Which Ultra Wide angle for Fuji?
Started 3 weeks ago | Polls
ms18
ms18 Veteran Member • Posts: 3,530
Currently I have XF 14mm and I feel it's not wide enough for my architectural shots.. I'm mostly shooting Hindu temples and forts . Also some religious festivals where i want to exaggerate things.
I also have XF 23mm which i use for general purpose.
I will be selling XF 14mm and planning to buy one of the below ultra wide angle lens.
So far I heard Laowa is lighter and NiSI is better quality.  Is that true? I would prefer lightweight If that does not degrade quality much.
New Tamron also seems to be light weight. While having zoom is good I will be shooting at 11mm most of the time any way.  How it will compare with above primes?  I don't want to compromise in Wide end IQ and light weight.
Please suggest me one.
 ms18's gear list:ms18's gear list
Fujifilm X-T20 Fujifilm XF 14mm F2.8 R Fujifilm XF 23mm F1.4 R Fujifilm XF 56mm F1.2 R +1 more
POLL
Laowa 9mm f/2.8
33.3% 5  votes
NiSi 9mm F2.8
0.0% 0  votes
Tamron 11-20mm F2.8
66.7% 10  votes
  Show results
Andreasfe Regular Member • Posts: 229
Re: Which Ultra Wide angle for Fuji?
5
I would probably wait a bit. Fujifilm has announced development of a quite compact 8mm f/3.5, that will be released this year. Hopefully at the next X-Summit in April.
 Andreasfe's gear list:Andreasfe's gear list
Fujifilm X100V Sony ZV-1 Fujifilm X-T5 Fujifilm XF 35mm F1.4 R Fujifilm XF 18mm F1.4 R LM WR +1 more
Rod McD Veteran Member • Posts: 8,589
Hi,
Why sell the 14mm - a good lens for architectural uses -  rather than keep both your 14mm and 23mm and ADD a wider lens?  Otherwise your step from 9mm to 23mm will be huge.  You will surely encounter situations where you will need something between the two?
Regards, Rod
 Rod McD's gear list:Rod McD's gear list
Fujifilm X-T4 Voigtlander 90mm F3.5 APO-Lanthar SL II Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 18-55mm F2.8-4 R LM OIS +13 more
Rightsaidfred
Rightsaidfred Senior Member • Posts: 2,179
2 important lenses missing
Two important lenses missing in your list.
  • Viltrox 13/1.4, gets many good opinions, I have it, too, and am very happy
  • Fujifilm XF 8/3.5, will be announced soon
Fujifilm wide angle zoom lenses are also missing. At least the XF 8-16.
Martin
 Rightsaidfred's gear list:Rightsaidfred's gear list
Fujifilm X-T20 Fujifilm X-T4 Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS +5 more
ms18
OP ms18 Veteran Member • Posts: 3,530
I'm not going to sell immediately. I will see and will sell only if I'm sure I don't need that focal length. I also have an idea to get 16mm if I feel that gap
ms18
Re: 2 important lenses missing
It's a spectacular lens. But I need wider considering I already gave 14mm.
It's very interesting. But I have used 9mm and fine with it. But scared to go even wider without testing it first. Also f/3.5 need to be released first too see how sharp it is wide open.
Not many choice. It's heavy for me
sir_c Contributing Member • Posts: 740
9
For wide shots of architecture i suppose the xf 10-24 could do a good job as well. The OIS is a nice benefit if your can't use a tripod.
 sir_c's gear list:sir_c's gear list
Fujifilm X-T1 Fujifilm X-T4 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R Fujifilm XF 18-55mm F2.8-4 R LM OIS +5 more
White-collar
White-collar Regular Member • Posts: 147
The xf 8-16 is heavy but it's an amazing lens.
 White-collar's gear list:White-collar's gear list
Fujifilm X-T4 Fujifilm XF 50-140mm F2.8 Fujifilm 16-55mm F2.8R LM WR Fujifilm XF 8-16mm F2.8 Fujifilm XF 50mm F1.0 R WR +11 more
Morris0
Morris0 Forum Pro • Posts: 32,175
If you go for a zoom, you may be able to carry just the zoom or the zoom and one very light prime. The resulting weight can be about the same as multiple primes and more convenient. The XF 10-24 f4 is another option and while some find it soft in the corners, it might not matter for your applications and/or at the apertures you use. If you can rent, borrow or purchase with an option to return I suggest you try both zooms. Waiting for an anticipated lens release could leave you waiting for a long time and there is no guarantee we will ever see the new lens.
Morris
Fujifilm X-T3 Fujifilm X-H2S Canon EF 200mm f/2.8L II USM Nikon AF-S Teleconverter TC-17E II XF 90mm +11 more
a_c_skinner Forum Pro • Posts: 13,047
I'm a new owner of the Fuji 10-24 and I'm struck by how good and useful it is in a fairly small package.  At f5.6 I'm hard pressed to see a difference from the 14/2.8, which I will be selling.
