The M additions I’d like to see
Started 3 weeks ago | Discussions
cr3shooter Junior Member • Posts: 42
5
I’ve been using an M6 Mark II since shortly after it was released and love it. With its 30MP sensor the results are excellent, particularly with the Canon 32mm/1.4 and Sigma 56mm/1.4 and its compactness is brilliant. Canon’s lack of commitment to the M series has made me look at other cameras for the future but none offers any compelling advantage over the M6 Mark II. In the overall combination of quality / frame rate / compactness / handling it’s still unsurpassed.
The one area where the M6 Mark II is particularly compromised is the lack of a built-in viewfinder and this surely put off some buyers. Yes, I have the add-on viewfinder which is fine but it would be better to have one built in. I compared the M6 Mark II to the Panasonic GX85 and was amazed to see how similar they are in size, except that the Panny has a built-in viewfinder. This could surely be added to the fictitious M6 Mark III by replacing the built-in flash.
See here and choose the views of the rear of the cameras.
https://camerasize.com/compare/#829,673
Increase the buffer size while they are updating it (22 shots is not enough when firing at 14 fps) and I would buy one.
On the lens side, release an M version of the R mount 16mm f2.8 pancake in the body of the M 22mm f2.
If Sony could only bring out more versions of their APS-C range like an improved A6600 - which has a similar form factor to the M6 and a built-in viewfinder - then maybe this would spur Canon into action. Compare the two in size here:
https://camerasize.com/compare/#829,831
Come on Canon, if the M series really isn't dead, give us an M6 Mark III with built-in viewfinder and bigger buffer, and a 16mm prime.
Canon EOS M6 Panasonic Lumix DMC-GX85
Maxmolly7
Maxmolly7 Senior Member • Posts: 1,481
Re: The M additions I’d like to see
9
Wishful thinking, nothing will happen in this case.
May THE LIGHT be with you!
 Maxmolly7's gear list:Maxmolly7's gear list
Sony RX10 IV Sony RX100 VII Canon EOS M6 II Canon EF-M 11-22mm f/4-5.6 IS STM Canon EF-S 55-250mm f/4-5.6 IS STM +16 more
MAC Forum Pro • Posts: 18,487
if they were going to do a III, they would not have discontinued the II
I had to get over it
though I keep my m6II, my future investments are going toward an R8 - just what they intended would happen
Canon EOS M6 Mark II vs Canon EOS R8 Camera Size Comparison
 MAC's gear list:MAC's gear list
Canon EOS 7D Mark II Canon EOS RP Canon EOS M6 II Canon EOS R8 Canon EF 70-200mm f/2.8L USM +7 more
istscott
istscott Regular Member • Posts: 467
Great point about the Panasonic GX85. Now that Panasonic has started to embrace phase detect AF with their S5ii maybe they will eventually release a new camera with that shape and PDAF.
m100
m100 Senior Member • Posts: 2,048
Both of my M6II cameras are staying outside of my dry box.
Neither is a backup.
I bought a 5D for $69.  Works fine and has the mirror fix.
Put the 100L on it. Oh my !  Had no idea that combo worked so nice !
It is staying out of the dry box too.
I am afraid a R8 might live in my dry box like my RP did.
Dr. says listen to this every morning.
https://www.youtube.com/watch?v=bEeaS6fuUoA
 m100's gear list:m100's gear list
Canon EOS M6 II
MyM6II Senior Member • Posts: 2,424
I would like to see an M3 Mark II. The M3's body size and weight was almost perfect.
 MyM6II's gear list:MyM6II's gear list
Canon EOS M6 II Canon EOS M6 Canon EOS M200 Canon EOS M50 II +1 more
$69 a great price with the mirror box fix. I loved mine in its time even with its shortcomings and weight.
R8 really requires more RF L glass imo if you go there someday - eg, RF 24-105 F4L, RF 70-200 F4L, then for birding add Rf 100-400 + Rf 1.4 ext
nnowak Veteran Member • Posts: 9,075
Isn't that what the M6 was?
M6 is the same dimensions, same shape, and only 24g heavier.  The only real external differences are an extra dial and some of the buttons swapped locations.
TiltShiftR
TiltShiftR Regular Member • Posts: 300
Just give me IBIS
..and I'll be happy.
The M6 is a very good camera, but has not got the newest technology. And no, the M6 was not M3 Mark II.
The M6 is great too. But it has a few physical drawbacks IMO.
1. I don't like the "ears" where you attach the strap.
2. The top of the camera is not flat because of the exposure compensation wheel.
3. As you said it is heavier. Not much. But every iteration has been slightly heavier and I liked the weight of the M3 better. I would like a new camera to go back to that weight (or even lighter).
Point 1 and 2 makes the camera "feel" a bit larger and more uncomfortable.
Not deal killers, but if I could choose, I would choose the M3 body.
M6 mark II fixes point 1 and 2, but not point 3. And it is also bigger than the M6.
m100
I still have a Nikon 50mm f/1.4 from 1967 I sometimes use for focus stacking. On a 5D at f/1.4 too.
Still have a 1D III that really does have a good mirror box.
I know how to rebuild the battery packs.
You know what I step out with though ?
To upgrade my stepppin out camera it would need to be something lighter and more powerful than a M6II with a 32mm lens for less than $1000 ?
And I sure do not know what setup that would be.
I do not find myself having a problem getting eyes in focus or tracking cars or bikes.
Rarely go out at night anymore.
Canon EOS M6 II
Alexis
Alexis Senior Member • Posts: 1,998
6
It's the "M5 Mk2" that we've all been dreaming about but sadly I cannot see it coming!
 Alexis's gear list:Alexis's gear list
Canon EOS 50D Canon EOS M50 II GoPro Hero9 Black Sigma 17-50mm F2.8 EX DC OS HSM Canon EF-M 11-22mm f/4-5.6 IS STM +12 more
AbuMahendra Regular Member • Posts: 106
The M6II is technically superior and more capable than the M5. But I prefer the ergonomics and shooting experience of the latter.
Maxmolly7
Could share the specifics in more detail?
I am curious because I skipped M5... 🤔
It's quite simple. The M5 has an EVF which I use 99.9% of the time so the shooting experience is rather like a DSLR, which I prefer.
R2D2 Forum Pro • Posts: 26,528
You didn't miss much.  The M5's AF pales in comparison to the M6ii's.
R2
R2
I skipped the m, until the m6II - and I love the M6II ergonomics.
and I say this, after having 15 Canon bodies in 20+ years
Maxmolly7
Thanx for coming back on this! All clear now.
... This is from someone, me, who's shot M and M3, both with the typical cigarette pack body sans EVF, since 2013. I am quite familiar and experienced with the form factor. In fact, most and my favorite M images have been taken with that form factor. But i prefer a view finder. Shooting experience and camera enjoyment is not only or even primarily about tech specs or capability, as the M itself has shown since 2013. If you are a old Canon M hand, you'll know that there's nothing wrong or bad with the M5 capabilities. It's certainly a much more capable camera all around than the M or M3 ever were. The reality is that if you know what you're doing, you can get non-static shots like this one shot on a DSLR with no face or eye tracking at all, with an AF system of a decade ago, limited focus points and only DIGIC 5+. The M5 with its face tracking would have made this shot even easier. Let's keep it real, folks.
6D (2012) & 70-200/4LIS (2006)
Alexis
6
What I meant by "M5 Mk2" is basically a "marriage" of the internals of the M6ii with the body of M50 Mk2 (built-in EVF, fully-articulated touchscreen) with a couple of extra dials as in the M5. This to me would be the ultimate "M"
