First nine days with R6II
Started 3 weeks ago | Discussions
Kokopelli_Rocks
Kokopelli_Rocks Veteran Member • Posts: 3,661
Re: First nine days with R6II
Congrats on the R6II. I am sure you will love the camera.
I am looking forward to hearing more about you experience with the camera.
 Kokopelli_Rocks's gear list:Kokopelli_Rocks's gear list
Canon EOS R5 Canon EF 70-200mm F2.8L IS II USM Sigma 14mm F1.8 Art Canon RF 24-105mm F4L IS USM Canon RF 15-35mm F2.8L IS USM +15 more
Alastair Norcross
OP Alastair Norcross Veteran Member • Posts: 9,874
rp2waiter wrote:
Talking mainly AF and how it sometimes struggles to find the eye in low light in vertical position. Now, I've set Horiz... and Vert... focus points to be the same but it doesn't work great. Also still too much noise at 6400 where I shoot most of the time. I use lightroom to process and usually stay under 50% with NR.
OK. I haven't had any struggles yet, but it's early days. If you use DXO Deep Prime, you can easily go to 25,600. It's much better than LR for NR.
“When I die, I want to go peacefully in my sleep like my grandfather. Not screaming in terror, like the passengers in his car.” Jack Handey
Alastair
http://anorcross.smugmug.com
Equipment in profile
 Alastair Norcross's gear list:Alastair Norcross's gear list
Canon G7 X II Canon EOS M6 II Canon EOS R7 Canon EOS R6 Mark II Canon RF 35mm F1.8 IS STM Macro +24 more
Alastair Norcross
I think I see what the issue is
I've been playing around with my screen resolution, and it's set at the next to the lowest image size setting (so next to highest resolution). If I increase the image size, by making the monitor, which has a 2560 X 1440 max resolution, behave like a 1920 X 1080 monitor, I can see the diagonals at 100%, just about when looking quite close. I'm talking about the image of the cat with his tongue out, looking at his whiskers. I tried a couple of different resize methods, and I think the bilinear method on PL6 gives slightly smoother results than the default, which is bicubic sharper. I also processed the image without resizing, and don't see the diagonals on that one. Here's the non-resized image (it is cropped a bit):
And here's the original version I posted, which is bicubic sharper resized to 2000 pixels on the longer side:
And here's the same one, resized with bilinear:
I can't see how that looks at 100% until I post this, and then look at the images on DPR's site. So I'll come back in a minute.
I've just had a look at 100%, and I can definitely see a difference between the original bicubic sharper resize and the bicubic linear resize. If I set my monitor to behave like a 1920 X 1080 monitor, I can see some diagonals at 100%, more so on the bicubic sharper version, but not on the original (non-resized) size version. At the default resolution, which is 2240 X 1260, I don't see them, and not at the monitor's maximum resolution either. It looks like some resolution settings are showing the images at 100% as if they were really more like 150% or 200%. It also looks like the resizing algorithm is what is introducing the diagonals, which are only visible at certain screen resolutions, at least on my iMac.
Alastair
Canon_Guy
Canon_Guy Senior Member • Posts: 1,486
Alastair Norcross wrote:
Canon_Guy wrote:
Congrats to a new camera.
There seem to be quite a learning curve of working with R6II files. Please do not take it personally, I only write it openly.
That's fine. Feedback is always appreciated, even when not agreed with.
Colors of the first photo are scary
I did wonder whether to adjust the white balance for this one, but that is how it looked in the restaurant. This one (also in my OP) was taken at the same time, but facing the other way (the woman was the one who took the one of us):
The lighting facing us was different. Here is the version of us, taking the white balance off the white lettering on my shirt:
And here's one taking the white balance off the mat:
I agree that both are less 'scary' than the first version I posted, but they are also less like what the lighting actually looked like facing us. On balance, I prefer the look of the first of these two reprocessed ones, though, so thanks for prompting me to make the change.
I think it is not so much about the wrong WB. In situations like that with the strong natural light coming from the left side and the artificial light from probably bulbs there is no right way how to setup the WB. You set it up for the light from outdoor and the rest is hell orange. You set it up for bulbs and the rest is hell blue. Usually something in between with rather decreased oranges (a bit!) and overall saturation works the best.
The major problem with colors on this photo is way extreme darkening of highlights, very decreased contrast and perhaps some kind of a HDR filter applied. All of them crushed natural balance between what should be really light and what should be darker - natural gradations.
It is most obvious on the flower at the top left corner. Parts of its leaves which are lit directly should be very bright. And you made them dark greyish...
