Medium Format class capture using the EOS R
Started 2 weeks ago | Discussions
Garry2306 Regular Member • Posts: 203
As many are aware, one of the big selling points of moving from a DSLR to a mirrorless camera body is that it opens up many adapter possibilities.
I thought some may be interested in my experiences, with both Canon R and M bodies.
In the following post I talk about capturing MF class 617 panos, as well as other formats, with the EOS R:
https://photography.grayheron.net/2023/03/flat-pano-stitching-with-eos-r.html
Bryan Conner
Bryan Conner Forum Member • Posts: 99
Re: Medium Format class capture using the EOS R
Very interesting.  What advantage do you see with using these older MF lenses as opposed to a modern RF mount lens?
I have dabbled with using older, legacy lenses with an adapter and found more modern lenses to be sharper and more contrasty.  But, I am not a video shooter and I understand about wanting that "vintage" look in video.
If I already had some MF lenses, I would certainly want to give this a go....but I don't have any and they are a bit expensive.
Ravensburg, Germany
 Bryan Conner's gear list:Bryan Conner's gear list
Sony RX100 III Canon EOS R Canon EF 70-200mm F2.8L IS II USM Sigma 105mm F2.8 EX DG OS HSM Tamron SP 24-70mm F2.8 Di VC USD +1 more
OP Garry2306 Regular Member • Posts: 203
The reason is obvious, :-), because it’s fun and it slows me down.
I’m a photographer and find that exploiting modern software, eg PureRAW 2 and/or Topaz Photo AI, I can get pretty good results.
I have 35mm, 45mm and 150mm Mamiya lenses, but tend not to use the 35mm, as my copy exhibits poor IQ at the edges, especially on the left side.
As you will see from my blog, I get enjoyment from the technical side of photography, so gadgets are fun
Bryan Conner
I can understand the aspect of doing it because it is fun.  I also love testing stuff and comparing.  I have a word document on my pc with where I have tested all 12 of my sd cards in my EOS R.  I have the format time, time to empty the buffer, as well as read and write speed with each of my 5+ card readers.  I also have similar information for my rechargeable AA batteries...tested m/aH date bought etc.  I test them periodically just to see if they are still performing.  I could do this kind of stuff all day...lol.
So getting one of these adaptors would be a no brainer for me if I already had lenses.  But, unfortunately the only MF cameras I have ever owned were TLRs, a Mamiya C220 and a Yaschica MAT124G.  I don't think there would be an adapter for Mamiya C lenses if I still had any lenses.....:-D
Ravensburg, Germany
robgendreau Forum Pro • Posts: 10,917
Nice results. Have you tried Fotodiox's RhinoCam Vertex adapters? they rotate a 645 lens four times to get a very large image when stitched. Sort of like the Rokr, but vertical too.
 robgendreau's gear list:robgendreau's gear list
Pentax 645Z
Yes, I’ve got two of those
One for Mamiya to EOS R and one for EOS to EOS M.
Great fun.
Great fun.
Cool. I thought they were brilliant ideas.
And having used he TS Rokr with my 645 lenses, I think it's a better solution than the old TS lens I used way back when. Just wish it had a tripod shoe.
Pentax 645Z
”Just wish it had a tripod shoe.”
I agree, a wasted opportunity.
