R6II AND LOW LIGHT EVENTS - FEEDBACK?
Started 3 weeks ago | Discussions
rp2waiter Regular Member • Posts: 128
Anyone here have feedback on low light/  niteclub work and the focusing of the R6ii? I'm doubtful if eye AF would work, but we'll see.
CamerEyes Regular Member • Posts: 266
Re: R6II AND LOW LIGHT EVENTS - FEEDBACK?
My own observation is that lowlight focusing of the R6Mii is just as good as the R6. Largely depending on the lenses you use, of course. Brighter lenses (1.8-2.8) no problem, yes even in lowlight. It's a different story when you're using 4.0-5.6 lenses, as I personally experienced when using my RF15-30mm.
 CamerEyes's gear list:CamerEyes's gear list
Sony a7C Canon EOS R7 Canon EOS R6 Mark II Canon EF 50mm f/1.2L USM Canon EF 50mm F1.4 USM +12 more
R2D2 Forum Pro • Posts: 26,536
Start by turning “Display Simulation” (for Exposure) OFF in dark environments. AF improves!  Also don’t underexpose, and improve the brightness by turning ISO up (and processing RAWs in DxO Photolab 6).
Best of luck!
R2
catastrophe Regular Member • Posts: 161
Here is one from Friday night
F2.8 s/s 1/200 iso 25600 raw into C1, default C1 settings then export to jpeg without editing. Eye and people detect, center point to pick up subject and then track to frame
If you are having problems, let us see some problem images and the parameters used.
