Canon EOS RP RAW editing flexibility?
Started 3 weeks ago | Discussions
Sgt_Strider Senior Member • Posts: 2,674
After reading DPR's review, it seems like the RAW files have limited editing flexibility. Does that mean I need to get the exposure, right? Would you guys say, I can push the files 1-2 stops before noise becomes problematic?
drsnoopy Senior Member • Posts: 1,216
Re: Canon EOS RP RAW editing flexibility?
6
The RP sensor (similar to 6D mk2) gets a lot of unjustified criticism. Certainly it has a little less dynamic range (only at low ISOs) but in the real world this matters very little. I have an R5 and RP, before that I had 5D4 and 6D2. All can have considerable highlight or shadow recovery. The RP RAW files can easily stand a lot more than +/- 2 stops. Especially if you use appropriate techniques to control noise in your RAW processor - my preference is to use DXO Photolab or PureRaw. Remember that the DR of a raw image is far greater than anything you can display or print, and yes, it is always a good idea to “get the exposure right” - which depends on what you are capturing, not necessarily the auto exposure.  In very high dynamic range lighting conditions you can use exposure bracketing, which applies to all cameras and sensors.
 drsnoopy's gear list:drsnoopy's gear list
Canon EOS RP Canon EOS R5 Canon EOS R10 Canon EF 100mm F2.8L Macro IS USM Canon RF 35mm F1.8 IS STM Macro +10 more
dpfan32 Regular Member • Posts: 258
Yes I can assure you the EOS RP files are more problematic in terms of dynamic range than lets say the EOS R files.
I own both cameras and owned several Sony A7 cameras as well.
Is it always a problem?
No.
Because I shoot landscapes with big dynamic range with exposure bracketing anyway. So there is no difference left even to cameras with even more dynamic range like the Sony A7 and A7r and the Mark II versions of them which I had. But the color science on the Sony cameras was to my eyes awful.
Do you shoot backlit portraits?
There will be a problem lighting up the person in post processing the you shoot to preserve the background sky. But you should use a flash anyway in this situation.
I will post an old link to a photo from the dpreview Canon EOS 6D Mark II review, which is said to have the same or similar 26 megapixels sensor to show you what I mean.
Look at the first picture of the two nice people with the cute dog:
https://www.dpreview.com/reviews/canon-eos-6d-mark-ii-review/3
So there is a problem with noise on the 3 main subjects.
I could post a link to a German forum where a Canon representative Gregor Zajac took this dpreview picture and edited it with Lightroom and it looked much better than what dpreview did ^^ Sorry for that... ^^
But the links to the Canon Irista pictures, where he showed the screenshots from the settings and the final picture edited are gone for good. Canon took down Irista at some point.
This is the link anyway: https://www.dforum.net/entry.php?10-EOS-6D-Mark-II
Maybe you can run a google translator from German to English.
But I can tell you it's a thing of how you edit the files:
The 6D Mark II and the EOS RP can handle a huge amount of noise reduction (30) without sacrificing a lot details like other cameras would do. The picture from the link above the Canon guy edited in that way that I had no noise and looked good.
In the Noise reduction section of Lightroom he set the luiminace Noise 30.
In the sharpening section he used an Amount of 66, Radius 0,6 pixels, Detail 35 and Masking setting  I can not remember. But this is always different.
So with a little bit of care while shooting and in post processing you can achieve very good results even with a Canon EOS RP and saving a lot of money!
Did I mention that the RP has wonderful oldschool Canon colours from the DSLR era ? Yes it has better colours than my EOS R and the R6 I had for a short amount of time and ended up returning it because I could not edit the colours to my taste in post processing, but this I maybe my poor skillset ;).
OP Sgt_Strider Senior Member • Posts: 2,674
No.
I want to thank you guys for your opinions as it'll help guide my purchasing decision. To be clear, I mostly shoot travel and landscape photos. I do occasionally shoot the so called social photos that I’ll upload to Facebook. I typically do shoot an auto exposure bracket. I suppose even if I want to wait the RAW file, I'll likely have a good starting point to edit the image. I get that the RAW files are noisier than it's competitors, but if I get the exposure mostly right and using base ISO, can you or anyone explain to me how noise is an issue and viewable?
Assuming someone is just starting with photography.
If someone is just starting with photography the EOS RP is the right tool. It's cheap, it's small, it's light but its full frame! And there are moderately priced RF STM lenses out there. One could adapt old EF lenses as well.
It's a perfect starter camera! Beginners don't need to go straight to the high end cameras IMHO.
My advise: A beginner should buy the RP now, shoot, learn about its limitations and one day when he is more advanced he could go to a more expensive and more advanced camera.
If a beginner would buy let's say a R6 straight away it may be an overkill for him and he may loose interest in photography.
I my opinion everyone should start with smaller and cheaper stuff so there is a upgrade path for the future
And I understand the confusion when someone reads all the technical stuff in the reviews.
