Some macros with flash
Started 3 weeks ago | Photos
baobob
baobob Forum Pro • Posts: 18,248
7
using the Godox 860
Part of a Euro banknote
Thx to the flash allowing a fast SS and a small aperture for DOF, these are all handheld, thx also to IBIS and OIS
Bob
Sony RX100 Panasonic ZS200 Fujifilm X-H2S Fujifilm X-H2 Fujifilm XF 35mm F1.4 R +16 more
a_c_skinner Forum Pro • Posts: 13,047
Re: Some macros with flash
This is with an old flash fired into a white umbrella.  Nice lighting.
Andrew Skinner
Fujifilm X-T2 Fujifilm X-E3 Fujifilm X-H2 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R +7 more
baobob
OP baobob Forum Pro • Posts: 18,248
Thx Andrew. Your comment  pushed me to completely revise my setting of the flash to get a much milder light avoiding harsh contrast. Posted in a new series
Bob
baobob
Some macros with flash NEW SERIES with new settings
Re: Some macros with flash NEW SERIES with new settings
That is nice lighting, what did you do?  I've got rid of my big flashgun and the umbrella is a bit of a bind if it is windy.  Nice if it rains!
Andrew Skinner
baobob
Thx In the first series the head of the cobra flish was oriented dircetly to the subject with a small softbox but even with the diffuser it delivers a harsh light.
After your comment I gave a 45 ° up orientation to the head of the cobra, used the diffuser gris and the small wite screen that you can pull upin the head of the flash.
and if the flash has not the wite scren an even bettrer solution is
https://www.amazon.fr/R%C3%A9flecteur-Externe-Recto-Verso-Compatible-Marques/dp/B073MHC4WB/ref=sr_1_1?keywords=diffuseur+flash+cobra&qid=1678637454&sr=8-1
Then you only have to play i,n M mode with settings : ISO, aperture, SS, power of flash, and angle of the head.
I spent recently sometime to correctly master these parameters and now I get good results with my Godox
Bob
Hmm.  I won't be able to do anything like that.  I'll have to experiment with the umbrella, but I think my flash isn't powerful enough having downsized the gear.
Andrew Skinner
baobob
In macro, the flash being quite close, its power is not a deal breaker. What matters is its type cobra or not and if cobra, the height vs the length of the lens to avois shadow. Which means with a small lens, a small cobra will do it perfectly.
And this one
https://www.amazon.fr/Yctze-R%C3%A9flecteur-Photographie-Portable-%C3%A9clairage/dp/B0B6JDHH3J/ref=sr_1_5?keywords=reflecteur%2Bde%2Blumi%C3%A8re&qid=1678700110&sr=8-5&th=1
in 30cm size is probably more convenient than umbrella ??
The operative distance is of course from the flash, to the umbrella and then on to the subject. My image was a 45GN flash and needed f11, so I guess the umbrella wasn't that reflective either.
I've used reflectors to modify daylight, I wonder how much better silver is than white?
I'll have to experiment when the flower season starts.
Andrew Skinner
sluggy_warrior Veteran Member • Posts: 3,204
I found for macro, even a diffuser box is not enough due to the extreme angles, and sometimes with the lens casting shadow itself.
What works for me is having two flashes with diffuser from nearly opposite angles. If I have only one flash, I'd have two shiny large bounce card as walls on two sides of the subject (of course with reduced SS).
The Godox V860II is indeed really nice with short cycling thanks to Li-Ion battery. Even for the AA model, I've used Li-Ion AA batteries with similar fast cycling time. It's also relatively easy to power the flash with a Ryobi battery pack.
https://www.amazon.com/EBL-Battery-Batteries-Capacity-Rechargeable/dp/B08RZ5NDMM/
Although, since "upgraded" from X-T20 to X-T2, I'm spoiled by the super-quick focus bracketing feature, thus, I've been using my two Ryobi lights for continuous lighting instead (they're on sale every few months, and I have too many Ryobi batteries)
https://www.homedepot.com/p/RYOBI-ONE-18V-Hybrid-20-Watt-LED-Work-Light-Tool-Only-P721/304049794
https://www.homedepot.com/p/RYOBI-ONE-18V-Cordless-LED-Light-Tool-Only-PCL660B/316630704
I even made a beauty dish for that Ryobi light just because of macro
https://www.thingiverse.com/thing:5610043
baobob
Very interesting and ... impressive..
But we are not in the same planet : my macro practice is while trekking or at least walking in nature anf all my gear has to fit in my backpack, without  a sherpa aid ...
So I can get beautiful macros only with the Godox, the macro lens or ext tubes or Raynox bonnette on the 70-300mm and that's all ! The Godox is sufficient to avoid any vignette and big enough to avoid shadow (tested with the 18-300mm Tamron at 300mm)
Add an extra battery and you can produce a few 1000s shots...
Well, the Ryobi are quite portable, too, subjectively Those are battery-powered lights.
I usually carry at least a pack of Ryobi battery to whole-day events to charge the camera batteries. Although, I'd not carry them in my backpack while trekking.
I think it's depending on the subjects. If I shoot a static subject and if I can use a tripod, I can set focus-bracketing with enough delays in between for the flash to cycle. However, with moving subjects like ants and bugs, ... the rapid focus-bracketing is crucial, thus, the need for continuous lighting, the flash can't cycle fast enough.
Ryobi battery pack can be the power source for many things
baobob
A trekker has to do some compromises between photo and hiking ... Despite my rather big Lowepro 500, cannot carry gear to do proper focus bracketing with tripod and my sherpa's salary exceeded my funds .....
A draught animal is the way to go.
Andrew Skinner
