What I wish for
Started 3 weeks ago | Discussions
Alan Sh Senior Member • Posts: 2,774
What I wish for
I really wish there was a way to change/make settings for my X-T5 on my PC and then just upload them all to a C1-C7 preset. Doing it all on the back of the camera is really fiddly.
Alan
 Alan Sh's gear list:Alan Sh's gear list
Canon EF-M 55-200mm f/4.5-6.3 IS STM Panasonic Lumix DMC-ZS40 (TZ60) Canon EOS M100 Canon EOS M50 Fujifilm X-T5 +13 more
Jeff Biscuits Senior Member • Posts: 1,166
Re: What I wish for
A phone app would be ideal. With the ability to set up all sorts of profiles and then just push them to the slots in the camera via Bluetooth as and when needed. Can’t be hard to do.
 Jeff Biscuits's gear list:Jeff Biscuits's gear list
Ricoh GR Digital II Ricoh GR Digital IV Fujifilm X20 Fujifilm XF10 Ricoh GR IIIx +14 more
RobRoy22 Regular Member • Posts: 273
Re: What I wish for
It sounds appealing. I have no idea how easy it would be. Do you have knowledge of this kind of technology or are you just guessing?
 RobRoy22's gear list:RobRoy22's gear list
Fujifilm X100V Fujifilm X-T5
Coldpaw Contributing Member • Posts: 772
Re: What I wish for
I haven't tried that particular feature myself but it *should* work with the free Fujifilm X RAW Studio software. It only works if your camera is connected via USB, besides of processing RAW files in-camera, you also save an unlimited number of custom presets (or recipes for that matter) on your computer and actually assign those to the C1-C7 profiles.
Morris0
Morris0 Forum Pro • Posts: 32,175
Re: What I wish for
Alan
Hi Alan,
Your wish is actually a complaint abut the rather confusing and poorly worded Fuji menu system.  They need to start from the beginning and have a native speaking photographer for each language retranslate the menus.  At the same time mark all defaults as such and do the same for the manuals.
Morris
Fujifilm X-T3 Fujifilm X-H2S Canon EF 200mm f/2.8L II USM Nikon AF-S Teleconverter TC-17E II XF 90mm +11 more
sprouty115
sprouty115 Contributing Member • Posts: 618
Re: What I wish for
Yes, use X-RAW.
https://www.youtube.com/watch?v=Gayg0-SrLcQ
Scroll to roughly the 6-min mark.
 sprouty115's gear list:sprouty115's gear list
Ricoh GR III
Re: What I wish for
Not camera firmware specifically, but I’ve been designing and building user interfaces for many years.
Technically it’s straightforward. The bigger issue as I see it is more of a product management one: if you’re going to introduce camera configuration via an app then instantly you’ll get demand for it to go further and questions about whether it should go so far as a camera which has no configuration UI but instead has just the basic physical controls and all configuration is done via the app. Taking the philosophy of the X-Pro3 to a whole new level: “das Wesentliche”, yet with access to all the technological chops that modern digital cameras can provide.
In a way it’s an extension of what Ricoh do, although they don’t do it via an app either: the GR has always been a paradox of being tremendously configurable, yet designed to perform in a point-and-shoot manner when in use. It’s that recognition of the separation of things that are configuration—which can be done in slow time—from things that are relevant to capturing a moment and need to be used in that moment. Moving the former to an app further allows the camera to be physically, and philosophically, optimised for the latter.
Samuraidog Senior Member • Posts: 1,672
Re: What I wish for
sprouty115 wrote:
Yes, use X-RAW.
Is that just for film sims, or can you change/save pretty much any camera setting?
 Samuraidog's gear list:Samuraidog's gear list
Fujifilm X-T30 Fujifilm X-H2S Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 27mm F2.8 +13 more
sprouty115
Re: What I wish for
Samuraidog wrote:
sprouty115 wrote:
Yes, use X-RAW.
Not sure, still on the steep part of the Fujifilm learning curve.  But X-RAW is free and it should be easy enough to figure out.
Ricoh GR III
OP Alan Sh Senior Member • Posts: 2,774
Re: What I wish for
I'll give that a try
Alan
Re: What I wish for
Yes, that works fine for all the settings that X-RAW knows about.
Not everything, but a good way there.
It's not terribly fast - but that's because it's not actually a settings program, that's just a sideline from it's main task.
Alan
xtabber Forum Member • Posts: 78
Re: What I wish for
sprouty115 wrote:
Yes, use X-RAW.
That might have worked with the X-T4 and possibly other 4th gen X processor cameras, but I doubt that it will for 5th generation processors (X-H2/S & X-T5, since Fuji has completely changed C1-C7  to include a lot more than Image Quality settings.
 xtabber's gear list:xtabber's gear list
Fujifilm X100V Fujifilm X-H2S Fujifilm X-T5 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 35mm F2 R WR +7 more
baobob
baobob Forum Pro • Posts: 18,248
Re: What I wish for
Agree 150% !!!
Sony RX100 Panasonic ZS200 Fujifilm X-H2S Fujifilm X-H2 Fujifilm XF 35mm F1.4 R +16 more
sprouty115
Re: What I wish for
xtabber wrote:
sprouty115 wrote:
Yes, use X-RAW.
Had you watched the 1st-minute of the video you would have seen a list of cameras that it works with, which shows the X-T4.
And that according to the latest camera compatability list from Fujifilm, it now includes the X-T5.
Ricoh GR III
baobob
Re: What I wish for
I have a XH2s anfd a XH2 I wanted the 2nd to have the same config for obvious ergonomic reasons
Any Acquire cannot work on different bodies
So finally I had to configure manually the XH2 took about one 1 hr before everything was ok because as mentionned in you post doing that on camera is the assurance to make many mistakes.
Are you listening Fuji ??
Re: What I wish for
xtabber wrote:
sprouty115 wrote:
Yes, use X-RAW.
It does work for the X-T5, but only saves the settings that X-RAW knows about. I assume the camera takes the rest from what is currently set.
Alan
Rumle
Rumle Senior Member • Posts: 1,609
Re: What I wish for
I shoot with 4 bodies, most of the times at once. I love a solution to just synchronise them all from an app or PC.
 Rumle's gear list:Rumle's gear list
Panasonic Lumix DMC-LX3 Fujifilm X70 Nikon D200 Nikon D700 Nikon D3S +29 more
DarnGoodPhotos Forum Pro • Posts: 11,881
Re: What I wish for
sprouty115 wrote:
Samuraidog wrote:
sprouty115 wrote:
Yes, use X-RAW.
I would think that you can change anything which you would be able to do in the camera which means that an X-Pro2, for example, would have fewer C# options than then X-T5.
www.darngoodphotos.com
 DarnGoodPhotos's gear list:DarnGoodPhotos's gear list
Fujifilm X100V Fujifilm X-T5 Fujifilm XF 18mm F2 R Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 27mm F2.8 +3 more
lewiedude2
lewiedude2 Senior Member • Posts: 2,662
Re: What I wish for
This is interesting stuff to me. Thanks for sharing.
 lewiedude2's gear list:lewiedude2's gear list
Fujifilm X-T2 Fujifilm 16-55mm F2.8R LM WR