Basically there is cheaper stuff with less features and image quality and there is expensive stuff with more features and better image quality. That’s it
(I edited this post for photographers in general and not speaking directly to the thread starter)
I'm more interested in talking about the RAW files than my own skill set.
jboyer
jboyer Senior Member • Posts: 1,373
I have an RP since its launch (eons ago?). The exposure is the key. 'Well' exposed pictures -- requiring minimal boosting of the dark areas, will come clean of noise at high ISO values. I shoot RAW and use Capture One as my RAW processor. I came from a 7D and a 6D.
This issue is mostly related in the need to get better rendition of dark areas, like backlit pictures. A bit of over exposure may go a long way.  As one poster noted, this issue may not really exist, and the Canon colors are worth the potential problems.
And today, the issue of noise is non sequitur with tools like Topaz AI.
After 1000s of RP pictures, I still feel it is a very decent and useable camera. Sill the most affordable Full Frame, with all the pros and cons of the format.
But it is an entry level body and if budget is no object, a R6 II may serve you better in the longer term. At three times the price.
 jboyer's gear list:jboyer's gear list
Canon EOS M100 Canon EOS M50 Canon EOS RP Canon EF 50mm F1.8 II Canon EF 100-400mm f/4.5-5.6L IS USM +8 more
Even right now I tend to expose to the right. I'm assuming that what you mean is I can reduce the exposure and not have to lift any shadows to keep noise to the bare minimum?
jboyer
Yes. If short of light, increasing the ISO may also work.
L a r s New Member • Posts: 24
I used to use the 6D II (same sensor as RP) a lot for landscape photos and definitely used to bracket more with that camera than I am now with the R5 due to the more limited dynamic range. When I went from 6D II to original R the change in dynamic range was pretty obvious to me.
 L a r s's gear list:L a r s's gear list
Canon EOS R5 Canon TS-E 17mm f/4L Canon RF 24-240mm F4-6.3 Canon RF 85mm F1.2L USM Canon EF 135mm F2L USM +8 more
Apparently, I'm better off shooting ISO6400 rather than shooting ISO800 and boosting it by two or three stops?
jboyer
It really depends on what you are shooting. There are a few 'methods' to increase the perceived DR. Bracketing, using higher ISO and 'overexpose' (assuming your RAW processor is good at recovery of highlights), HDR in camera, etc.
And sometimes, noise is simply OK. It may hurt in a deep blue sky or muddy some grass. The final image may be great, no matter what.
At the RP price point, you get a pretty serviceable camera.
CamerEyes Regular Member • Posts: 266
The $70 solution is DxO PureRaw. I used to run all my RP raw files through it, including the ones I shot on low ISO. It cleans up nicely while retaining much of the useful details.
Since then, I've not had to worry about lifting shadows in RP raw files, until of course I sold my RP body.
 CamerEyes's gear list:CamerEyes's gear list
Sony a7C Canon EOS R7 Canon EOS R6 Mark II Canon EF 50mm f/1.2L USM Canon EF 50mm F1.4 USM +12 more
I'm sort of confused about how noise could be an issue. If I expose it to the right and start lowering the exposure, what would be causing the noise? I can understand if I'm increasing the exposure during post-processing or shooting in high ISO, but if I expose to the right at base ISO?
This is the image I shot
Unedited
You want to see the ugly noise?
Lights 100% down and Shadow 100% up in Lightroom
This is a Sony A7 photo
Lights 100% down and Shadow 100% up in Lightroom + 1EV Exposure on top needed.
So if you want to do this type of shots you better bracket or buy a Nikon camera!
davidwien Contributing Member • Posts: 572
It is always preferable to get the exposure right, of course, and there is no reason why you should underexpose by 2 stops if you take care; but I dont find noise to be a problem with my RP and raw files edited in Photolab.
David
 davidwien's gear list:davidwien's gear list
Sony RX100 VA Canon EOS RP Canon EOS R6 Canon EF 17-40mm f/4.0L USM Canon EF 70-300mm f/4-5.6 IS USM +6 more
jboyer
At base ISO, you should have no visible noise.
You have visible noise, when you lift the shadows too heavy. Look at my example above
I apologize if I'm being rude, but we're not even talking about lifting shadows as there is universal agreement that there is noise. What we are talking about is exposing to the right or at least getting the exposure right and then dialing back the settings like exposure. The consensus thus far is that noise won't be an issue in this scenario?
Quarkcharmed
Quarkcharmed Senior Member • Posts: 2,713
If you shoot landscapes and properly use ETTR (exposure-to-the-right) with your RP, you may get good results comparable to someone who doesn't use ETTR with an R or even R5. Although you'd get much better results had you used an R5 with ETTR.
Lowering 'exposure' in Lightroom after ETTR doesn't increase visible noise. Sitting at base ISO and using ETTR is the way to squeeze the possible dynamic range out of your camera.
But if you can't use ETTR (say because it's too dark or you can't use long enough shutter speed), yes you'd better use higher ISO 3200 right in the camera rather than ISO 800 plus 2-stop exposure lifting in Lightroom. That's because the RP is not 'ISO-invariant'.
 Quarkcharmed's gear list:Quarkcharmed's gear list
Canon EOS R5 Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM Canon EF 50mm F1.8 STM