Andrew Skinner
Fujifilm X-T2 Fujifilm X-E3 Fujifilm X-H2 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R +7 more
britcam
britcam Senior Member • Posts: 2,583
I am an historic buildings Architect and have been shooting buildings in France and the UK for many years, both internally and externally.
Internally, lighting conditions vary enormously, and for adequate DOF I often used a small aperture with the camera mounted on a tripod. The ability to minimize CA is also vital, which was one of the reasons I moved from Pentax to Fuji back in 2015. I bought the XE2 then and soon after, the XM1 for its tilting screen. I also bought the Fuji 10-24 zoom specifically for architectural work.
When mounted and set up on a tripod, and swiveling round to frame different shots, the ability to zoom is incredibly useful.
I never felt the need to go wider than the 10mm, so rather than the primes that you mention, I would simply get the Fuji 10-24 and if you don't have an IBIS body, then the Fuji wins again with its OIS.
Rich S
 britcam's gear list:britcam's gear list
Fujifilm X-E2 Fujifilm X-M1 Fujifilm X-S10 Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro +8 more
ms18
You mean 10-24 has the same IQ at f/5.6 similar to XF 14mm shot at f/5.6?
Other question is, Can you tell me about the IQ of 10-24mm when using 10mm wide focal length wide open ie f/4?
ms18
I felt i should go wider than my XF 14mm for the exaugurated depth.  I found it's working well with 9mm. I tested it!  I don't think i need wider than that. But i definitely want wider than 11mm to get that effect.
21William Contributing Member • Posts: 866
I’ve got the 10-24 as well and it’s a lot smaller than my old, admittedly wider 8-16 Sigma that I bought for my Pentax. It also accepts filters which is nice.
 21William's gear list:21William's gear list
Pentax K-5 Fujifilm X-H1 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 10-24mm F4 R OIS
Yes
Not any more than saying it seems OK stopped down a bit but I usually want a bit more DoF that you get at f4.  All in all it seems OK.
Andrew Skinner
Oregon Dawg
Oregon Dawg Contributing Member • Posts: 846
For me, I'd get the Fuji 10-24 and keep the 14.  I like the flexibility of zooms for wide and telephoto.  (But this is just me, we're all different.  I like the idea of carrying both a zoom and a prime).
Good luck with your decision!
 Oregon Dawg's gear list:Oregon Dawg's gear list
Fujifilm X-T4 Fujifilm XF 16-80mm F4 Fujifilm XF 70-300 F4-5.6 R LM OIS WR Fujifilm XF 33mm F1.4 R LM WR Apple iPhone 11 Pro
ms18
This is what I want to achieve.
Taken by wide angle camera of Samsung galaxy M33 smartphone
The wide angle camera in my mobile is equivalent of 13mm in full frame format.
My XF14mm which has equivalence of 21mm would not bring this drama to my shots. I want drama in my pictures not reality. I'm extremely satisfied with the result coming with my smartphone wide angle lens except the image quality. I had another budget smartphone which also had similar UWA camera with 13mm view. I liked it but not image quality.
I want high quality RAW files in same type of dramatic depiction of things.
XF14 while being excellent lens of it's own does not give this drama. I might still keep XF 14mm after purchasing one of this UWA. But What i need is this drama and able to include all of the scene.
Oregon Dawg
Re: This is what I want to achieve.
Looks like you should wait for the Fuji 8mm f/3.5.
(Unless you think 10mm would be wide enough, then the Fuji 10-24 might still work and give you some versatility)
Jeff Biscuits Senior Member • Posts: 1,166
5
Oddly enough that’s precisely how I’ve been using my recently acquired (used) 10-24 today.
The first time I bought one I quickly decided it was too bulky for urban use and I returned it. This time I got it primarily for rural landscapes but it turns out it’s really not that bulky after all (at least once you leave the hood at home). Plus, with the internal zoom meaning I’m not constantly shrinking the lens back to the wide end when I stop shooting, it’s like having a 10 for architecture and a 24 for street both fitted at once.
 Jeff Biscuits's gear list:Jeff Biscuits's gear list
Ricoh GR Digital II Ricoh GR Digital IV Fujifilm X20 Fujifilm XF10 Ricoh GR IIIx +14 more
ms18
yES. Just worried that 8mm may be very wide which i can't handle. But yes there couldn't be much different between 12mm and 13.5mm (full frame equivalence.)
Not much in to that lens. Not just just because it's look large but I will be any way using it on 10mm. So why buy a zoom. Second it's f/4. It has OIS but i might take photos with things moving such as people or moving plant foliage's / stems.
