, e.g. beach work.
With the R7 I prefer not to have ISOs higher than about 1600, but with the R5 I can easily shoot fairly clean at ridiculously high ISOs. (Topaz Ai noise reduction as needed)  But anymore I don't do much night shooting.  One last thought, for bumbling around daytime, the RF 100-400 and either body makes for lighter carry and optical quality is still very good.  I may add the R8 and 24-50 for an "easy to carry" package-- hope that lens is at least decent,
Bramble9
 Bramble9's gear list:Bramble9's gear list
Canon EOS R5 Canon EOS R7 Canon RF 24-105mm F4L IS USM Canon RF 100-500mm F4.5-7.1L IS USM Canon RF 14-35mm F4L IS USM +1 more
tsinvest
Bramble9
More good information...Thanks!
The R8 sounds interesting.  I was thinking of adding it too, however I decided to get the R10 instead since I do a lot of bird photography.  It is working out well.  I'm 73 and also enjoy lightening the load when I can.
Best of luck!
Thanks, Tom
Franz Kerschbaum
Franz Kerschbaum Senior Member • Posts: 1,242
Have both inkl both extenders. Great on all combinations.
 Franz Kerschbaum's gear list:Franz Kerschbaum's gear list
Canon EOS 5D Mark II Canon EOS 7D Mark II Canon EOS M6 Canon EOS Ra Canon EOS R5 +30 more
RDM5546
The 1.4X works very well with almost degradation from the extra glass.    The 2X pleases me when it is needed.  I particularly like full 4X zoom when using TCs rather the reduced zoom range of 300-500 when using the 100-500mm.   You need the right for the right job.  The 100-400 is both less weight and less bulk even when the 1.4X is used.
