Appears to be satisfactory…
Sir Jake wrote:
I tried to calculate the magnification ratio of several lenses with different Raynox add-ons with this site:
http://extreme-macro.co.uk/calculators/
The calculations give me astronomical results, such as Tamron 50-400mm on the 400mm end + the Raynox 150+250 yields a magnification ratio of 6.65x.
Has somebody tested and verified whether the calculator is right or not?
A Raynox 150 is 4.8 diopters. A Raynox 250 is 8 diopters. Diopter values add when you stack them close, so both Raynoxes together is 4.8+8=12.8 diopters.
The 400mm is 1000/400mm=2.5 diopters.
With the 400mm focused at infinity the magnification will be 12.8/2.5=5.12x
I don’t know how close the 400mm focuses or what the change in focal length at its closest distance is, but 6.65x is a very reasonable value. I tend to favor using the rear (aka "tube") lens at infinity so I'd call it a 5.12x combination.
I punched in a combination I do know (Nikon 85mm f/1.4 + Canon 500D) and their answer matched mine at close focus, so I'd say it's OK.
Personally, I'd never stack two Raynox closeup lenses in front of a 50-400mm zoom. Aside from the optical quality of that combo not being all that, there's a problem with speed. The Tamron is rated f/5.6 at 400mm, that's a 71mm aperture. The Raynox will choke that down to 32mm or f/12.5. That's approaching diffraction limiting.
The term "mirrorless" is totally obsolete. It's time we call out EVIL for what it is. (Or, if you can't handle "Electronic Viewfinder Interchangeable Lens" then Frenchify it and call it "LIVE" for "Lens Interchangeable, Viewfinder Electronic" or "Viseur électronique").
Stanley Joseph Wisniewski 1932-2019.
Dad, so much of you is in me.
Christine Fleischer 1947-2014.
My soulmate. There are no other words.
Rahon Klavanian 1912-2008.
Armenian genocide survivor, amazing cook, scrabble master, and loving grandmother. You will be missed.
Ciao! Joseph
www.swissarmyfork.com
