Best flash for R System
Started 2 weeks ago | Discussions
Franz Weber
Franz Weber Contributing Member • Posts: 675
Hi all,
I am trying to find out which is the best flash solution for indoor portraits in the Canon R System. I would like to have a small master flash for catchlights and a powerful slave for bouncing. Currently I am contemplating these options:
  • 470 Ex: Pro: self adjusting head. But why was it discontinued by Canon?
  • 430 Rt as a master. Is it any good?
  • El-5: Pro: Lithium battery, powerful. Con: no optical slave functionality, why?
  • El-100: Pro: smallest Canon flash, Con: no RF Master functionality
  • Godox Flashes: are they comparable to the Canon ?
What would you recommend?
This column is intended for something inspiring, something meaningful or at least something that makes any sense at all. I‘ll work on it.
 Franz Weber's gear list:Franz Weber's gear list
Olympus OM-D E-M10 IV Nikon Z6 II Olympus M.Zuiko Digital 45mm F1.8 Nikon Z 50mm F1.8 Olympus 12-45mm F4 Pro +5 more
Franz Weber
OP Franz Weber Contributing Member • Posts: 675
Re: Best flash for R System
Another option:
Would the inbuilt flash of the r10 give good results in conjunction with an optical slave flash?
CamerEyes Regular Member • Posts: 266
Franz Weber wrote:
Hi all,
I've been using the small EL-100 to trigger my 580EXii and my 470EX. It works like a charm. The advantage of this set up is I often only have the EL-100 in my regular camera bag because it's so small.
Heard good reviews about Godox. I just got used to Canon Speedlites which is why I never tried Godox.
 CamerEyes's gear list:CamerEyes's gear list
Sony a7C Canon EOS R7 Canon EOS R6 Mark II Canon EF 50mm f/1.2L USM Canon EF 50mm F1.4 USM +12 more
Rock and Rollei Senior Member • Posts: 2,902
Why was the 470 discontinued? Too expensive at the original price, probably no profit at the revised price.
But I love it, to be honest, tends to be the gun I use when I'm not using studio flash.
 Rock and Rollei's gear list:Rock and Rollei's gear list
Canon EOS 5DS R Canon EOS 5D Mark IV Canon EOS R Canon EOS M6 II Canon EF 50mm f/1.2L USM +29 more
Same with me. I end up picking it up versus my 580EXii and 430EXii when I need a bigger flash. It's seamless to use with RF bodies.
Franz Weber
Thanks both of you! - nt!
davidwien Contributing Member • Posts: 572
I havent used flash since I moved to the RP and R6. Low light scenes are easily coped with and any noise can be removed with Photolab.
David
 davidwien's gear list:davidwien's gear list
Sony RX100 VA Canon EOS RP Canon EOS R6 Canon EF 17-40mm f/4.0L USM Canon EF 70-300mm f/4-5.6 IS USM +6 more
mojorisn Regular Member • Posts: 459
I like using my tiny Speedlite 90EX as a master for my larger Speedlites.
 mojorisn's gear list:mojorisn's gear list
Canon EOS R Canon EOS R5 Rokinon 14mm F2.8 IF ED MC Canon EF 16-35mm F4L IS USM Canon RF 35mm F1.8 IS STM Macro +7 more
SteveinLouisville
SteveinLouisville Senior Member • Posts: 1,586
Godox wireless system.
The Godox wireless system works well with my RP.
 SteveinLouisville's gear list:SteveinLouisville's gear list
Canon EOS RP Canon EOS R7 Canon EF 17-40mm f/4.0L USM Canon EF 40mm f/2.8 STM Canon EF-S 24mm F2.8 STM +9 more
