Why is tone-curve greyed out in in-camera raw conversion menu?
Started 3 weeks ago | Discussions
lensfungus Regular Member • Posts: 190
Hi,
Probably something simple, but I can't figure out what I'm doing wrong.
If I choose an image in the playback menu and go to raw conversion, the tone-curve setting is greyed out and not selectable. This is an X-E4 and the image is definitely raw, not jpeg
Anyone able to shed any light please?
sprouty115
sprouty115 Contributing Member • Posts: 618
Re: Why is tone-curve greyed out in in-camera raw conversion menu?
Was the image shot with an X-E4?
As an example X-RAW will not process an image shot with an X-E3 with and X-E4 connected to the computer.  You'll still see the image in X-RAW, but you won't be able to edit it.
 sprouty115's gear list:sprouty115's gear list
Ricoh GR III
OP lensfungus Regular Member • Posts: 190
This is the in-camera raw conversion, but you may be onto something. This card was used in an X-E3 previously, I wonder if I need to format it in the X-E4 maybe? Worth a try anyway.
sprouty115
Ah sorry, somehow thought you were using X-RAW.  But post back again if the formatting fixes the issue.
Ricoh GR III
Greybeard2017
Greybeard2017 Veteran Member • Posts: 3,112
lensfungus wrote:
Hi,
You have a conflicting setting - likely D Range Priority set to something other than off
 Greybeard2017's gear list:Greybeard2017's gear list
Fujifilm X-T30 Fujifilm X-S10 Fujifilm X-H2S
Greybeard2017 wrote:
lensfungus wrote:
Hi,
This was the problem. Thanks!
JNR
JNR Veteran Member • Posts: 4,652
lensfungus wrote:
Hi,
Either way, you should format the card in-camera every time after you have saved something on the card from another device (camera, computer, etc.).
JNR
 JNR's gear list:JNR's gear list
Fujifilm X-T2 Fujifilm 50mm F2 R WR Phase One Capture One Pro Pentax K-01 Pentax K-3 +22 more
