Question(s) for RF 14-35 owners
Started 2 weeks ago | Discussions
Basil Fawlty
OP Basil Fawlty Regular Member • Posts: 237
Re: Question(s) for RF 14-35 owners
drsnoopy wrote:
Basil Fawlty wrote:
Wing2 wrote:
Distortion and vignetting is not serious after correction. The RAW file uncorrected does have serious distortion and vignetting. However, if you manually correct the RAW file, you can get as wide as 13mm
Thanks for your reply! Just curious, from your experience, was you zoom out, at what focal length would you say the uncorrected distortion and vignetting cease to be a problem? In other words, how bad is it at 15mm? 16mm?
It’s irrelevant. Just use the profile (DPP, DXO, Adobe) and the distortion is corrected. It is designed to be used with a profile. If that troubles you, buy something else. Or use jpeg.
Thanks for your thoughtful reply.  I ask him because I'm just curious.  I am well aware that it can be fixed in post.
 Basil Fawlty's gear list:Basil Fawlty's gear list
Panasonic LX100 Canon EOS 5D Mark IV Canon EOS R5 Canon EF 50mm F1.4 USM Canon EF 135mm F2L USM +8 more
dmanthree
dmanthree Forum Pro • Posts: 10,302
Which of the three do you prefer? I use ACR just to keep it simple when importing to PS.
---on the cutting edge---
BBR5 Regular Member • Posts: 212
In general I prefer DXO PureRAW because of the excellent noise reduction and overall rendering. But when using it I typically follow-up with LRc for additional editing (I have PureRAW, not PhotoLab).
In the case of the RF14-35, the PureRAW distortion correction also produces an image slightly wider than that from LRc. Interestingly, ON1 produces an even wider image than PureRAW with the RF14-35.
Comparison images from DXO PR and ON1 below.
DXO PureRAW
ON1
Basil Fawlty
From the samples you posited I think I would agree.  If I end up getting this lens, I may have to invest in DXO PR.  It would be interesting to play around with the Lightroom corrections (Adjust distortion and transform sliders maybe) to see what adjustments might be made to match as close as possible the DXO corrections.
Abbott Schindler Veteran Member • Posts: 3,099
I use Capture One and can’t comment about LR, but you’ve already gotten a lot of input about LR and its profile for this lens.
The distortion, vignetting, and noticeable edge softening at the long end (reported in the reviews I read before buying the lens) are very easy to correct for in a single layer in Capture One. I assume you could do something similar in LR.
I bought this lens because I felt that the EF 16-35 + RF adapter was ungainly on the R5. Also, I really wanted the 14-16mm FL range, as it covers much of what I shoot with my 11-24L.
Before purchasing, I read several reviews from sources I’ve grown to trust, and from them had an idea of what to expect. Then I went shooting with a friend who kindly lent me his lens for a little while. I shot a number of images at the FL and aperture extremes and some in the center FL region. Sure enough, my shots were consistent with the reviews. I found the needed corrections trivial to make, and bought the lens without blinking. Now instead of needing to carry the huge 11-24 and 16-35, I’ve got one lens that does well for almost everything the other 2 did. I’m keeping the 11-24, but now I rarely need to carry it.
I don’t hesitate to recommend this lens if you need the ultra wide FL range. Overall it’s an excellent lens. As mentioned earlier, unlike EF L lenses that were optically excellent on their own, I have the feeling this lens was designed to require processing to achieve what I consider L-lens results.
grenow
grenow Regular Member • Posts: 141
I got my 14-35 last month and have thoroughly enjoyed using it. As other have said, it is relatively light and compact, and with the 70-200 f4 makes a very easy to carry "cover (almost) everything" kit.
Here's a couple of shots taken shortly after I got it, at 14 and 35.