The same applies to the lady's cheek. Way too darkened out of proportions with the rest.
Overall the picture seems to be kind of greyish and foggy. In the real it must have been very contrasty, colorful and vibrant thanks to the strong light from outside.
It is very hard to work on the JPG with all the lost highlighs (which are the biggest issue here) and drastically reduced color ranges but adjustments going this direction makes the photo less foggy and scary to me :
Hmm. I like the faces here, but the rest now looks wrong.
Sure. Because --- read above --- "It is very hard to work on the JPG with all the lost highlighs (which are the biggest issue here) and drastically reduced color ranges"
and majority of pictures are way oversharpened (glowing halos around edges, washed out colors on edges).
Now this I don't see at all (except maybe a little in the last shot). Sharpening halos are caused by USM sharpening,
Only when done improperly.
Yes, of course.
Otherwise no halos with USM. It is all about the right balance of its sliders. And also (with less sharp lenses which might not be your case) about understanding that when the picture simply is not sharp from the camera/lens combo, you never get that sharpness in.
which DXO doesn't use (at least I don't use it with DXO). All these just use the standard DXO lens corrections, which incorporates their own sharpening (not USM, which they include as an option if you want to use it). I don't add anything to that.
Yes, these were my finding from couple of months of using the DxO. That its way of standard processing is too processed, looking unnatural.
Well, that's certainly a matter of taste. I find the results from DXO to look far more natural than other processors I've used.
Pity not shown here.
As on the lady's hair on top of hear head on the above picture. No halos there but the level of cogged stairs like diagonal lines is just too much. Hair don't look like that.
Same applies to the cat's whiskers.
I'm afraid I'm not seeing any of this.
Really :-)? Honestly I've never seen hair like this. You did :-)?
(enlarged to 400% to avoid blurring the stairs by your monitor)
It doesn't show up at 100% on my monitor, at least not from the viewing distance I intend.
That is very strange to me since it hits my eyes without any observation. That's why I went "oh, how can he not to see it" :-).
Same plus the halo I mentioned applies to the writing (I did enlarge it to 200% but it is very obvious and distractive even at 100%):
Now this must be down to monitor differences. I see just the level of pixellation that you expect at 200%. At 100% I don't see anything.
Your monitor really does not show the clear white glow around the black lines on the below picture when viewed at 100%?
Not from a normal viewing distance, no (I don't view my screen from closer than about 18 inches).
Mine is about 16-17 in, which is basically the same.
Or the branches on the last picture? If not, than it explains the whole issue here.
In that case your monitor somehow blurs fine details. That explains why all the samples here are oversharpened as you try to suppress the lack of actual monitor sharpness by sharpening the image.
The same oversharpened artifacts acompany all the shots. The tree bark, the squirrel fur... Way too much micro contrast, my eyes hurt while looking at it. It would look much more natural if the same way of sharpenng was pulled down from 100% to 40-50%.
I've examined all these at 100% on my monitor, and see a lot of detail, but no sharpening artifacts, and no sharpening halos.
Come on....
No, really.
Now I see, we have the explanation above.
I think what you're seeing is the very good amount of detail that's possible with the R6II and DXO. Coming from different combinations, it can be easy to see actual good sharpness as oversharpening. A couple of the shots have a bit of glow on some edges, but not on the plane of focus, so not caused by sharpening. What you're probably seeing there is a bit of LOCA.
The last one shows it the most evidently.
Yes, this one might need a bit of toning down. Although DXO is an excellent processor,
I am not convinced at all neither from my own experience neither from you examples.
Well, some people just don't like DXO. It's all a matter of personal taste.
one thing it doesn't do as well as Lightroom is show you exactly how an image will look before you process it (because the processing takes a lot of power). You can only see small previews of bits of the image with all the settings applied. I adjusted a couple of settings on this one (turned down the smart lighting from medium to slight, turned down the clear view (PL's version of LR's dehaze) a bit, and turned down the microcontrast (PL's version of LR's clarity) a bit too). This is what it looks like now:
Compared with the earlier version:
I'm actually not sure which of these I like better. It's up to individual taste, but thanks for pushing me to at least try it differently.
Or is it the DxO what performs that badly? Also the HDR on the last picture is patchy in the sky and trees and poorly handled
I think what you're actually seeing here is the patchy clouds in the sky. Notice the difference between the trees closer to the sun, and the ones on the left near the top. The top left corner was the only part of the sky with no wispy clouds in it at that time.
Well I mainly mean the halos around branches where the blue is lighter at some distance exactly around the shape of branches. And also of course the strong white glow at the edges of branches.
