Question(s) for RF 14-35 owners
Started 2 weeks ago | Discussions
Basil Fawlty
Basil Fawlty Regular Member • Posts: 237
For anyone who actually has the RF 14-35:
1.  Does Lightroom now have a correction profile for this lens?  I've heard it has quite a bit of barrel distortion and vignetting at the wide end?
2. If LR has a profile now, how well does it work?
3.  If you had it to do over, would you still get this lens, or would you get something else (like maybe RF 15-53 or EF 16-35, etc)?  Why or why not?
Thanks in advance.
 Basil Fawlty's gear list:Basil Fawlty's gear list
Panasonic LX100 Canon EOS 5D Mark IV Canon EOS R5 Canon EF 50mm F1.4 USM Canon EF 135mm F2L USM +8 more
BobKnDP Senior Member • Posts: 3,140
Re: Question(s) for RF 14-35 owners
I don't use LR.
The 14-35 has lots of barrel distortion at the wide end. It also vignets fairly badly in the corners. I imagine that a lot of the vignetting disappears after the barrel distortion is removed by remapping, and the frame is cropped back to a 3:2 aspect ratio.
I assume that LR has profiles for the lens, like Photoshop.
The 14-35 weighs 544g. The 15-35, 840g.
I haven't used the 14-35 a great deal yet, but I think I can live without the extra stop.
LennyLevino Forum Member • Posts: 59
Also interested. I have the 15-30mm, which has a profile for it in LR. However, even after applying the profile the image will still be distorted, at least at shots under 20mm.
 LennyLevino's gear list:LennyLevino's gear list
Canon EOS R6 Canon EF 135mm F2L USM Canon RF 24-105mm F4L IS USM Sigma 40mm F1.4 DG HSM Canon RF 85mm F2 Macro IS STM +3 more
R2D2 Forum Pro • Posts: 26,531
Thanks in advance.
Data point:
I bought the 15-35 f/2.8 because I needed the extra stop for shooting action.  Really nice rendering.  Zero complaints.
R2
KariP
KariP Veteran Member • Posts: 6,450
I really own this lens…
Thanks in advance.
I use CaptureOne and it has corrections - results are just very good. There is also DPP to use. LR very likely has corrections… no sure.
14-16mm really shows those distortions - in real life it is not a problem. A very usable lens! Images look good and very sharp
The size of the lens is perfect and i carry it with RF24-105L and 70-200f4  - weight of my bag stays portable.
Kari
I started SLR film photography in 1968. Now two systems: Fujifilm X-H1 + X-E3 and Canon FF gear 5dMkIV + R6
 KariP's gear list:KariP's gear list
Canon EOS 5D Mark IV Fujifilm X-E3 Fujifilm X-H1 Canon EOS R6 Canon EF 50mm F1.4 USM +13 more
Phylloxera Regular Member • Posts: 256
Replaced my excellent EF 16-35/4.0 by an RF 14-35/4.0  (considering size and weight with adapter).
RF 14-35 shows more vignetting in the corners at 14/16mm  but corners seem a lilttle bit sharper. At 35 mm the corners are softer.
(I'm using DxO PL6)
 Phylloxera's gear list:Phylloxera's gear list
PTGui Pro
koenkooi Contributing Member • Posts: 920
You can check all supported lenses here: https://helpx.adobe.com/camera-raw/kb/supported-lenses.html
It will list the ACR and LR version where the profile was introduced. For the 14-35mm: yes, there is a profile.
Users on the interwebs report that LR will give you a slightly wider result than DPP4/SOOC-jpeg and that the correction in DxO PL will give you an even wider result. DxO PL also allows an uncropped result for a even wider, but funnily shaped result.
 koenkooi's gear list:koenkooi's gear list
Canon EOS 7D Canon EOS M Canon EOS M6 II Canon EOS R5 Canon EF 85mm F1.8 USM +20 more
CameraCarl Veteran Member • Posts: 9,193
1. Yes.
2. Fine.
3. I'm happy with it and have no regrets having sold my EF 16-35.
Howard Contributing Member • Posts: 724
Hi,
I do not use Lightroom and also do not use profiles that often from any software brand.  I replaced the EF-16-35/4 with the 14-35 and my clients are very happy with the results.  I almost dropped the 16-35 last year because I found the lens to be very bulky and difficult to handle with the adapter when changing lenses on the fly without having time to put all the gear down and slowly change lenses.  The distortion that does occur is easily corrected and I would miss some of the images if I did not have the extra 2 (or more since I really think it is wider than 14 before correction).
