82mm Circular Polarizer
Started 3 weeks ago | Discussions
cpharm86 Senior Member • Posts: 2,742
I am looking at the Nikon 82mm circular polarizer for the Canon RF 15-35mm f/2.8L lens. I do have a 77mm Nikon CP filter but wondering about any other suggestions that anyone has used besides the Nikon? I see the prices vary a bit.
Here is the Nikon 82mm filter.
https://www.bhphotovideo.com/c/product/1175267-REG/nikon_2498_82mm_circular_polarizer_ii.html
Thank you,
Pete
OP cpharm86 Senior Member • Posts: 2,742
Re: 82mm Circular Polarizer
Thank you,
Pete
Any suggestions or is this Nikon filter a good choice?
L a r s New Member • Posts: 24
I use Polar Pro CPLs and some of their CPL/ND combo filters. Not sure if they are better or worse. Just an option ..
 L a r s's gear list:L a r s's gear list
Canon EOS R5 Canon TS-E 17mm f/4L Canon RF 24-240mm F4-6.3 Canon RF 85mm F1.2L USM Canon EF 135mm F2L USM +8 more
Thank you, looks like an option. I saw the Canon equivalent is $199 which is $27 higher than the Nikon I was looking at.
Veggiedean DTP Regular Member • Posts: 161
I have not used Nikon filters, but I have used Olympus. I have the B+W 82mm Master High Transmission Kaesemann Circular Polarizer and it is an excellent filter.   No vignetting with 15-35,
Dean
dtp-realestate.com
deantylerphotography.com
 Veggiedean DTP's gear list:Veggiedean DTP's gear list
Panasonic GH5 Panasonic Lumix DC-S1R Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Leica Nocticron 42.5mm +8 more
Would this be the one you have? Higher price than the others but important to limit the vignetting with a 15-35 mm lens.
https://www.bhphotovideo.com/c/product/1670788-REG/b_w_66_1101635_82mm_pol_filter_high.html
Abbott Schindler Veteran Member • Posts: 3,099
I don't know that Nikon actually makes their filters. I've had excellent results from Hoya HD and HD2 filters. I see they're now on the 3rd generation, and it looks pretty pricey. One thing I like about my Hoyas is that their filter factor was (at the time) lower than other brands, yet they polarized about the same.
https://www.bhphotovideo.com/c/product/1177612-REG/hoya_xhd3_82crpl_82mm_hd3_circular_polarizer.html
Breakthrough filters are also quite good, and far less expensive:
https://www.adorama.com/btx4cpl82mm.html
I used to use B+W CPLs, but at the time (about 10 years ago) I had problems with both of my B+W CPLs' mounts binding (others reported this as well), which is what got me to change to Hoya. B+W almost certainly has fixed the problem by now:
Whatever you decide on, don't get a cheap filter.
PIOT Regular Member • Posts: 211
Thank you,
Pete
Get this one instead... B+W High-Transmission MRC-Nano Master Circular Polarizer Filter Nicer colors, much easier to clean
I am using Nikon CPL for at least 10 years ( but I prefer this one and I do recommend getting one over Nikon.... I did a test side by side and I like more B&W ( but I have 77mm)
https://www.bhphotovideo.com/c/product/1670788-REG/b_w_66_1101635_82mm_pol_filter_high.html/reviews
https://www.glazerscamera.com/products/b-w-82mm-master-htc-circ-pol?_pos=1&_sid=42a920bfa&_ss=r
As for 82mm I have Zeiss and also prefer this one compare to Nikon
Very good quality CPL ( but this does not cleans as easy as B&W but at leas as good as Nikon or a little easier )
https://www.bhphotovideo.com/c/product/763761-REG/Zeiss_1856_339_82mm_T_Circular_Polarizing.html
Thank you,
Pete
Thank you, another response on this thread was for this same one. Is the Glazers camera and B&H the same filter just $50 difference in price?
Correct - both have the same number
MFR #66-1101635... You can find this info on both websites
And as I said before....
Very good quality CPL ( but this does not cleans as easy as B&W but at least as good as Nikon or a little easier )
Thank you. But you still prefer the B&W over the Nikon and Zeiss? I’m not sure about the difficulties in cleaning though. Are you saying the glass quality makes the difference in cleaning?
Exactly. B&W coating make big difference. And I prefer this Filters more than Nikon and Zeiss ( but Zeiss is also very good )
What I only don't like  about B&W CPL is that its rotate too easy in comparison to Nikon or Zeiss
You need to read some reviews about B&W and see, maybe this change  in last 6 months.
I still have Nikon 72mm CPL and I am using with 24-70 f4 ( but I wish to replace this filter with B&W ...thats how I like them
drsnoopy Senior Member • Posts: 1,216
Whatever you buy, be aware that at very wide angles, the degree of polarisation of the sky varies across the field of view, and you will get variation in the blue shading across your image. This is not a fault of the filter - polarisation of sunlight from the sky is maximal at +/- 90 degrees from the sun, minimal at 0 / 180 degrees.  At 15mm you have about 100 degree field of view, which includes the maximum and minimum effects.  In some instances the resulting effect is very marked, so be careful. At 35mm you may not notice, but at 24 to 15mm you definitely will.
“You cannae change the laws of physics, Jim”
 drsnoopy's gear list:drsnoopy's gear list
Canon EOS RP Canon EOS R5 Canon EOS R10 Canon EF 100mm F2.8L Macro IS USM Canon RF 35mm F1.8 IS STM Macro +10 more
Thank you for the information.
I’m planning on getting this filter this week sometime.
