XH-1 Film Simulation Can't Change It. Help!
Started 3 weeks ago | Questions
Jazz1
Jazz1 Contributing Member • Posts: 757
I've had the XH-1 sometime, but never tried to change the the built-in film simulations.
Today under the menu system I go to IQ and scroll down to "Film Simulation" the film case tape is grey, and won't respond to a push. In fact I can't even stop the scroll to rest on the greyed out "Film Simulation" I also seeing "Grain Effect" greyed out, and several other selections.
Any ideas on how to change from STD, to say Provia?
Thanks for the help!
 Jazz1's gear list:Jazz1's gear list
Ricoh GR III Fujifilm X-H1 Fujifilm X-Pro3 Fujifilm XF 10-24mm F4 R OIS Fujifilm XF 50-140mm F2.8 +9 more
Erik Baumgartner Senior Member • Posts: 6,893
Re: XH-1 Film Simulation Can't Change It. Help!
Provia is STD.
How about a shot of the top dials and rear screen in normal shooting mode to see what's going on? Your drive ring setting is probably set to something like "ADV" instead of "S". That would do it.
Sony RX100 Fujifilm X100V Fujifilm X-T2 Fujifilm X-T20 Fujifilm XF 35mm F1.4 R +5 more
Yawlen Z
Yawlen Z Regular Member • Posts: 184
Looks like you could have some scene-preset mode engaged, or some filter mode. They're known to make filmsim choice impossible. Can you make sure these 'specials' are all off? By the way, the Std. film equals to Provia.
Jazz1
OP Jazz1 Contributing Member • Posts: 757
Provia is STD.
OMG, you were right. It was set on ADV. What the heck I should just go back to my Pentax ME.
Thank you all for the help! I guess I spend to much time with the XPro3 and need to spend more time with the XH-1 and it's manual!
