R6 to R6 Mark ii. Worthwhile upgrade for portraits?
Started 3 weeks ago | Questions
Alastair Norcross
Alastair Norcross Veteran Member • Posts: 9,874
Re: R6 to R6 Mark ii. Worthwhile upgrade for portraits?
José B wrote:
Alastair Norcross wrote:
José B wrote:
[text snipped]
3) Custom settings do not keep on this camera at all. I will setup the shooting parameters (including 1/125 shutter speed) that I use, save them as C1-C3 and later when I go to use the setting the shutter speed always drops to 1/40th of a second. An no, I don't have the auto update enabled under this setting. This one is a head scratcher for sure.
Yeah for some reason custom settings do not stick. In my case it's the recording to the individual cards i.e. let's say I have record separately (Slot 1 RAW, slot 2 Jpeg) on C1 then on C3 I might have it as Auto Switch jpeg. When I return to C1 it could be record separately in RAW or something like that. I just complained to Canon Canada. They told me to reset my camera but the problem remains. Anyway, I hope it gets solved via firmware update.
Well, in your case, it seems to be just that one setting (record to card). As you say on the other thread, all your other settings stick. The person you are replying to seems to be claiming that the problem is more widespread. Are you sure that absolutely all the settings are even supposed to register with custom settings?
I just checked the user's manual. It says "You can register current camera settings such as shooting, menu, and Custom Function settings as Custom shooting modes." It doesn't say that you can register all settings. But it doesn't say you can't, either.
Here's my issue here:
https://www.dpreview.com/forums/post/66922980
Yes, I understand your issue. I'm just wondering whether the setting you are trying to assign to your C1, C2, and C3 modes is one that the camera can assign. Maybe not all settings can be assigned like that. As I said, the manual doesn't say that all settings can be registered to a C mode. It says settings "such as shooting, menu, and Custom Function settings". It doesn't specify exactly which of these settings will be remembered by a C mode. Maybe all settings are supposed to be registered. But maybe not. If I get a minute, I'll try to register the specific settings you are interested in (the write to card settings) to C modes on my R6II, and see whether they stick.
“When I die, I want to go peacefully in my sleep like my grandfather. Not screaming in terror, like the passengers in his car.” Jack Handey
Alastair
http://anorcross.smugmug.com
Equipment in profile
 Alastair Norcross's gear list:Alastair Norcross's gear list
Canon G7 X II Canon EOS M6 II Canon EOS R7 Canon EOS R6 Mark II Canon RF 35mm F1.8 IS STM Macro +24 more
José B
José B Forum Pro • Posts: 20,482
José B wrote:
[text snipped]
Thanks Alastair. My workaround is just to put the recording function to My Menu---that's good enough for me right now.
 José B's gear list:José B's gear list
Canon EOS R6 Mark II Canon EOS-1D Mark III Canon EOS 5D Mark II Canon EOS 5DS Sony a6500 +16 more
dpfan32 Regular Member • Posts: 258
I can tell you, with the EF 135mm f2 L there is no problem shooting even with the EOS RP. I own both. I didn't like the color science of the original R6. The new R6 seems better in this regard with the new sensor. But this is all a matter of taste.
I would replace the original R6 with the R6 II for the color science alone.
MichaelFrederickPhoto
MichaelFrederickPhoto Contributing Member • Posts: 638
I will more talk about the color cast,  I struggled with it for too long then I played with DPP on various WB settings for my headshot work.
I found 5600K and M2 B2 in WB shift gave me exactly what I am looking for with no hue. Works great on skin tones.  See if that works for you as well.
https://www.instagram.com/michaelfrederickphotography/
https://www.flickr.com/photos/159695193@N02/albums
Canon R6, Canon 16-35 F4, Sigma 40mm 1.4, Sigma 105 1.4,, and Tamron G2 70-200 2.8. Fuji X100v, Fuji X-H1 - Viltrox 33mm 1.4
