Need help!
Started 3 weeks ago | Discussions
Boomer1967 New Member • Posts: 5
Need help!
Ok guys,
i need your help…
i buy now R5 or I wait for R5 mark II?
i understand the last update give to R5 more power but when I saw the evolution of R6 with mark II…I’m not sure if the firmware update is enough ?
Canon EOS R5 Canon EOS R6
cpharm86 Senior Member • Posts: 2,742
Re: Need help!
If you need or want a camera now either buy the R5 or the R6ii depending on your budget. You might be waiting awhile for the R5ii. I’m sure you will be happy with either one.
MasterWayne Regular Member • Posts: 214
Re: Need help!
You might want to focus less on camera models and their numbers but more on what you actually need and expect from it.
The R5 is an utterly brilliant camera. Sure, it has a few minor issues (only 20fps in e-shutter, banding *can* appear in e-shutter, tracking only possible in "full-area" mode,...). But they are not "universal", so likely not all will even bother you.
Really, either rent one or do more research and evaluate if this is even an issue for your photography.
Currently, as an R5 owner, I cannot imagine what Canon could add to an R5II that makes me want to spend 1000-2000 bucks for a switch..
If you always need the latest and greatest, then the answer is simple: Buy an R5/3 now and resell it when you ordered the R5II..
 MasterWayne's gear list:MasterWayne's gear list
Canon EOS 80D Canon EOS M50 Canon EOS R5 Canon EF 50mm F1.4 USM Canon EF 135mm F2L USM +4 more
