Do you mount the GP-E2 on the R7 without AD-E1?
Started 2 weeks ago | Discussions
bullet1 Veteran Member • Posts: 7,339
Does anyone of you use the Canon GPS unit GP-E2 on the R7 without using the Canon multifunction shoe adapter AD-E1?
Canon says that the AD-E1 shoe adapter is required to mount the Canon GP-E2 unit on the R6 Mkark II, R7, R8 and R10.
The GP-E2 works without the AD-E1 present although the lock lever does not go all the way.  Will mounting the GP-E2 without the AD-E1 damage the multifunction shoe on the R7?
Nelson
 bullet1's gear list:bullet1's gear list
Panasonic FZ1000 Canon PowerShot G5 X Sony a7 III Canon EOS R Canon EOS R7 +20 more
Canon EOS R10 Canon EOS R6 Canon EOS R7 Ricoh Caplio R8
Larry Cunningham
Larry Cunningham Senior Member • Posts: 1,228
Re: Do you mount the GP-E2 on the R7 without AD-E1?
I've used the GP-E2 both with and without the AD-E1 adapter, and it seems to work fine either way. As far as I'm aware, the only real purpose of the AD-E1 adapter is to make the connection between the camera and the device more dust- and water-resistant.
At least with my gear, the lock lever of the GP-E2 locks as firmly with the camera (directly) as it does with the adapter. The lock lever is a tiny bit stiffer when attaching the GP-E2 directly to the camera, but it does lock.
Larry
 Larry Cunningham's gear list:Larry Cunningham's gear list
Canon EOS M5 Canon EOS M3 Canon EOS M6 II Canon EOS R7 Canon EF 50mm F1.8 II +20 more
OP bullet1 Veteran Member • Posts: 7,339
Larry
Thank you for the reply.  I was scrared to push the locking lever too hard.  After reading your reply, I tried and it did lock after a firm press.  I can see the multifunction shoe is a bit longer than the old kind on my R so the rubber seal does not cover the whole shoe.
I wonder why Canon says the AD-E1 is required as if the GP-E2 won't fit or work without it.  Perhaps Canon should say it is only required to complete the weather seal.
Nelson
koenkooi Contributing Member • Posts: 919
This is exactly my experience with the R7 and GP-E2 as well.
 koenkooi's gear list:koenkooi's gear list
Canon EOS 7D Canon EOS M Canon EOS M6 II Canon EOS R5 Canon EF 85mm F1.8 USM +20 more
Bryan Conner
Bryan Conner Forum Member • Posts: 99
I can imagine that it is Canon trying to protect themselves from a user complaining that some type of weather related damage occured because they didn't use the AD-E1.  I suppose that using the AD-E1 is the safest way to mount the GP-E2...or maybe it is because Canon wants everyone to buy an extra piece of gear....and make a bit more profit.  Could be either or both.
Ravensburg, Germany
 Bryan Conner's gear list:Bryan Conner's gear list
Sony RX100 III Canon EOS R Canon EF 70-200mm F2.8L IS II USM Sigma 105mm F2.8 EX DG OS HSM Tamron SP 24-70mm F2.8 Di VC USD +1 more