- most probably it is the DxO thing too.
Looking on the DPR's samples gallery I am sure R6II can deliver WAY better results. It is just about a good SW and its correct using. Which can be learned at the end quite easily.
Thanks for the feedback, even though I disagree with most of it. It's also possible, of course, that the images look different on different monitors.
This might be part of the issue. Many people do not have properly hardware calibrated monitors with the correct white point value.
Also many monitors suffer from lack of the microcontrast between individual pixels or are just blurry.
Also there still is terrible amount of TN panel monitors which are completely unusable for any photo work.
I do not think these might be your case - I suppose you have an up to date monitor corresponding to your photo gear.
I've had the experience before of one or two people saying my images looked oversharpened, and others saying they didn't. So it could be a difference in viewing medium. A lot of it is also down to individual taste. I've been processing digital images for over twenty years, with Photoshop and Lightroom, and DXO. My tastes change a bit, but I've got my DXO settings to where they mostly give me the results I like. I know what oversharpening, for my taste, looks like, and I know what detail extraction looks like. I'm happy with the detail that DXO gives me.
Of course that colors and sharpness are strngy the matter of the individual taste. But these glowing edges or edgy stairs like diagonals are just wrong objectively. Things don't look like that.
Well, they don't look like that to me either on these images. Another possibility is that whatever DPR uses to host images is doing something.
Impossible. If it was true, all pictures from all posters would look like this. But they don't.
I appreciate the time you've put into it, and I understand your preferences here (though I don't share most of them). But I'm rather puzzled by some of what you're saying, because the images simply don't show those features on my monitors (all iMacs).
Yes, that is pretty much possible.
There are certainly differences between how they look hosted on DPR and how they look when viewing with something like Preview on my Macs, but I'm not seeing the diagonal effect you describe in either place. The hair and whiskers, for example, all look completely natural to me.
Don't you have any kind of up/downscaling, smoothing, read assistence or whatever turned on on your graphic card? Or any other "graphics enhancements" turned on?
I don't think so, unless the iMac turns it on by default. I've always liked the way the retina monitors on my iMacs look, and haven't messed with them. I've just checked the system settings and don't see anything about smoothing adjustments. You can adjust the scaling, but I leave it on the default for the iMac display. The adjustment just seems to make text and images bigger or smaller. If you're seeing stair-stepping at 100% view, your scaling is probably producing bigger images than mine.
Well, my scaling is correct - meaning native. The display is 2560x1440 and the graphic card sends 2560x1440 on it. So 1:1, no scaling.
Just to check, when you look at a 2000 pixel wide image at 100%, how wide is that on your monitor (cm or inches)?
Measured it is approx 46.5cm.
Counted it is 46.6cm: display width is 59.7cm or 2560px. Meaning 1px is 0.0233203 mm, so 2000px is 46.6cm.
Cause it is obvious now that what you see on your monitors is not as sharp as it should be. So you oversharpen the image to look good on your monitor. But when viewed on proper monitor (Eizo CG on my side) it shows the real state.
If you have nearby any graphic studio or photo gear shop with quality HW calibrated monitors, try to take you photos on a USB stick and have a look at them there.
I could do that. But you seem to be making the assumption that how things look on your monitor is how they are 'supposed' to look.
Assumption? No. Why?
The resolution I use is native and Eizo's CG line can hardly be considered as inacurrate. Also my prints look pretty much the same sharp wise on my home printer (Canon PRO-100) as well as on the commercial prints I'm doing time to time.
Also pictures in DPR's sample galleries look pretty much the same as mine in sharpness and details. Which BTW can not be same in your case - if it really is down to your monitor, DPR's sample galleries should look notably less sharp and detailed than images processed by you. DPR also uses ACR same as me and I would not blame them from inability to process images properly .
So it is not an assumption, it is just a logical conclusion.
I process my pictures to look like I want them to look on the medium I use. Most of the people I show them to seem to have similar hardware to me, and like how they look on that. It's possible that they would look quite different to me on your hardware. But then, if I processed them to look like how I want them to look on that hardware, they might look worse on other people's.
Yes, I fully understand.
Still on your place I'd rather be interested what is it wrong with your system when it displays something else than how the files look in reality. Just for the matter itself.
You can see the edgy diagonals and white halos when I upscale the image to 400% but you don't see them when at 100% although they are also clearly visible. Logic implies there must be something wrong on your system at 100%.
Imagine that you always print on high gloss paper, and I always print on Photo Rag. It's quite possible that a file of mine that looks good printed on Photo Rag would look less good printed on high gloss, or vice versa.
