Canon EOS RP RAW editing flexibility?
Started 3 weeks ago | Discussions
Quarkcharmed
Quarkcharmed Senior Member • Posts: 2,713
Re: Canon EOS RP RAW editing flexibility?
Sgt_Strider wrote:
dpfan32 wrote:
You have visible noise, when you lift the shadows too heavy. Look at my example above
I apologize if I'm being rude, but we're not even talking about lifting shadows as there is universal agreement that there is noise. What we are talking about is exposing to the right or at least getting the exposure right and then dialing back the settings like exposure. The consensus thus far is that noise won't be an issue in this scenario?
The noise may become an issue depending on how much dynamic range you need for the given scenery and how that compares to the dynamic range of the camera.
Higher dynamic range of your camera means you need to do less exposure blending/HDR. The camera covers greater range of contrasty scenes in one shot.
 Quarkcharmed's gear list:Quarkcharmed's gear list
Canon EOS R5 Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM Canon EF 50mm F1.8 STM
OP Sgt_Strider Senior Member • Posts: 2,674
Quarkcharmed wrote:
Sgt_Strider wrote:
jboyer wrote:
Sgt_Strider wrote:
jboyer wrote:
Sgt_Strider wrote:
jboyer wrote:
I have an RP since its launch (eons ago?). The exposure is the key. 'Well' exposed pictures -- requiring minimal boosting of the dark areas, will come clean of noise at high ISO values. I shoot RAW and use Capture One as my RAW processor. I came from a 7D and a 6D.
This issue is mostly related in the need to get better rendition of dark areas, like backlit pictures. A bit of over exposure may go a long way. As one poster noted, this issue may not really exist, and the Canon colors are worth the potential problems.
And today, the issue of noise is non sequitur with tools like Topaz AI.
After 1000s of RP pictures, I still feel it is a very decent and useable camera. Sill the most affordable Full Frame, with all the pros and cons of the format.
But it is an entry level body and if budget is no object, a R6 II may serve you better in the longer term. At three times the price.
Even right now I tend to expose to the right. I'm assuming that what you mean is I can reduce the exposure and not have to lift any shadows to keep noise to the bare minimum?
Yes. If short of light, increasing the ISO may also work.
Apparently, I'm better off shooting ISO6400 rather than shooting ISO800 and boosting it by two or three stops?
It really depends on what you are shooting. There are a few 'methods' to increase the perceived DR. Bracketing, using higher ISO and 'overexpose' (assuming your RAW processor is good at recovery of highlights), HDR in camera, etc.
And sometimes, noise is simply OK. It may hurt in a deep blue sky or muddy some grass. The final image may be great, no matter what.
At the RP price point, you get a pretty serviceable camera.
I'm sort of confused about how noise could be an issue. If I expose it to the right and start lowering the exposure, what would be causing the noise? I can understand if I'm increasing the exposure during post-processing or shooting in high ISO, but if I expose to the right at base ISO?
If you shoot landscapes and properly use ETTR (exposure-to-the-right) with your RP, you may get good results comparable to someone who doesn't use ETTR with an R or even R5. Although you'd get much better results had you used an R5 with ETTR.
Lowering 'exposure' in Lightroom after ETTR doesn't increase visible noise. Sitting at base ISO and using ETTR is the way to squeeze the possible dynamic range out of your camera.
But if you can't use ETTR (say because it's too dark or you can't use long enough shutter speed), yes you'd better use higher ISO 3200 right in the camera rather than ISO 800 plus 2-stop exposure lifting in Lightroom. That's because the RP is not 'ISO-invariant'.
Thank you! That's what I was asking!
I have to admit, I'm still confused with the ISO-invariant terminology.
I'm also aware that the R and the R5 have superior sensors. I'm just trying to understand how to extract every possible performance out of the RP sensor.
I mainly shoot on a tripod. Can't I just go on bulb? How well does the RP handle long exposure noise when shooting at base ISO?
danferrin Contributing Member • Posts: 730
dpfan32 wrote:
This is the image I shot
Unedited
You want to see the ugly noise?
