How many shots left on card for Canon R5?
Started 2 weeks ago | Discussions
Crayonmuffin New Member • Posts: 12
Couldn't find this in the manual or searching around online. Apologies if this is an easy fix that I just must be missing.
Recently picked up an R5 and learning all the ins and outs of it. I initially only had a card for CF Express, a 128gb card, and then a few days later got a SD card for the second slot. If I have only the CFE card in the camera, it shows the remaining shot count in the top left of the LCD, which is great. If I insert the second card, that number doesn't change and there is no second number to know how much space is left on the second card. Is this how it's supposed to be? Wouldn't either the total number of shots left increase or there be a second number for the second card?
I shoot CRAW to CFE and JPG to the SD card so I'm assuming the limits will be very different and I'd love to have that info. Any input would be appreciated, thanks in advance!
Canon EOS R5
rmexpress22 Senior Member • Posts: 2,304
Re: How many shots left on card for Canon R5?
Assuming your CFe card is smaller, that number would be the correct number regardless of whether your SD card is present.
 rmexpress22's gear list:rmexpress22's gear list
Canon EOS 5D Mark IV Canon EOS M6 Canon EF-M 22mm f/2 STM Sigma 85mm F1.4 Art Canon PowerShot G16 +20 more
OP Crayonmuffin New Member • Posts: 12
Both cards are 128gb. The number of available shots is 5121. Whether it's a single card or both cards. Does that mean both cards EACH have that number of shots left? I figured JPG only on the SD card would allow for much more than the raws.
kikimora Regular Member • Posts: 225
In that configuration the RAWs on CFE are the limiting factor.
Sure, you can fit more JPEGs on the SD, but where would corresponding RAWs go?
That's all well and good. I'm just trying to find out if there is a way to SEE how many shots are left on EACH card.
Laqup Regular Member • Posts: 351
As others have pointed out, the limit is the raw files in your chosen mode. Even if there is space left on the SD card the camera will not record additional pictures due to missing space for the raws. There is no such thing as individual numbers for EACH card.
When CFE is full, switch to jpg only to SD exclusively and then you will get the according number of shots left.
 Laqup's gear list:Laqup's gear list
Canon EOS M6 Canon EOS M100 Nikon Z7 Nikon Z6 Canon EOS R +38 more
CameraCarl Veteran Member • Posts: 9,193
The screen displays the shots left on your active card. To see how many are left on the other card -- switch cards.
I tried this as well and the number is the same. But either I'm not communicating right what I'm looking for or there is no way to see the info I need unfortunately. I've seen it done in other manufacturer's bodies so I had assumed it would be this way with Canon
expro Senior Member • Posts: 2,273
Canon expects you to buy larger cards
 expro's gear list:expro's gear list
Canon EOS R3 Canon RF 24-70mm F2.8L IS USM Canon RF 70-200mm F2.8L IS USM Canon RF 100-500mm F4.5-7.1L IS USM Canon RF 14-35mm F4L IS USM
cnyphotoguy Contributing Member • Posts: 817
The info shown is correct, if you take a picture and have it saved to both cards in different formats, when the larger format card is filled...the other card even if storage left over is considered filled too. You'd need to change quality of the image captured, and maybe which card is used to take more shots at which time it would show how many shots are available.
The display us nit a representation of free space on the card.
 cnyphotoguy's gear list:cnyphotoguy's gear list
Canon EOS Rebel T6i Canon EOS RP Canon EOS 90D Canon EOS R7 Canon EF 100mm F2.8L Macro IS USM +15 more
jckk Regular Member • Posts: 227
You have to change the settings to record on one card only, or maybe have the second as overflow.  Then switching the primary card will show the remaining shots per card.  Like others have said, recording to multiple cards will show the lower amount since it needs to record to both.
James
James
I see. Well that sort of helped.
Side note, another thing I noticed is Fv mode which I've never used before. This seems to just replace all other modes really so I went to use that instead...and my number of shots shown on the screen decreased by about 2K shots. Going back to manual, it goes back to 5k shots or so, back to Fv it goes down to just over 3K. Far as I can tell all the same qualities to each card on each setting as well. Maybe I'm missing something there as well.
Crayonmuffin wrote:
James
To go back to the CFe/SD thing. If you shoot raw to CFe plus jpeg to SD, let's pretend your CFe only had space for 10 raw pictures, but your SD card has space for 100 raw pictures. Only you shoot 10 pictures, your CFe card has space for 0 pictures and your SD card has space for 90 pictures. You can't take pictures at this point because you have no more CFe storage and the camera will not switch to recording raw to SD only automatically. You can change the settings to take more pictures, but as far as the camera is concerned, your settings of shooting raw to one card and jpeg to another dictate that you have no more storage available to take pictures once the CFe card is full.
Fv can be auto anything, including ISO. Higher ISO has more noise, which takes up more storage. You can switch to manual, increase your ISO, and you will see the picture count drop also. Of course, that storage number is a complete guesstimate and how many pictures your storage holds is dictated by how much data is needed to capture the image.
Yes, I understand how the storage thing works, it would just be helpful to be able to see remaining shots regardless. I've seen this in other camera bodies and it was a nice feature for keeping track of cards, especially when switching between 3-4 if needed, to make sure you have a good amount of space left or not.
I was setting up the C1-C3 functions using Fv and manual. When setting them to identical settings, the Fv still shows as far, far less shots estimated. Poured over the settings for a long while to double and triple check. Seems odd, but I guess that's just how it is for some reason. Fv mode seems super nice to use but if I can get drastically more shots on a card from manual settings I guess I won't use it. (All of this assuming I'm not just missing some important detail somewhere, which is entirely possible.)
If the photos are actually made with the all the same parameters you will get exact same number of shots no matter if you use M or Fv.
What is shown is estimation only and the numbers differ because camera makes different assumptions – likely expecting photos in Fv mode to be possibly shot on higher ISO.
Yeah I'm not really sure how it's calculating it. Very odd. But it would be good to know, even roughly, if I have 3k shots left or 1k shots left, for example. Drastic enough difference to matter in some situations. I tried it again today and it's still a giant difference in estimated shots left. Will look into it more.
Don't change your ISO and only shoot the same kind of shot with similar or the same data and it should get you in the ballpark of the number of shots you can take.
