DST on R5
Started 2 weeks ago | Questions
PDE94301 Forum Member • Posts: 60
DST on R5
I believe the answer is no, but can the R5 automatically switch its onboard clock 1 hour forward in March, and back again in November?
 PDE94301's gear list:PDE94301's gear list
Canon EOS R5 Canon RF 50mm F1.2L USM Canon RF 24-105mm F4L IS USM Canon RF 85mm F1.2L USM
Canon EOS R5
chipman
chipman Regular Member • Posts: 491
Re: DST on R5
OP PDE94301 Forum Member • Posts: 60
Re: DST on R5
chipman wrote:
https://support.usa.canon.com/kb/index?page=content&id=ART178153
Thanks. I think this confirms my suspicion that it won't change automatically, e.g.,
4. Set daylight saving time.
- Set it as necessary.
It's not a big deal, but it's a minor hassle to remember to adjust the camera time every few months, given you've already entered your time zone.  Seems like it would be a very easy firmware improvement to make it automatic based on known DST conventions.
CameraCarl Veteran Member • Posts: 9,193
Re: DST on R5
no
Mark B.
Mark B. Forum Pro • Posts: 29,742
Re: DST on R5
The only way that could happen is if the camera had a continuous cellular or internet connection.
Re: DST on R5
Not sure I follow why that's the case. If you tell it what city's time zone you're in it should know when to flip the clock. For example, in '23 it would change time in LA time zone on March 12 & Nov 5, in London on Mar 26/Oct 29, in Tokyo it wouldn't change, etc. I think you could simply have a table of selectable cities in the firmware to automate this. If in the future if countries adopt or abandon DST then future firmware updates would capture that. That doesn't seem overly difficult to me.
BobKnDP Senior Member • Posts: 3,140
Re: DST on R5
No.
After the date, time, and location were set, all that would be needed would be the rules for that location.
I have a (low-end) remote weather station. It has no Internet connection, and it receives no time signals. It automatically does DST, using the standard that applies to most of the US. (DST can be turned off, for those places like Arizona that don't switch.)
If the rules change, it won't work correctly. I believe that the last change was in 2007.
Ali Senior Member • Posts: 1,969
Re: DST on R5
Even if they could do it thru built in tables and without a network connection, I am sure companies don’t want to be in the business of having to release firmware updates for DST adjustments, which do happen pretty often around the world. Especially firmware updates many years after the camera has been released.
One problem with having a built in table that may go stale is that your camera will change the time when you are not expecting it.
 Ali's gear list:Ali's gear list
Sony Cyber-shot DSC-HX50V Olympus TG-5 Panasonic Lumix DC-ZS80 Canon EOS M6 II Canon EOS R5
koenkooi Contributing Member • Posts: 920
Re: DST on R5
Exactly this! If you look at https://www.iana.org/time-zones you can see that in 2022 there were at least 7 changes that caused a release of the tzdata files.
The example that comes to mind is Turkey in 2015, where they moved DST 2 weeks later, with little to no forewarning, for election shenanigans: https://www.bbc.com/news/world-europe-34631326
 koenkooi's gear list:koenkooi's gear list
Canon EOS 7D Canon EOS M Canon EOS M6 II Canon EOS R5 Canon EF 85mm F1.8 USM +20 more
Re: DST on R5
I hadn't considered the complexities of the world market.
However: do you change the time settings in your camera when you cross time zones? Do you care if your EXIFs are tagged with the correct local time?
I wonder why the standard isn't set to Zulu time. As long as the camera's clock is set correctly with respect to that, the time tag would be accurate regardless of locale. (If memory serves, Microsoft Windows files are tagged by Zulu time. The time and date displayed in Windows are those of the PC's time zone, though.)
apersson850 Senior Member • Posts: 2,076
Re: DST on R5
The camera does both. Your images will have the time for the time zone you set as well as UTC.
Garmin is a company that does try to keep up with changing DST specifications. There's a massive amount of firmware updates released for many models just to cover that. So they know all about it.
Anders
 apersson850's gear list:apersson850's gear list
Canon EOS 40D Canon EOS 400D Canon EOS 7D Canon EOS-1D X Canon EOS-1D X Mark II +26 more
Re: DST on R5
Yes, I've gotten pretty good at remembering to do that right before boarding
Extremely. But I care more that all cameras agree on which minute it is. Recent Canon cameras like to drift, my M6II does a few minutes per week. My R5 almost always has the GP-E2 mounted when used outdoors, so its clock is reasonably correct.
One of the issues is that the EXIF spec doesn't specify an option for Zulu/GMT nor for timezones. Canon does store the time offsets in a vendor specific section, so you can derive both the local time without adjustments, GMT and the time that is displayed on clocks locally.