Lights 100% down and Shadow 100% up in Lightroom
This is a Sony A7 photo
Lights 100% down and Shadow 100% up in Lightroom + 1EV Exposure on top needed.
So if you want to do this type of shots you better bracket or buy a Nikon camera!
Your Sony ICLE-7 does have a couple of steps better DR at base ISO than the RP.  But, the Canon EOS R5 and R62 both have a bit more DR than either the Nikon Z72 or Z9, according to the dynamic range charts at Photons to Photos, so I don’t think the OP needs to move to Nikon in order to get those kind of shots.  The new EOS R8 has the same sensor as the R62, and therefore should do really well in low light and in high contrast scenes.
My life is a circle of confusion - photography is my meditation.
See my work at http://www.danferrinphotography.com
 danferrin's gear list:danferrin's gear list
Canon EOS 60D Canon EOS 7D Mark II Canon EOS RP Canon EOS R5 Canon EOS R7 +20 more
Quarkcharmed
  • Sgt_Strider wrote:
  • If you shoot landscapes and properly use ETTR (exposure-to-the-right) with your RP, you may get good results comparable to someone who doesn't use ETTR with an R or even R5. Although you'd get much better results had you used an R5 with ETTR.
  • Thank you! That's what I was asking!
  • I have to admit, I'm still confused with the ISO-invariant terminology.
So called ISO-invariance is just as described above: your shots at some high ISO have the same visible noise as shots taken at lower ISO plus 'exposure' lifted by corresponding amount in a photo editor.
The R5 is practically ISO-invariant from ISO 800, but the RP is never ISO-invariant:
https://www.photonstophotos.net/Charts/PDR_Shadow.htm#Canon%20EOS%20R5,Canon%20EOS%20RP
The invariance starts where the graph goes flat which unfortunately is never for the RP.
That means, with an RP, it's best to lift the ISO in camera. However note the dynamic range generally reduces by 1 stop when you raise the ISO by 1 stop.
That's a bit different from what those charts may show. When shooting long exposure you may get non-random thermal noise, plus hot pixels. Tbh I haven't seen long exposure comparisons across different cameras. But I guess the RP shouldn't be too bad in that regard - you may do your own tests to see if it provides satisfying results.
With a sensor that is ISO-invariant, you can shoot at ISO 100 and increase the exposure by say four stops, and the resulting file will be identical to the file you would shoot at ISO 1600.  So technically, you could leave your camera ISO at 100, and make all your exposure adjustments in post processing, and the results would be the same as if you had set the camera to the appropriate ISO at the time you took the shot.
Quarkcharmed
ISO 100 is a bad example. Most of the modern cameras (Canon, Nikon, Sony, Fuji) are ISO-invariant from about ISO 640-800.
Above I've posted a link to Photonstophotos chart where you can check ISO invariance range for your camera.
Fjzk Regular Member • Posts: 220
So the RP, per that chart, is ISO invariant at base ISO and then from 300-400 onwards it is better to just raise the ISO versus underexposing and recovering in post? Am I reading this right?
 Fjzk's gear list:Fjzk's gear list
Canon EOS M50 Canon EOS RP Canon EOS M6 II Canon EF-M 22mm f/2 STM Canon EF-M 11-22mm f/4-5.6 IS STM +8 more
Quarkcharmed
Per that chart, the RP is nowhere ISO-invariant for practical use.
You can see flat groups like ISO 100-120*, then 160-200-250 etc. - that's because the camera uses digital gain (multiplication) between those ISO values, which is the same as digital 'exposure' slider in a raw photo editor. But it's not practical to use ISO-invariance within such short ranges covering less than a stop. You might as well make the camera use 1-stop increments for ISO, instead of default 1/3-stop increments.
* ISO 50 is marked as extended ISO in that chart (and in the camera manual) - in practice that means the raw data at ISO will be the same as ISO 100, just different ISO tag and middle grey point. So ISO 50 doesn't really help invariance.
dpfan32 Regular Member • Posts: 258
Yeah this was an interesting point.
ISO 50 setting make a +1EV overexposure right?
In connection to ETTR. When you hint the right side of the Histogram this doesn't mean that it's the end.