14mm
35mm
It would make an excellent walk around cityscape/street lens, which I shall try next time I get to a city.
 grenow's gear list:grenow's gear list
Canon EOS R6 Canon RF 35mm F1.8 IS STM Macro Canon RF 24-105mm F4L IS USM Canon RF 100-500mm F4.5-7.1L IS USM Canon RF 70-200 F4 L +4 more
Basil Fawlty
Thanks for sharing the images - very nice!  Looks like the sky was on fire.
Blue-Shift
Blue-Shift Regular Member • Posts: 140
Basil Fawlty wrote:
For anyone who actually has the RF 14-35:
1. Does Lightroom now have a correction profile for this lens? I've heard it has quite a bit of barrel distortion and vignetting at the wide end?
2. If LR has a profile now, how well does it work?
3. If you had it to do over, would you still get this lens, or would you get something else (like maybe RF 15-53 or EF 16-35, etc)? Why or why not?
Thanks in advance.
1. Yes and yes.
BUT there is a big advantage, too: If you deactivate the lightroom profile, you get closer to 12mm with good image quality. (with distortion and vignetting). Having that option can be very helpful, 12mm is an incredible focal range for such a compact package.
2. I could see no problems with it whatsoever.
3. I had the EF 16-35 before. It's a very good lens, and for many use cases it's fine keeping that one. I switched because:
1. Wanted to go all-native (not a strong reason, because adapting EF glass works perfectly)
2. The RF 14-35 can focus much closer, giving it 2x the magnification of the EF 16-35. That's quite an advantage for a flower guy like me.
3. The option to go wider while deactivating profile is so nice to have, I use this on a regular basis. It's useless for architecture, but most shots of living subjects (plants, portraits, animals...) will not be negatively affected by the distortion.
CamerEyes Regular Member • Posts: 266
Thanks in advance.
1. Yes and yes.
Don't you miss the EF16-35mm? I am about to walk down the path of trading it with the RF14-35. Biggest hesitation is the build quality.
 CamerEyes's gear list:CamerEyes's gear list
Sony a7C Canon EOS R7 Canon EOS R6 Mark II Canon EF 50mm f/1.2L USM Canon EF 50mm F1.4 USM +12 more
Blue-Shift
No, not at all.
I have to say that I was annoyed a bit at first about the extending design of the RF. All those complications for one cm extension! In that sense, I prefer the EF solution with a solid, rugged barrel that is 1cm longer.
But once I got the RF 14-35, I forgot about it quickly. It's build quality is beyond reproach, very solid feeling and every bit as good as the EF, but much more modern. I used it in strong rain a few times with no issues, also it got dirty several times and never was there any complaint.
I like this lens a lot despite it costing a steep premium over the EF - it was worth it for me.
CameraCarl Veteran Member • Posts: 9,193
I don't miss the weight and size of the 16-35. I've never been hung up over plastic versus metal construction. My only annoyance with the 14-35 is that the control ring and the focusing ring are adjacent to one another.  Sometimes when I am focusing I move the control ring which I have set to zoom in to assist focus so the sudden appearance of the zoomed view can be disconcerting.
drsnoopy Senior Member • Posts: 1,216
Basil Fawlty wrote:
drsnoopy wrote:
Hi - it was intended as a thoughtful post, not a criticism.  My point is it’s intended to be used that way, it’s not “fixed in post” because they never expect you to see it uncorrected.  Indeed you can’t view it on the camera without correction, in the EVF or on the LCD, and this is why the ability to turn correction off is greyed out in the menu.  In some other camera systems, Fujifilm for example, software correction is employed by being baked into the RAW file, and this with/without correction question never arises and isn’t even discussed, it’s basically a non-issue.
 drsnoopy's gear list:drsnoopy's gear list
Canon EOS RP Canon EOS R5 Canon EOS R10 Canon EF 100mm F2.8L Macro IS USM Canon RF 35mm F1.8 IS STM Macro +10 more
Blue-Shift wrote:
No, not at all.
Thanks for this helpful feedback.