Another thing to consider is how your photo organizer (e.g. LR) and viewer (e.g. phone) handle time. In the past I really liked how Google Photos would auto generate an album for your travels, including Indiana Jones style travel maps. The problem was that the generator would look at your current timezone, so if it ran after you got back home, your days would be off, in my case due to the 9 hours between California and The Netherlands. Google understands timezones, use GMT internally but use your current location to set midnight for showing the weekday.
I'd like to see a few changes to how Canon cameras handle time and syncing:
  1. Allow time sync over bluetooth, currently the phone app only allows time sync over wifi. It does allow GPS sync over bluetooth...
  2. Try contacting a time server every time a connection over wifi is made
  3. Fix 'automatic sync' when using the phone app, it still needs a manual sync
  4. Allow camera-to-camera time syncing over bluetooth, especially if one of them has GPS
  5. Allow the app to update the timezone database so we can have automatic adjustment based on both time and position.
Re: DST on R5
I can't seem to find the time zone anywhere in my EXIF data.
I just took some test shots at similar times, where I manually changed the R5's clock to another city (and the clock moved ahead by the correct amount) but my RAW files in Windows (and EXIF data as shown in DPP4) are showing different (rather than the same) times, and there's no time zone info. anywhere as best as I can tell.
Mark B.
Re: DST on R5
^^^^This.  Too many variables; cities & localities seem to be changing their rules about DST frequently.  Too much for camera companies to keep the firmware up to date.  Far easier to let the user simply set local time and DST on or off.
Mark B.
Re: DST on R5
Too many variables for camera companies to keep up with.
Mark B.
Re: DST on R5
Garmin devices have to be updated frequently enough that they are going to have the correct local time.  Camera firmware is only updated when there's an update, and that's not every year and frequency becomes much less often as the camera ages.
JohnMoyer Regular Member • Posts: 354
Re: DST on R5
The exif and other metadata contains the time zone offset in multiple locations and contain the time in multiple locations including the time zone city in makernotes.
exiftool -G0:2 -a -"*date*" -"*time*" ../2023Jan17/IMG_2806.CR3
[File:Time] File Modification Date/Time : 2023:01:17 08:45:40-06:00
[File:Time] File Access Date/Time : 2023:01:17 17:44:50-06:00
[File:Time] File Inode Change Date/Time : 2023:01:17 17:44:46-06:00
[EXIF:Time] Modify Date : 2023:01:17 08:45:39
[EXIF:Time] Date/Time Original : 2023:01:17 08:45:39
[EXIF:Time] Create Date : 2023:01:17 08:45:39
[QuickTime:Time] Create Date : 2023:01:17 08:45:39-06:00
[QuickTime:Time] Modify Date : 2023:01:17 08:45:39-06:00
[QuickTime:Time] Track Create Date : 2023:01:17 08:45:39-06:00
[QuickTime:Time] Track Modify Date : 2023:01:17 08:45:39-06:00
[QuickTime:Time] Media Create Date : 2023:01:17 08:45:39-06:00
[QuickTime:Time] Media Modify Date : 2023:01:17 08:45:39-06:00
[Composite:Time] Create Date : 2023:01:17 08:45:39.24-06:00
[Composite:Time] Date/Time Original : 2023:01:17 08:45:39.24-06:00
[Composite:Time] Modify Date : 2023:01:17 08:45:39.24-06:00
[EXIF:Time] Offset Time : -06:00
[EXIF:Time] Offset Time Original : -06:00
[EXIF:Time] Offset Time Digitized : -06:00
[EXIF:Time] Sub Sec Time : 24
[EXIF:Time] Sub Sec Time Original : 24
[EXIF:Time] Sub Sec Time Digitized : 24
[MakerNotes:Time] Time Zone : -06:00
[MakerNotes:Time] Time Zone City : Chicago
[MakerNotes:Time] Time Stamp : 2023:01:17 08:45:39.24
chipman
Re: DST on R5
Getting back to DST, I don't know how easy or hard it was for Canon to do it, but my R7s changed to DST all by themselves, with no wifi or internet.
ron
John Photo Senior Member • Posts: 1,371
Re: DST on R5
My Canon bodies correct the times themselves if I wait about 6 months.;-)
Victor Engel Forum Pro • Posts: 20,968
Re: DST on R5
I always keep my cameras on standard time. Even works for when I use GPS because I use Houdageo for GPS tagging of my photos, and I always shoot a picture of the time on my phone as the last picture of a shoot, which allows Houdageo to apply the appropriate offset to all photos.
This saves aggravation especially if the photoshoot timespan includes the time of the timezone change. That can cause a real headache, especially if your import process includes a name change to the files based upon time. Images could be out of order and/or have duplicate names.
Victor Engel
 Victor Engel's gear list:Victor Engel's gear list
Canon EOS 5D Canon EOS 5D Mark II Canon EOS 600D Canon EOS 5DS Canon EF 50mm F1.8 II +13 more
