Custom Film Simulations Question...
Started 4 weeks ago | Discussions
sprouty115
sprouty115 Contributing Member • Posts: 618
Camera is an X-Pro3...
So I understand how to setup and save film simulations to the different "registers" (C1 - C7).
I also understand how to delete a film simulation from one of the registers.
But what I'm wondering, is after I've modified all 7 registers, is there a way to "get back" to the original base settings - everything set to "0"?
I know I can leave one register unmodified and just select that, but I was curious if there was a single button press that would sort of "unselect" all banks?
Hope this question makes sense...
 sprouty115's gear list:sprouty115's gear list
Ricoh GR III
JayBee037
JayBee037 New Member • Posts: 3
Re: Custom Film Simulations Question...
Not that I know of unfortunately. On my X-pro3 I leave one of the custom slots as a “default” with all the settings back to their default values, effectively leaving me with 6 customized slots.
Maybe someone knows of a better way!
 JayBee037's gear list:JayBee037's gear list
Fujifilm X-T4 Fujifilm XF 23mm F2 R WR Fujifilm XF 80mm F2.8 Macro Sigma 56mm F1.4 DC DN | C (X-mount) Sigma 18-50mm F2.8 DC DN
sprouty115
OP sprouty115 Contributing Member • Posts: 618
I was thinking it may be a stupid question, but given all the options there are on cameras these days, I figured I'd ask.
Ricoh GR III
Greybeard2017
Greybeard2017 Veteran Member • Posts: 3,112
How about using X Raw Studio?
 Greybeard2017's gear list:Greybeard2017's gear list
Fujifilm X-T30 Fujifilm X-S10 Fujifilm X-H2S
sprouty115
I understand the suggestion, but I was thinking more of while I was out shooting if I wanted to just shoot a film simulation as it comes from Fujifilm.
Basically quickly switching from custom recipes back to factory.
Leaving one register unmodified does exactly what I want, I was just wondering if there was a way to use all the registers that I missed.
Ricoh GR III
McWoodley
McWoodley Contributing Member • Posts: 647
Just set 1 to Provia Standard with all other settings at base or zero.  You could also use X Acquire to backup your settings and then factory default if you wanted to confirm but I’m quite certain Provia standard is the default film simulation will color, sharpening, NR etc all set to 0 and auto white balance.
 McWoodley's gear list:McWoodley's gear list
Fujifilm X-E1 Fujifilm X-T30 Fujifilm X-T4 Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R +10 more
Coldpaw Contributing Member • Posts: 772
It's not a stupid question, far from it! When I started with Fujifilm, I wondered exactly the same thing and wasn't alone either. The answer however has already been provided:
You indeed have to "sacrifice" one of the custom profile slots for something like a default setting. Another option would be to search for a more or less neutral film recipe and use it as a baseline, so something without a harsh DR setting and any dramatic white balance experiments.
PeterCL New Member • Posts: 10
That's what I do, PLUS I've programmed one of my buttons of "Recall C1 settings". That way, with one press of that button it's done.
cedm New Member • Posts: 8
There's no "OFF" option for "Select Custom Setting" on X-Pro 3 bodies? Or "A" option in the Q menu?
It's a thing on my X-T30 II.
 cedm's gear list:cedm's gear list
Fujifilm X-T30 II Fujifilm XF 35mm F2 R WR Fujifilm 15-45mm F3.5-5.6 OIS PZ
sprouty115
Will look, but I don't remember seeing it...
Ricoh GR III
I looked it up for you: https://fujifilm-dsc.com/en/manual/x-pro3/shortcuts/q_button/index.html
You should be able to cycle through C1-C7 and back to 'BASE' from the Q menu.
rla1022 Contributing Member • Posts: 762
This is the correct answer.
 rla1022's gear list:rla1022's gear list
Fujifilm X-E4 Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 35mm F2 R WR Fujifilm XF 16-80mm F4 Fujifilm XF 27mm F2.8 R WR +1 more
sprouty115
Except it doesn't appear to work that way.
I just modified all 7 registers and then started cycling through them. Now I can only select one of those registers (C1 - C7) and when I do the word "BASE" appears above the register number in small text, presumably indicating "this is what the camera is now set to".
C2 has a film simulation I added, all other registers have been modified with Noise Reduction changed from "0" to "+1".
I then scrolled to C2 using the Q-menu and selected it.  This is what it shows now.
Then I went back to the Q-menu and scrolled through all the registers and they all show the NR change.
Before I select the register...
After I select the register...
So it seems like the only way to get back to "no modifications" is to leave one register unmodified.
Ricoh GR III
I'm a bit too new with Fuji to give an authoritative answer, but I think Cx+Base means both custom presets and base settings are applied.
I vaguely remember Pal2Tech discussing this in one of his video. This may be the video: https://www.youtube.com/watch?v=iE4sAPrVqE0 Have not double checked as I'm at work at the moment.