Howard
 Howard's gear list:Howard's gear list
Canon EOS 6D Canon EF 50mm F1.4 USM Canon EF 85mm F1.8 USM Canon Extender EF 1.4x II Canon EF 70-200mm F4L IS USM +4 more
dmanthree
dmanthree Forum Pro • Posts: 10,302
Yes, there is a profile.
It works perfectly.
I'd buy this lens again in a heartbeat. It's excellent.
---on the cutting edge---
BBR5 Regular Member • Posts: 212
Lightroom's correction is good. It's compared with Canon DPP and DXO results below.
Canon DPP
Lightroom Classic
DXO Deep Prime
If the speed of the 15-35 f/2.8 would be useful for you and you don't mind the extra weight and size, it's probably worth the difference in price.
I prefer smaller and lighter lenses in most cases, so if doing it over again I'd probably consider the 15-30 as well. The drawback of the 15-30 for me is that I occasionally find the focus of the slower lenses somewhat poor in certain low light conditions.
José B
José B Forum Pro • Posts: 20,482
5
I don't own the RF 14-35 as my EF 16-35/4 L IS is excellent with the R6MKII. So I'll just keep the EF.
 José B's gear list:José B's gear list
Canon EOS R6 Mark II Canon EOS-1D Mark III Canon EOS 5D Mark II Canon EOS 5DS Sony a6500 +16 more
Wing2 Contributing Member • Posts: 512
Lightroom does have a correction profile for this lens.
Distortion and vignetting is not serious after correction. The RAW file uncorrected does have serious distortion and vignetting. However, if you manually correct the RAW file, you can get as wide as 13mm
1mm is a lot wider, plus it has better macro and IS and lighter
Bowenphoto Junior Member • Posts: 30
Hi,
I have this lens and use LR as well... I would say the profile seems to work well and I do not even notice it is happening! I would say there is certainly a little more distortion you can see in the 14-16mm range, but realistically there is going to be tons of focal length distortion there anyways so you just have to use it well, and it's always a fun challenge to shoot that wide for that reason!
I came from using the Nikon Z 14-24 2.8, which was a great lens and probably the best of it's kind, but I still love using the Canon Rf 14-35 and appreciate its smaller size, wider range and (to my taste) better build quality. I would buy it again!
Basil Fawlty
OP Basil Fawlty Regular Member • Posts: 237
Thanks for your reply!  Just curious, from your experience, was you zoom out, at what focal length would you say the uncorrected distortion and vignetting cease to be a problem?  In other words, how bad is it at 15mm?  16mm?
I would say to me, 17mm seems very safe, 16mm is probably right on the border, 14 and 15 you will start to see more of the distortion. But again, I think it's more than useable, but I do not take a lot of photos of buildings or straight lines. I use it more for waterways, landscapes etc.
All of these are shot at 14mm I believe... hope it helps!
Thank you. This is a very useful comparison.
Like a lot of RF lens including the 16mm 2.8, 15-35 2.8,24-240, 14-35 4.0 is designed to be working with distortion correction software/firmware to start with.
The theory behind this is distortion and vignetting are now easily correctable by software or firmware but the extreme wide angle and wider zoom range achieved using this method is close to impossible (may be possible at very high cost) to be done using pure optical solution.
I can see distortion and vignetting on uncorrected RAW files from 20mm or below. If you refuse to use any software to do post-processing, you may be better off shooting jpeg (Canon camera's firmware would correct it for you)
Wing2 wrote:
(snip)
Is there anyone who refuses to do post processing?
I hope that there is no one who regards distortion and vignetting correction as inappropriate in post processing, but OK if the processing is done in-camera. That makes zero sense, at least to me.
drsnoopy Senior Member • Posts: 1,216
It’s irrelevant. Just use the profile (DPP, DXO, Adobe) and the distortion is corrected. It is designed to be used with a profile. If that troubles you, buy something else.  Or use jpeg.
 drsnoopy's gear list:drsnoopy's gear list
Canon EOS RP Canon EOS R5 Canon EOS R10 Canon EF 100mm F2.8L Macro IS USM Canon RF 35mm F1.8 IS STM Macro +10 more