I'm open to suggestions, but I'm reluctant to make changes based on how my images look on equipment that most people don't have. As all the tutorials point out, digital sharpening should be tailored to the output medium (so usually different for prints versus monitor viewing, for example).
This all are valid points. But I am that kind of person that with that expensive and top quality gear it would annoy me knowing that my files actually look different than what I see.
Of course, it might be that most people have hardware like yours, and are just being polite when they say that my images look good. I'll try to look at some of my images on someone else's monitor, to see whether I see a difference.
All in all it is just an interesting issue :-).
 Canon_Guy's gear list:Canon_Guy's gear list
Canon EOS R6 Canon EF 70-200mm F2.8L IS II USM Sigma 14-24mm F2.8 DG HSM Art Sigma 105mm F1.4 DG HSM Art Canon RF 24-105mm F4L IS USM +6 more
Canon_Guy
Re: I think I see what the issue is
OK, so we are at home now :-). You do use downscaling and that most probably causes the problem. Because your computer is not showing you 1:1 image but is downscaling it to a lower resolution. And this downscaling algorythm somehow works with sharpness and details.
The only correct way is to go with the native resolution. So set the monitor to 2560x1440 and forget :-).
No, never use other than native resolution.
This one below (the original) looks very fine.
And here comes the issue. The original image is already sharpened. Now after downsizing it you sharpen it for the 2nd time. Which should not be done. The correct workflow for the best control over sharpening (and its artifacts) is to have the original not sharpened at all. Then downsize it to the desired size and apply sharpening corresponding to the target resolution.
Bicubic sharper tends to be too aggresive, which is somehow confirmed here.
This one not too bad.
Most probably. So leave the native and that is the best you can do for fidelity of what you see.
Alastair Norcross
Yes, of course.
Come on....
No, really.
Well, this is all based on the idea that there is a single way that images are 'supposed' to look. I also use the PRO-100 printer, and my prints look pretty much the same in sharpness as my screen images, at least when printed on glossy paper. There is, of course, a difference with matte or photo rag paper.
Well, there is no such things as how files look 'in reality'. There is only how they look when displayed on various media. The files themselves, of course, are digital.
No, not really. If 'logic' (one of the areas I have professional training in) implies anything, it is that some things that are visible at 400% are not visible at 100%, which is entirely unsurprising.
Yes, but my point is that my files only look different from what I see, when viewed on other equipment. Your files probably look different on my monitor from what you see on yours. I did have a look at some of the shots you posted in another thread, and they are very nice shots, but certainly don't look as sharp on my monitor as I would like. I presume it doesn't bother you that your files look different from what you see when viewed on some other monitors. That's because you think the way they look on your monitor is how you want them to look. It's the same for me. You mentioned looking at samples in DPR galleries. You'll notice that there are always disagreements among the commenters about how sharp those images are (among other things). That suggests that there's quite a range of viewing hardware out there.
Alastair
Canon_Guy
Have to go sleep, it is well past midnight and tomorrow we go to ski to Alps.
I will stay tuned later :-).
Alastair Norcross
So you think I should also not resize pictures for web viewing? The files can be quite unwieldy at original resolution.
Alastair
Canon_Guy
Native monitor resolution (2560x1440). Not native photos resolution .
See ya
Alastair Norcross
See ya
Thanks. Yes, I have now set my monitor to its native resolution.
Alastair
Justme Forum Pro • Posts: 22,435
Great to hear you are enjoying the new camera.  I know the feeling.  Great pics.
I know you mean well but please do not embed my images into the forum. Thanks for respecting that.
http://www.pbase.com/golfpic/some_recent_shots
http://www.pbase.com/golfpic/a_red_fox_family
http://www.pbase.com/golfpic/image/55043863/small.jpg
Canon_Guy
See ya
Hi Alastair,
so how is you experience now when you finally got your monitor set correctly? You should see the difference clearly now.
Having set the monitor to a non-native resolution forces it to rescale the image. The unavoidable side effect is blurring the image. It is similar to the situation you would take every of your shot slightly out of the focus and then tried to sharpen it in the post. Does not make much sense.
Hope it helped you to proces your files correctly now :-).
The Bad Photographer Regular Member • Posts: 142
Cat's eyes are nice and sharp
Focus on the cats looks great.
 The Bad Photographer's gear list:The Bad Photographer's gear list
Canon PowerShot G16 Canon EOS 6D Canon EOS RP Canon EF 85mm F1.8 USM Canon EF 17-40mm f/4.0L USM +4 more
