Nitecore FX1 Dual-Slot USB Travel Charger any good?
Started 4 weeks ago | Discussions
jonikon Veteran Member • Posts: 7,432
I'm looking for a good international battery charger for the FUJIFILM NP-W126(S) batteries.
It appears the Nitecore FX1 may be the solution. I like how it can charge two batteries at once.  Hopefully someone on this forum owns one and can give some advice.
-Jon
BombayBaker Regular Member • Posts: 125
Re: Nitecore FX1 Dual-Slot USB Travel Charger any good?
-Jon
It is a perfectly decent charger.  Note that it does not come with a power adapter....you will need one that connects to a USB A cable.
 BombayBaker's gear list:BombayBaker's gear list
Fujifilm X-Pro3 Fujifilm X-T5 Fujifilm XF 35mm F1.4 R Fujifilm XF 27mm F2.8 R WR Fujifilm XF 18mm F1.4 R LM WR +3 more
Crashton
Crashton Senior Member • Posts: 1,999
I've been using that charger for a couple of years. Works great for me....
Chuck
 Crashton's gear list:Crashton's gear list
Fujifilm X-T4 Fujifilm X-E4 Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 23mm F2 R WR +3 more
Rob711 New Member • Posts: 21
The Nitecore chargers are great products. I purchased an FX1 for my XT2/XT3 batteries and now have added the FX3 dual charger for my X-H2S. Both are small & compact and will charge two batteries and are great for using with my Anker PD26800 Power Bank.
Highly recommended.
 Rob711's gear list:Rob711's gear list
Fujifilm X-T2 Fujifilm X-T3 Fujifilm X-H2S Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 10-24mm F4 R OIS +6 more
TriTip New Member • Posts: 1
As others have said, it doesn't come with a wall adapter; however, since you're looking for a travel charger, it works great since you can use different adapters for different countries. I use an international multi-adapter and the Nitecore as my travel setup. I've found it to be a great solution.
Coldpaw Contributing Member • Posts: 772
I got the Nitecore FX1 back in 2021 when the genuine Fujifilm chargers were out of stock everywhere. It was a good decision, the charger has been working very well since then. It is very compact and pretty light, just a bit larger than the actual battery. It charges two of them without any issues.
As others have said though, you need to provide your own USB (Type A) power adapter, as none is included within the box. Another important information: While the cable is very sturdy and convenient it is short, extremely short. If you don't want it to be dangling from the wall plug. you might want to think about some sort of extension cord. In addition the cable is hardwired into the FX1, so you can't simply exchange the cable for a different one.
sluggy_warrior Veteran Member • Posts: 3,204
If you plan on charging from USB power banks on the road, don't go for the FX1, it hogs 300-350mA of the precious juice itself, that is around 1/3 of a Fuji battery. The latest Wasabi Power flat charger is better in terms of power efficiency, seeping only 19mA itself (since it doesn't need to feed a bright LCD screen).
https://www.amazon.com/Wasabi-Power-NP-W126-NP-W126S-Fujifilm/dp/B08R12HYSW
Related thread:
https://www.dpreview.com/forums/post/66895439
I was shooting the whole day at a dance fest on Sunday, my 10,000mAh Samsung bank was able to charge 3 Fuji/Wasabi batteries and still have one bar (out of 5) left.
