AF-S !AF error XS10
Started 4 weeks ago | Discussions
CSing New Member • Posts: 11
AF-S !AF error XS10
Hi,
I am upset with problem that I have started facing recently and that is, camera is unable to focus on near objects.
Any valuable comments are most welcome.
britcam
britcam Senior Member • Posts: 2,583
Re: AF-S !AF error XS10
What lens are you using ?
That should help establish what the problem is ..
Rich S
 britcam's gear list:britcam's gear list
Fujifilm X-E2 Fujifilm X-M1 Fujifilm X-S10 Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro +8 more
GMacF Contributing Member • Posts: 999
CSing wrote:
Hi,
Is it possible you have somehow switched on the focus limiter?
 GMacF's gear list:GMacF's gear list
Fujifilm X-E3 Fujifilm X-H2S Fujifilm X-T5 Fujifilm XF 27mm F2.8 Fujifilm XF 10-24mm F4 R OIS +9 more
Alan Hewitt Photo
Alan Hewitt Photo Contributing Member • Posts: 909
Check in-camera focus limiter settings and if the lens you are using has it, check it isn’t limiting and excluding closer distances.
Freelance wildlife photographer, filmmaker, photography safari & workshop guide, writer. Fujifilm UK Ex-X-Photographer!
www.alanhewittphotography.co.uk
INSTA1: alanhewittphoto
INSTA2: bts_alanhewittphoto
 Alan Hewitt Photo's gear list:Alan Hewitt Photo's gear list
Fujifilm X-T2 Fujifilm X-H1 Fujifilm X-H2S Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 50-140mm F2.8 +2 more
WeirdSheep Regular Member • Posts: 220
CSing wrote:
Hi,
You're focusing using a tiny focusing box on a dark subject with no contrast, so no, your camera won't focus, no camera that relies on contrast will focus on a subject where there is none. The problem is your inability to understand how to focus that scene, it's not a camera issue.
OP CSing New Member • Posts: 11
It is kit lens , 18-55mm f2.8-4
britcam
Thank you - I have the XS10 and the kit lens 18-55 (dating from 2015 with my XE2, and I’ll do some testing myself ..
Rich S
Why I have posted the issue here is because I am not  able to focus on any of the near objects 1m - 3 m and this problem was not existing earlier.
It works fone for far away objects.
Moreover this problem is only with AF-S mode.
I believe it is all because of canera settings that have changed. What do you say.
Based on the picture you provided as evidence I can only repeat what I said originally. If you believe it is the camera settings then simply reset the camera to the default camera settings and try again.
britcam
To let you know, I have no problems shooting at min focal range using the 18-55 ... AF range limiter is set to OFF.  I would suggest a full reset to default then doing another test ...
Two examples ....
Regards
Rich S
It works now after reset,
It works now after reset.
Thanks,
Where i can find the focus limiter option?
Where can I find focus limiter, and by the way it works after reset.
Thanks,
Greybeard2017
Greybeard2017 Veteran Member • Posts: 3,112
Thanks,
The focus limiter option is on page 3 of the AF menu - for future reference that was very likely your problem and worth checking before doing a full reset.
 Greybeard2017's gear list:Greybeard2017's gear list
Fujifilm X-T30 Fujifilm X-S10 Fujifilm X-H2S
Thanks,
No problem, glad you got it sorted.
That's right, got this thanks a lot,
Fz2000user uk Senior Member • Posts: 1,509
WeirdSheep wrote:
CSing wrote:
Hi,
The xs10 uses hybrid af so should easily af on that scene .
Sure enough after reading the rest of the replies it was a camera setting .
It’s all about the zoom
 Fz2000user uk's gear list:Fz2000user uk's gear list
Olympus OM-D E-M1X Fujifilm FinePix IS-1 Fujifilm X-S1 Sony RX10 II Nikon Coolpix P1000 +5 more
Thanks,
Glad you got it sorted .
