Canon R5 -using EF lenses?
Started 3 weeks ago | Discussions
fairfaxian Regular Member • Posts: 396
Hey fellow Canon shooters-
My world changed with the Canon R5. I adorned it with the Canon 15-35 2.8 RF, 100mm 2.8 Macro RF, and my main lens (for wildlife) the Sigma 500mm F4.
The sigma is excellent, but the 2 RF lenses are outstanding!
I have an opportunity to cover an important outdoor event, where I would have used my older 24-70 2.8, & 70-200 2.8 -both EF L lenses.
Anyone using EF lenses on an R5? I don't use them much now, but compared to the RF lenses, they seem soft. The 70-200 was a reliable workhorse for me in the past. But wide open it was always soft. The focal range is perfect for events. I won't be paid enough to buy new glass right now. (I could rent if necessary) Just asking for opinions from other shooters with the same gear.
Thanks.
Canon EOS R5
koenkooi Contributing Member • Posts: 920
Re: Canon R5 -using EF lenses?
My EF180L is still delivering sharp pictures and also doesn’t have an RF equivalent yet. Same for the MP-E65mm
 koenkooi's gear list:koenkooi's gear list
Canon EOS 7D Canon EOS M Canon EOS M6 II Canon EOS R5 Canon EF 85mm F1.8 USM +20 more
VisuallyOriented Regular Member • Posts: 425
I'm just switching to Canon; received my R5 yesterday so I have no personal experience with either the EF or RF versions of the 70-200 f2.8. But I have been intensely researching new lenses. Here are 2 reviews from what I consider reliable sources who both say optically the new RF model is about the same as the last EF version- both very good. They say the RF version does have advantages over the EF (weight, length) disadvantages (cost) but image quality is about the same.
https://www.youtube.com/watch?v=_cWsGjdqUnI
https://www.youtube.com/watch?v=wGYQQ2wI1JQ
drsnoopy Senior Member • Posts: 1,216
Thanks.
Your EF 70-20/2.8L lens will work just fine, but won’t magically be improved optically. If it was soft on a dSLR it won’t be any better unless that softness was due to autofocus errors, which would be eliminated with a mirrorless body. Also - do you need to shoot at f2.8? You could happily use f4 for better sharpness at higher ISO using your R5, and get great results. My own experience was with the 70-200 f4 L IS, which performed just as well on my R as on my 5D4. I now have a R5 with the RF 70-200 f4L, and it is better than the EF, but only by a small margin.
 drsnoopy's gear list:drsnoopy's gear list
Canon EOS RP Canon EOS R5 Canon EOS R10 Canon EF 100mm F2.8L Macro IS USM Canon RF 35mm F1.8 IS STM Macro +10 more
cfieldgate Regular Member • Posts: 475
I’m fine with the EF lenses I have now which work great on both my cameras (R3 and 1DX II). They are a little nicer / better on the R3, bar the adapter “hassle” (which I’m now used to), and with the advantage of no micro-adjust to have to mess with.
That said, the original EF 24-70 was never my favourite lens, hence I upgraded to the II version which is much sharper and has more reliable AF than my copy. The internal zoom of the original was clever though.
I also used to have the EF 70-200 IS and really only replaced it with the II due to age. Although again the IQ was a little better.
As for advice, I’d take them along to the gig if I were you and see for yourself. I doubt anyone will complain about the results - us photographers are generally the critical ones!
 cfieldgate's gear list:cfieldgate's gear list
Canon EOS-1D X Mark II Canon EOS R3 Canon EF 100mm f/2.8 Macro USM Canon EF 70-200mm F2.8L IS II USM Canon EF 300mm f/2.8L IS II USM +6 more
Abbott Schindler Veteran Member • Posts: 3,099
There are a number of threads on this subject; just search for something like "ef lens on rf camera".
I've got a number of EF lenses and all work better on my R5's than they did on any of my DSLRs, including the 5D Mark 4 and 5Ds R. In all cases, AF is noticeably faster and seems more accurate. For your upcoming event, rather than worry about using the EF lens (be sure to use a Canon EF-RF adapter; doesn't matter which one), study up on the AF modes. You'll likely want to configure Back Button Focus (I use dual BBF; some people I know use 3 buttons).
Your lenses should be fine. I bought the RF 24-105L only so I'd have a native normal zoom range lens for the R5. I also have the EF 24-105L for my DSLRs. I find them about the same. The RF is a little sharper at one end; the EF's sharper at the other. I prefer the EF's ring layout.
As previously mentioned, Canon hasn't (yet?) come out with updated versions of either the 180L or MP-E65 macros, both of which are pretty old designs, yet both work just fine on the R5. The 180L's the only EF I have that I'd consider replacing. I'm not doing massive EF lens replacements. So far I have 3 RF lenses, all of which do more than the EFs I had. 100-500 is more useful for me than 100-400; the 14-35 is more useful for me than the EF 16-35 (better zoom range, much lighter, more compact, but needs more work in post to compensate for optical shortcomings).
Since you already own the lenses you're thinking of using, just use them! I'm sure you'll be satisfied with the results. If you decide to replace any of them, I'd suggest considering the f/4 versions unless you really need f/2.8 for DoF reasons. In DSLRs, faster lenses had the added benefit of providing a brighter viewfinder view, but that advantage is gone with the R5. Also, the R5's high ISO performance means I don't need to open up as much, and I typically want greater DoF anyway, so rarely shoot at faster than f/5.6.
Really, though, the best advice is to use what you have and then decide if it works for you...unless you're particularly eager to part with a lot of money.
OP fairfaxian Regular Member • Posts: 396
Thanks for the good advice below -and to the others who have replied.
A local pal pointed out that having 2 cameras at a race event is critical. So bringing my 7DII for the longer lens shots, and using the R5 with the 15-35RF would probably be the best approach.
I am addicted to low light/golden hour shooting. And prefer faster lenses when possible.
expro Senior Member • Posts: 2,273
I would switch this as the r5 has much better af which will be important with longer lenses?
 expro's gear list:expro's gear list
Canon EOS R3 Canon RF 24-70mm F2.8L IS USM Canon RF 70-200mm F2.8L IS USM Canon RF 100-500mm F4.5-7.1L IS USM Canon RF 14-35mm F4L IS USM
