Re: Run&Gun Setup (Frustrations with WB, Exposure and Focusing)
rdbot wrote:
So far, I haven't been using shutter priority because I sometimes want the aperture to stay wide open and not be variable.
In that case, wouldn't it make more sense to either use aperture priority and auto ISO or let the shutter speed fluctuate to adjust exposure? Note that with a variable shutter speed you WON'T be getting consistent 180-degree shutter speed, which some people veel is very important. (180-degree shutter speed is when the shutter speed is TWICE the frame rate, so if you shoot at 30fps, the shutter speed is set to 1/60th, if you shoot at 69fps, the shutter speed would be 1/120th.)
Or, if possible, use Andrew's suggestion for a variable ND filter.
But if the exposure isn't automatic, I'm left with having to change the aperture manually, or the nd filter, or the exposure compensation dial (unless I'm using variable ISO and then it doesn't seem to have an effect).
If it is very BRIGHT outside, then you might be at the LOWEST ISO your camera can go, so Auto ISO might not make a difference.
In short, I never know which options to go for and wind up losing lots of shots. Not to mention white balance for changing lighting situations. Is AWB fine if I can't actually get a white balance reading or if the subject then moves to another room or outside?
White balance is tricky. Really, you might have to rely on auto white balance just because you might not have other options in a changing environment. Shooting in 10-bit gives you a lot more flexibility to change white balance in post, but I am not 100% sure the a7R V shoots in 10-bit.
What's the best way for me to be able to quickly turn the camera on and film in a snap? If aperture priority is the answer, then is there a way to control it such that the ISO changes before the aperture does? If variable ISO is the answer, then can I get the exposure compensation to work if the camera is giving me zebras and I want to turn it down a notch? Or any other way?
If you are in aperture priority, then the aperture SHOULDN'T change (unless I am losing my mind, which is really a 50/50 possibility on a Monday morning). If the zebras are showing up, and the ISO is NOT already at it's lowest, then using exposure compensation should either lower the ISO or raise the shutter speed.
As far as focusing, I've run into problems as well. When shooting dogs running, for example, I found most of my footage out of focus even with the setting to animal. There are sometimes more than one dog and it's really hard to use the touch screen to lock on to a specific dog when they are far away because the dog is too small. By the time they get close enough, they are going to fast for me to touch the screen. If I let the camera try to focus, it's been too slow and usually the shot is missed. Or when the dog runs into frame while the camera is focused in the distance, why doesn't it lock on the dog when coming in frame? (Also, can I switch sometimes to a human or specific object and then back to dogs?)
I don't know how the new AF system in the a7R V works, but aside from animal detect, isn't there a specific tracking af setting? Can tracking and animal detect be used together? Or are they mutually exclusive? Or is tracking now "built in" to all the other continuous AF modes?
I also prefer sometimes looking though the viewfinder when it's bright out but then I cant use the LCD tracking on touch screen unless it can be done somehow in the viewfinder? I was hoping that the camera would be good enough to lock on to a dog, any dog, but sometimes it's focusing on random objects or even people. (On a tangential note, can one use the facial memory for dogs?)
When looking through the viewfinder, can you use the joystick to move the AF spot over the dog that you want to track?
I don't know if the face priority works for dogs or not. That would be awesome!!!
p.s. I shot with slowmo 120p which I think has to be HD and it looked terrible. Is that normal? I read somewhere with the A7RIV that it didn't look good, but hard to believe it would look so bad. Also, maybe this was partly the issue, my ND filter was over a clear filter filter for part of it.
In my opintion, Sony HD quality (no matter what the frame rate) has always looked pretty bad (with the exception of the NON-4K cameras like the a6000 and a5100, etc.,) So it might be a combination of Sony's HD quality and the quality of your ND and clear filters.
I don't know if the a7R V has 120fps in the REGULAR video mode, but I believe that in past cameras, using the S&Q mode where footage is automatically slowed down in camera would be worse than shooting in the "normal" video mode and then slowing down in post.
