MONOCHROME Pentax K-1
Started 3 weeks ago | Discussions
Medex Junior Member • Posts: 49
27
In the beginning of 2022 I had opportunity to get very cheap full frame DSLR in working condition with 36 mpix sensor - same sensor used in Pentax K-1, Sony a7R, Nikon D800/810. I used it for my monochrome conversion (debayering) experiment and first attempt was successful. This motivated me to try Pentax K-1 conversion because I am Pentax shooter and this camera has many good functions as well as in-body image stabilization. Unfortunately my attempt in April 2022 was unsuccessful and I hesitated quite long to try another K-1. Until October 2022.
Probably many of you know advantages of monochrome sensor compared to stock sensor:
- resolution increase (x2,25): sensor still has 36 mpix but is able to produce details which can be get from about 80 mpix stock sensor;
- sensitivity increase about 0,7-1 stop (my observation is more modest - 0,5-0,7 stop, but some sources claim +1 stop as an average);
- much better noise profile at higher ISOs (advantage about 1,5-2 stop). IMO ISO 6400 look very very beautiful and now I use max Auto-ISO 25600 without fear.
I like the idea of shooting monochrome only. Starting from early 2021 when I converted Pentax K200D with 10 mpix CCD sensor I like monochrome even more than color.
Pentax K200D monochrome
First FF 36 mpix monochrome sensor (D800)
Pentax K-1 monochrome (36 mpix) debayered
 Medex's gear list:Medex's gear list
Pentax K100D Pentax K-x Pentax K-5 Pentax K-30 Pentax K-5 II +5 more
Pentax K-1 Pentax K200D Sony a7R
TomWret
TomWret Veteran Member • Posts: 4,692
Re: MONOCHROME Pentax K-1
Medex, you have some really beautiful photos, and I'm able to see what you mean. They look like the difference between my old TV and the newer 4K TV.
Thanks for sharing.
Tom W
 TomWret's gear list:TomWret's gear list
Epson Stylus Photo R3000 +6 more
BobORama
BobORama Senior Member • Posts: 2,842
Those are wonderful and have a great look to them, and obviously well planned out.
I am of the opinion that it is just as important to show off our failures so that others can learn from them. Can you tell us about how your conversion went wrong?  Did you document somewhere the conversion process?   ( That can be a separate thread, obviously, but I am curious as I am interested in doing a multi-spectral conversion which is 98% the same mess. )
 BobORama's gear list:BobORama's gear list
Pentax K-5 Pentax K-1 Sigma 10mm F2.8 EX DC HSM Diagonal Fisheye Pentax smc DA 18-55mm F3.5-5.6 AL WR Samyang 14mm F2.8 ED AS IF UMC +9 more
James O'Neill Veteran Member • Posts: 6,117
But how ...
So you have a sensor with rows going
Red Green Red Green
Green Blue Green Blue.
You remove the bayer filter - but the camera still thinks that 1,1 is red, 1,2 is green, 2,1 is green, 2,2 is blue and it outputs a raw with 4 pages for R, G1, B, G2, or a very odd debayer'd JPEG (which will also appear in live view).
What do you use to convert the files to a 36MP mono ? I'm assuming there is no firmware hack to do it.
 James O'Neill's gear list:James O'Neill's gear list
Pentax K-5 IIs Pentax K-1 Pentax smc FA 50mm F1.4 Pentax smc DA 18-250mm F3.5-6.3 Pentax smc FA 43mm F1.9 Limited +3 more
OP Medex Junior Member • Posts: 49
Thanks for sharing.
Tom W
Thank you
Multispectral conversion? Is it the same as full spectrum? If yes, then your choice is much much easier to do. You don't need to remove color filter array from sensor surface and even go beyond sensor protective glass. Simple removal of UV/IR-cut filter makes your sensor full spectrum (or almost full spectrum, because UV part is still blocked by protective glass).
Re: But how ...
