dp quattro viewfinders
Started 2 weeks ago | Questions
j_y Forum Member • Posts: 64
Hello! I recently ordered a dp2 quattro and was hoping to get clarity on the available externa viewfinders.
is the LVF-01 an attachment that goes over the camera’s back screen? If so, how effective is it in practice?
would you recommend the VF-41 optical viewfinder instead?
Thanks!
Sigma DP2 Sigma dp2 Quattro
xpatUSA
xpatUSA Forum Pro • Posts: 23,016
Re: dp quattro viewfinders
j_y wrote:
Hello! I recently ordered a dp2 quattro and was hoping to get clarity on the available external viewfinders.<>?
On other than Quattro (any DP), I found the view in the Sigma VF models too small for my taste, preferring larger and much cheaper third-party models where the viewing scale is about the same as that seen by the naked eye.
what you got is not what you saw ...
Panasonic Lumix DMC-LX1 Sigma SD9 Panasonic Lumix DC-G9 Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Sigma 17-50mm F2.8 EX DC OS HSM +11 more
Bee Bee
Bee Bee Contributing Member • Posts: 583
Yes.
It does what it says it does - well.
The issue I have/had is that it just adds too much bulk; the way it's attached, it feels precarious.
For me, I realised I don't benefit from it. I attached a matt screen protector, which helps with sun + glare; then, I cup my other hand to provide shade from the sun if needed - I can see the screen well enough to compose, etc.
I've never used it, so I can't comment or compare.
Thanks!
Bee
 Bee Bee's gear list:Bee Bee's gear list
Sigma DP2 Sigma DP1 Sigma DP2 Merrill Sigma DP3 Merrill Sigma dp2 Quattro +9 more
Ceistinne
Ceistinne Veteran Member • Posts: 3,256
Thanks!
j_y,
It is an excellent piece of equipment, beautifully designed and the image view in it is very good. A very necessary tool in bright sunlight.
The VF21 is also good but I do not have it, as I use an optical viewfinder modified from the viewfinder out of an old Sigma compact film camera. It can be useful at times when I do not want to use the LVF-01.
S
 Ceistinne's gear list:Ceistinne's gear list
Sigma SD1 Merrill Sigma dp2 Quattro Sigma SD9 Sigma SD10 Sigma SD14 +5 more