This only means that this is the last point where the JPEG wouldn't blow out!
The RAW file can handle up to 2 EV overexposure, I read somewhere.
The reason I actually shot at some point wit ISO 50 on my EOS 6D Mark II was actually a EOS RP review I watched on YouTube, where the reviewer showed, that the ISO 50 setting had much less noise in the shadows that ISO 100!
Of course he didn't shoot a high dynamic range scene.
The result had been the same if he overexposed the ISO 100 RAW 1 stop while shooting and made the image darker afterwards.
Am I right?
But this is IMHO a good practice for ETTR:
The EOS RP can handle 1 EV overexposure with ease and it can bring back the according to the histogram overexposed  highlights in Lightroom without clipping.
So instead of trying to click 3 times on the exposure to match this +1EV I can remember I  just uses ISO 50 (the 6D Mark II has the same sensor as the EOS RP) and then made the exact ETTR on my histogram.
The results were not overblown afterwards.
I just forgot about this technique and didn't practice is on my RP for actually no reason... I just forgot ... maybe I had too much gear in the meantime ^^ Canon EOS R, Olympus, Sony, Fuji, Nikon... Oh my... ^^
But yeas I still use the RP an my main camera and please tell me if my thoughts are correct about the ISO 50 with the ETTR I did at some point or did I misunderstood this ISO 50 thing
Quarkcharmed
Well in Canon cameras the extended ISO 50 introduces a metering bias, which effectively makes the camera overexpose compared to the same metering mode at ISO 100 (note that 'overexposure' is relative to the current metering mode, no more no less).
Yes, that's why you might want to use something like UniWB (so called universal white balance) if you really want to maximise the DR of your camera.
The question is, this overexposure - it's 'over' against what exactly? If you're on standard evaluative metering, you may already be blowing out some highlights because metering makes mistakes, so overexposing +2 ev against evaluative metering can easily make things much worse.
If you don't want to go for all the hassle with UniWB, there's another simple technique to ETTR: use spot metering on the brightest part of the scene (e.g. white clouds), then use exposure compensation of +3 stops (the exact amount has to be tested with your particular camera). This may bring you pretty close to ETTR. Unfortunately, with Canon cameras, spot metering is bound to the dead centre of the frame, which means you'll have to recompose every time you change the exposure, which makes this method impractical if you're shooting from a tripod.
Another method - use RGB histogram and ignore red and blue channels, ETTR by the green channel only (suggested by Iliah Borg IIRC). Again, unlike UniWB, it's not 100% reliable, but it may work in many daytime situations.
Am I right?
Yes.
In my opinion, no, shooting at extended ISO 50 is not ETTR. There was a similar very interesting debate on DPR recently, I don't remember who it was with exactly.
So the issue is, as above, that with ISO 50 you effectively use a constant metering bias against your current metering mode, and it doesn't guarantee you're getting a constant 2.5-stop headroom. And even when you are, you're still 1.5 stops away from the 'ideal' ETTR.
I'm not sure about the RP, but in the R5 the histogram may be showing no clipping at ISO 50 but you actually get clipped highlights in raw.
Yes in many cases ISO 50 brings you 1 stop closer to 'ideal' ETTR, but it's not very reliable so occasionally you will be getting blown out shots.
koenkooi Contributing Member • Posts: 920
Quarkcharmed wrote: [...]
If you don't want to go for all the hassle with UniWB, there's another simple technique to ETTR: use spot metering on the brightest part of the scene (e.g. white clouds), then use exposure compensation of +3 stops (the exact amount has to be tested with your particular camera). This may bring you pretty close to ETTR. Unfortunately, with Canon cameras, spot metering is bound to the dead centre of the frame, [...]
On 1-series bodies you do get AF-point-linked-spot-metering. And only on 1-series bodies, the R3 lacks it as well.
 koenkooi's gear list:koenkooi's gear list
Canon EOS 7D Canon EOS M Canon EOS M6 II Canon EOS R5 Canon EF 85mm F1.8 USM +20 more
Quarkcharmed
Which I don't understand, it would be so easy to implement in mirrorless.