Red Green Red Green
Yes, you are right - camera does not know that sensor has no color filters. Therefore almost all white balance modes give pinkish jpeg preview on the screen. But I set custom white balance using white paper and preview now looks gray-toned. I also switch to Monochrome mode to discard all possible color "additives".
So, now jpegs are black and white. But I do not shoot jpeg at all. RAW only. Then I import raw files into editing software (Raw converter = e.g.Lightroom) for storage. But editing software applies demosaicing which degrades details. It is not good if you like max details and shoot with dedicated mono camera. To avoid demosaicing and get pure monochrome, Monochrome2Dng converter is used. It produces another DNG file which is treated by Lightroom as monochrome and demosaicing is not applied.
Re: But how ...
Red Green Red Green
A-ha! That was the missing piece.
Lessiter Regular Member • Posts: 412
Re: But how ...
Have you tried http://rawtherapee.com/ ?
Raw tab (mosaic icon) > Demosaic Method > Mono (or perhaps none)
Rod Herdman Veteran Member • Posts: 3,494
Medex, I've seen you previous equally fantastic BW shots from converted sensors. It's fascinating and the BW images are fantastic. Well done to you !
Personally I'd be too scared to attack a fully functioning decent camera in case i wrecked it. But - a monochrome K5II is something I would love . . .
Rod
All I want is a digital back for my trusty K1000 . . .
 Rod Herdman's gear list:Rod Herdman's gear list
Pentax *ist D Pentax smc DA 18-55mm F3.5-5.6 AL Pentax smc DA 50-200mm F4-5.6 ED +12 more
Re: But how ...
Yes. I tried Rawtherapee and monochrome demosaic method, but its interface is too difficult to me and I don't like it. Just my preference
timo Veteran Member • Posts: 5,927
This is a very convincing argument for getting a camera converted.
 timo's gear list:timo's gear list
Fujifilm X30 Pentax K-5 Pentax K-30 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GX8
ozdean
ozdean Forum Pro • Posts: 28,665
I have to admit I love colour but what you have achieved here is most impressive - so detailed and obviously professionally shot.
Regards Dean - Capturing Creation
N.B. All my Images are Protected by Copyright
 ozdean's gear list:ozdean's gear list
Pentax MX-1 Pentax K-5 IIs Pentax K-3 Mark III Pentax smc DA* 55mm F1.4 SDM Pentax smc DA 15mm F4 ED AL Limited +14 more
Mark Ransom
Mark Ransom Veteran Member • Posts: 8,209
Those are all exquisite, and the sepia tone you applied on the last one is the icing on the cake.
 Mark Ransom's gear list:Mark Ransom's gear list
Pentax K-7 Pentax K-01 Olympus E-M5 II Pentax smc DA 15mm F4 ED AL Limited Pentax smc DA 18-135mm F3.5-5.6ED AL [IF] DC WR +6 more
Rod
I wrote DM to you.
I have some already converted if you like (in good shape and tested)
Thank you. I shoot not often but like planned photoshoots more, especially for monochrome
Sepia toning is the way of postprocessing I use in last months
SMCTakumar
SMCTakumar Regular Member • Posts: 318
This is beautiful. I kind of wish to have a dedicated monochrome K-1 to use with Takumar lenses. Is the conversion technically challenging?
Eric J - Irek J
 SMCTakumar's gear list:SMCTakumar's gear list
Ricoh GR Pentax K20D Pentax K-1 II Pentax smc FA 43mm F1.9 Limited Pentax smc FA 77mm 1.8 Limited +12 more
Krummj Contributing Member • Posts: 543
Those look great. I've been loving my monochrome converted Z6. I paid this person $1200 to do it: https://monochromeimaging.com/ . He says it's for Sony conversions, but he's open to Sony sensor cameras. I know he has done Panasonic, Nikon and Sigma FP, not sure about Pentax. Seems quite competent.
I use the same conversion software.
