MONOCHROME Pentax K-1
Started 3 weeks ago | Discussions
ogl
ogl Senior Member • Posts: 2,004
Re: MONOCHROME Pentax K-1
Sharpness is stunning
 ogl's gear list:ogl's gear list
Pentax K-5 IIs Pentax smc FA 31mm F1.8 AL Limited Pentax smc FA 43mm F1.9 Limited
Rod Herdman Veteran Member • Posts: 3,494
Medex wrote:
Rod Herdman wrote:
Medex, I've seen you previous equally fantastic BW shots from converted sensors. It's fascinating and the BW images are fantastic. Well done to you !
Personally I'd be too scared to attack a fully functioning decent camera in case i wrecked it. But - a monochrome K5II is something I would love . . .
Rod
I wrote DM to you.
Replied, thank you
All I want is a digital back for my trusty K1000 . . .
 Rod Herdman's gear list:Rod Herdman's gear list
Pentax *ist D Pentax smc DA 18-55mm F3.5-5.6 AL Pentax smc DA 50-200mm F4-5.6 ED +12 more
Pentax645 Contributing Member • Posts: 968
The detail here is wonderful, but I am reluctant to give up the exposure adjustment capability for landscape work..........Larry
 Pentax645's gear list:Pentax645's gear list
Pentax K10D Pentax K-1 Pentax smc DA 16-45mm F4 ED AL Pentax smc DA 12-24mm F4.0 ED AL (IF) Pentax smc D-FA 100mm F2.8 macro +6 more
robgendreau Forum Pro • Posts: 10,926
What exposure adjustment do you give up with a monochrome camera?
 robgendreau's gear list:robgendreau's gear list
Pentax 645Z
robbo d Veteran Member • Posts: 3,884
Spectacular results.
I'm not one to go interfering with a camera, although I'd like to learn.... but that's yet another thing on my list
Now I'm tossing up wether to wait for Pentax to bring out a monochrome or wait for your online store service to begin so I can buy a refurbished older body from you !!
Very well done 👏.. and the photography is sublime
Not with the camera, but in PP the levels can be adjusted by color even though it's a monochrome image. Just like using filters with B&W film.
OP Medex Junior Member • Posts: 49
SMCTakumar wrote:
This is beautiful. I kind of wish to have a dedicated monochrome K-1 to use with Takumar lenses. Is the conversion technically challenging?
Sure, it is chalenging... and not cheap.
I am not sure it is worth extra money to use with old optical design lenses which have best resolution at f5,6-8. But this is just my opinion.
 Medex's gear list:Medex's gear list
Pentax K100D Pentax K-x Pentax K-5 Pentax K-30 Pentax K-5 II +5 more
Krummj wrote:
Those look great. I've been loving my monochrome converted Z6. I paid this person $1200 to do it: https://monochromeimaging.com/ . He says it's for Sony conversions, but he's open to Sony sensor cameras. I know he has done Panasonic, Nikon and Sigma FP, not sure about Pentax. Seems quite competent.
I use the same conversion software.
Yes, I think as well he is very competent. I do not know what process he uses for conversions.
and it can be even better using sharpness sliders in editing software.
Mark Ransom
Mark Ransom Veteran Member • Posts: 8,209
That's the benefit of having a cleaner original image, the sharpening software works better with it.
 Mark Ransom's gear list:Mark Ransom's gear list
Pentax K-7 Pentax K-01 Olympus E-M5 II Pentax smc DA 15mm F4 ED AL Limited Pentax smc DA 18-135mm F3.5-5.6ED AL [IF] DC WR +6 more
James O'Neill Veteran Member • Posts: 6,117
This is something I'm reluctant to give up. I've just been working on a mono conversion where parts of the image want a red filter and parts want a yellow or none at all. I can make two layers in photoshop with different filters and blend them.  Without trying one I don't know how easy it is to see the effect of the filters you will need to use with a mono sensor. Temping as it is, I'll stay with the convenience, rather than take the extra detail - there is so much already in a K1 image.
 James O'Neill's gear list:James O'Neill's gear list
Pentax K-5 IIs Pentax K-1 Pentax smc FA 50mm F1.4 Pentax smc DA 18-250mm F3.5-6.3 Pentax smc FA 43mm F1.9 Limited +3 more
TomWret
TomWret Veteran Member • Posts: 4,692
Just curious does anyone, manufacturer, make a B/W sensor camera only?
Thanks, Tom W
 TomWret's gear list:TomWret's gear list
Epson Stylus Photo R3000 +6 more
Thanks, Tom W
Leica (M9, M10 Monochrome, Q2 monochrome) and PhaseOne (100 and 150 mpix digital backs)
Krummj Contributing Member • Posts: 543
Of course, one of the nicest advantages to doing it with a K1 or another dslr is that you retain Phase Detect autofocus. I have to use contrast detect now, in pinpoint mode. It's accurate, but slower.
TomWret
Thank you, Medex.
Tom W
Monochrome conversion does not eliminate phase detection AF on Nikon Z6 sensor.
I convert Ricoh GR III sensor which has PDAF and it works as should after conversion. This AF mode does not relate to color filter array, green filters above AF pixels are used just because pixels are most sensitive to green light if UV/IR-cut filter is used (as well as for normal sensor).
SMCTakumar
SMCTakumar Regular Member • Posts: 318
Thanks. Yes, I tweaked the on board B/W to work really well for my use, especially with sharp Tak lenses.
Eric J - Irek J
 SMCTakumar's gear list:SMCTakumar's gear list
Ricoh GR Pentax K20D Pentax K-1 II Pentax smc FA 43mm F1.9 Limited Pentax smc FA 77mm 1.8 Limited +12 more
Mark Ransom
Is that where the phrase "sharp as a tak" comes from?
Adam007 Contributing Member • Posts: 805
I have one. Feel Free to Ask Me About it
"Medex" performed the necessary surgery on a K-1 I purchased for this purpose.  I'm very happy with it.  If anyone has any questions, feel free to PM me.  While you can..
Adam
 Adam007's gear list:Adam007's gear list
Fujifilm X100F Pentax K-1 Pentax K-3 Mark III Pentax smc DA* 300mm F4.0 ED (IF) SDM Pentax smc FA 31mm F1.8 AL Limited +7 more
