Banding Issues with Artificial LED Lights
Started 3 weeks ago | Discussions
Shooters on My Squad Regular Member • Posts: 381
Since two years I’ve been fighting banding issues on the Canon EOS R5 with artificial LED lights.
The basic theory is easy: Use a shutter speed 1/x for a frequency y of the PWM LEDs where you can divide y / x with no remainder.
Let’s take Philips Hue as an example where the light bulbs operate at 1 kHz. In this case shutter speeds of 50, 100, 125, 200, 250, 500 & 1000 should work without any banding at all. But I still get banding e. g. at 250, which shouldn’t be the case here as 1000 / 250 = 4. The banding gets better at 250, compared to let’s say 400, but it is still visible, usually in burst shots with uniform backgrounds.
It doesn’t matter if I have “Anti-Flicker Shooting” on or off (which accordingly to the manual only works for 100 & 120 Hz, so no wonder), and when I press the Info button when checking for flicker it doesn’t detect any.
The first thing that puzzles me is why the formula doesn’t work for the R5 body.
The second important thing that I want to mention is that I use several bodies from different manufacturers like Fujifilm, Ricoh, Olympus etc. but only the R5 exhibits this behavior.
How do you deal with uncontrollable LEDs on your camera bodies? Do you see any difference between manufacturers, or even different bodies by the same manufacturer?
 Shooters on My Squad's gear list:Shooters on My Squad's gear list
Canon PowerShot G5 Ricoh GR III Olympus TG-6 Canon G5 X II Ricoh GR IIIx +41 more
Canon EOS R5
mollyc Forum Member • Posts: 95
Re: Banding Issues with Artificial LED Lights
Are you using electronic shutter? You have to use mechanical shutter to alleviate banding.
 mollyc's gear list:mollyc's gear list
Nikon Z6 Nikon Z6 II Fujifilm GFX 50S II Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II +13 more
OP Shooters on My Squad Regular Member • Posts: 381
Yes, I use MS which gives me slightly better results than EFCS (where many people on the internet say that both shutter types should be affected by banding in the same way, something that I cannot confirm).
I’ve seen some posts here on the forum, some of them more than four years old, but nobody seemed to have a satisfying answer. I hope some smart photographer can help me out this time.
I’ve also read several times that Philips Hue modulates at about 600 Hz, but this is also not true in my case. I can just point a phone with the camera app open at the light source, and I immediately see the effect of different shutter speeds on the screen without even recording.
It would be also good to know why I observe this behavior mainly on the R5, and why all of my smaller sensor bodies don’t seem to be affected by that issue (slower sensor and / or slower sensor readout time?).
teejaywhy
teejaywhy Contributing Member • Posts: 552
Perhaps try genuine LED lights.
 teejaywhy's gear list:teejaywhy's gear list
Nikon D750 Olympus E-M1 III
As I mentioned in my initial post, my question is about uncontrollable light, often in dimly lit environments (I gave Philips Hue just as an example to keep things simple, because it is quite common these days).
I just don’t get it how some bodies seem to be able to defy physics. What’s going on here?
tbcass
tbcass Forum Pro • Posts: 57,147
You didn't get the joke, did you? That out of the way I have never had that issue with any of my Sony cameras. I don't know what Sony does to prevent it.
Tom
 tbcass's gear list:tbcass's gear list
Sony RX100 Sony RX10 IV Sony a99 II Tamron SP AF 90mm F/2.8 Di Macro Tamron SP 70-300mm F/4-5.6 Di USD +7 more
I’m still contemplating until God will send me a truly genuine, fully natural light-emitting diode down to earth
But let’s be a little bit more serious again. I don’t know what kind of information would help to mitigate this issue. MS works best for me, with EFCS a close second. Fully ES will give you that typical banding, and it gets worse the faster your shutter speeds are. I’m not sure which kind of settings besides Anti-Flicker, shutter speed, and shutter type could affect banding?
BobKnDP Senior Member • Posts: 3,140
I presume you're getting 50Hz power. That would cause the LEDs to flicker at 100Hz.
You'd like to have an integer number of cycles in the exposure. Which means that you want the exposure time to be an integer multiple of 10ms.
1/100s, 1/50s, 1/33s, etc.
In your usage, x/y with no remainder.
I think if this would be caused by power it would be 120 Hz, but PWM LEDs should run on their own cycle, with cheaper LEDs usually running at a lower frequency.
I think I should get massive banding at 1/1000 when pointing my phone at the LED if you were right, but instead I get uniform images in the camera app?
And to further underpin my argument that it should have nothing to do with the power cycle, I’ll refer to my first post where I described the “Anti-Flicker Shooting” setting behavior. I would assume that the camera would detect something if it would be dealing with a 120 Hz cycle, but it doesn’t do it. No matter if I point the camera directly at the light source, or slightly nearby, a press on the “Info” button in the corresponding Quick Control menu just gives me negative feedback.
Still wondering what is going on here with the Canons, and why other manufacturers seem to handle this issue better? This kind of makes a professional camera unusable in amateurish conditions, if you’re not OK with image degradation due to banding issues.
Where are you?
In the US, power is 60Hz. In the UK, 50Hz.
I don't know how PWM LEDs are driven, I admit. Some old dimmers used to control the current within a cycle of the AC power. There were no lower frequency effects.
Victor Engel Forum Pro • Posts: 20,968
That formula should work if the camera's idea of frequency exactly matches the LED's idea of frequency. Especially for cheap LEDs, I bet there's a mismatch. And that's probably the main source of your issue. Unfortunately, your camera probably is not very tunable (there are discreet values you can choose from), and the LED lighting probably has only one frequency, which, if you're lucky, is constant. But there's likely to be a mismatch.
https://www.youtube.com/watch?v=DdToSNgPnO8
Notice in this video that when the frequencies match (60 Hz) the light gradually changes. That's because they're not both at exactly 60 Hz.
Then there are light sources like with some of the new M1 Macs that vary the frequency of the display to save on battery (maybe it's not the light source but the pixels that vary in frequency). Such is probably not the case for LED lighting, though.
Victor Engel
 Victor Engel's gear list:Victor Engel's gear list
Canon EOS 5D Canon EOS 5D Mark II Canon EOS 600D Canon EOS 5DS Canon EF 50mm F1.8 II +13 more
