The Sigma 18-50 is wonderful on the X-E4
Started 4 weeks ago | Discussions
Nunataks
Nunataks Regular Member • Posts: 234
23
Sigma 18-50mm F2.8
Antique Eruption
Antique Eruption Regular Member • Posts: 167
Re: The Sigma 18-50 is wonderful on the X-E4
You're putting it to great effect here. Superb.
tater8 New Member • Posts: 10
Have you noticed any exposure inconsistencies at the long end of the zoom as others have seen and described here:
https://www.dpreview.com/forums/thread/4692974
DarnGoodPhotos Forum Pro • Posts: 11,881
According to my quick test, yes and no.
Auto ISO, f2.8, Spot Meter on a wall; no difference in ISO between 18mm and 50mm
However, with auto shutter speed the exposure is changing.
www.darngoodphotos.com
 DarnGoodPhotos's gear list:DarnGoodPhotos's gear list
Fujifilm X100V Fujifilm X-T5 Fujifilm XF 18mm F2 R Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 27mm F2.8 +3 more
Nunataks
OP Nunataks Regular Member • Posts: 234
I didn't notice anything weird while out shooting last weekend.
Can you try shooting in A mode at a set ISO at 50mm using f2.8 and then see if just changing to f4.0 results in the shutter speed time doubling as would be expected?
IParks398 New Member • Posts: 5
This does happen with mine on my xt20, but I don’t think I would have noticed if I hadn’t sat going through F stops and focal lengths.
I’ve used this lens pretty extensively now and I can’t say I’ve noticed it being an issue in real world shooting. It’s such an impressive lens overall that I can live with the odd quirk.
NickD81 Regular Member • Posts: 172
Lovely photos! How's the handling of the 18-50 on the X-E4? Do you use the additional grip / thumb rest? Considering picking up this combo myself.
 NickD81's gear list:NickD81's gear list
Fujifilm X100V
jrmacd Regular Member • Posts: 174
Very nice pictures, and you had me sold . . . until I looked and saw the 18-50 has no stabilization. I just use my X-E4 too often in low light, and my hand-holding skills only get me to around 1/60, 1/30 if I'm lucky. Maybe if a possible  X-E5 comes with IBIS. I've been thinking about the 18-55, but constant 2.8 is very appealing.
 jrmacd's gear list:jrmacd's gear list
Fujifilm X-T4 Fujifilm X-E4 Fujifilm XF 18-135mm F3.5-5.6 R LM OIS WR Fujifilm XF 50-140mm F2.8 Fujifilm 16-55mm F2.8R LM WR +6 more
Nunataks
It honestly balances perfectly without anything. It's such a light lens and is around the same size as the Fuji 18-55.
Tamaron has a stabilized 17-70 f2.8
Tom Schum
Tom Schum Forum Pro • Posts: 13,282
Beautiful sample set!
Tom Schum
"Beware of taking advice from anonymous wise men." Quote from Anon.
Fujifilm X30 Sigma dp0 Quattro Panasonic ZS100 Fujifilm X-T3 Fujifilm X-E4 +14 more
Erik Baumgartner Senior Member • Posts: 6,893
So bump up the ISO a bit. I have no trouble with my unstabilized 16-55 in low light at all. I’d much rather have constant f/2.8 than stabiized f/4. There’s almost always something moving that requires a faster (handholdable) SS anyway.
Sony RX100 Fujifilm X100V Fujifilm X-T2 Fujifilm X-T20 Fujifilm XF 35mm F1.4 R +5 more
Tom Schum
Looks like it is about $200 more. Also the weight and the length might be greater. Does anyone know how well it works?
Tom Schum
Michael Everett Senior Member • Posts: 2,054
I have both lenses and I would say the IQ is excellent on both, although I have not made a direct comparison. I can say that both are noticeably better than the 16-80. The main difference is size. The Tamron is considerably larger and heavier than the Sigma, although you do get a longer zoom range.
Ric Cheng Regular Member • Posts: 338
Tamron is better than Sigma, reasons :
- focus length 17-70
- with image stablization
Sigma is better than Tamron, reasons :
- small size and weight
- price
For X-E4, without ibis, Tamron is a better choice
For X-S10 with ibis, Sigma is a better choice
max2331 Regular Member • Posts: 101
You must be kdding.
Check the size comparisson (on Sony because the app doe not have the lenses for FUjifilm yet)
https://camerasize.com/compact/#809.1049,809.955,ha,t
The Tamron is ridiculous on any Fujifilm camera except the X-Tx or X-Hx
 max2331's gear list:max2331's gear list
Fujifilm X-S10 Fujifilm XF 23mm F2 R WR Fujifilm XF 16-80mm F4
ChrisGibbons001
ChrisGibbons001 Regular Member • Posts: 234
Some beautiful photos, colours on the day photos are perfect.
@bychrisgibbons
@chrisgibbonswildlife
 ChrisGibbons001's gear list:ChrisGibbons001's gear list
Fujifilm X-T5 Fujifilm XF 23mm F2 R WR XF 150-600mm
