R7 in camera lens corrections?
Started 3 weeks ago | Discussions
Dave C 150 Regular Member • Posts: 320
Being relatively new to Canon do these take place with all formats of shooting i.e. raw and all jpeg settings? e.g. Apparently the 16mm f2.8 RF needs a lot of distortion correction and I wouldn't want to mess around in pp with a load of raw files correcting it.
 Dave C 150's gear list:Dave C 150's gear list
Sony RX10 IV Pentax Q Nikon D500 Canon EOS R7 Sigma 105mm F2.8 EX DG OS HSM +6 more
Canon EOS R7
Sittatunga Veteran Member • Posts: 5,406
Re: R7 in camera lens corrections?
No it doesn't. But DPP4 automatically corrects the distortion too (it makes no difference if you switch that lens correction off, though you can switch off the Digital Lens Optimizer, the Diffraction correction, Color blur and Peripheral illumination and see differences).
My DxO PhotoLab is set up to automatically apply all lens corrections.
Canon_Guy
Canon_Guy Senior Member • Posts: 1,486
As far as I know all RAW processors allow to bach process files, meaning turning on/off the lens corrections and their strength for all pictures at once.
 Canon_Guy's gear list:Canon_Guy's gear list
Canon EOS R6 Canon EF 70-200mm F2.8L IS II USM Sigma 14-24mm F2.8 DG HSM Art Sigma 105mm F1.4 DG HSM Art Canon RF 24-105mm F4L IS USM +6 more
OP Dave C 150 Regular Member • Posts: 320
Thank you.
Thanks.
drsnoopy Senior Member • Posts: 1,216
In-camera lens corrections only apply to jpeg images, and to the the jpeg preview embedded in a RAW.  For some lenses, these cannot be turned off, and the reason for that is so that you see the corrected view via the EVF and LCD.  However the RAW file will still show the uncorrected image with the distortion, and you need to apply a profile when processing.  Canon DPP applies exactly the same correction as the camera body.  Lightroom and DXO PL (and others) have their own correction profiles which are not exactly identical.  You can set your RAW processor to apply correction by default.  If you only use jpeg, you don’t need to do anything.
 drsnoopy's gear list:drsnoopy's gear list
Canon EOS RP Canon EOS R5 Canon EOS R10 Canon EF 100mm F2.8L Macro IS USM Canon RF 35mm F1.8 IS STM Macro +10 more
Alastair Norcross
Alastair Norcross Veteran Member • Posts: 9,874
I strongly recommend using DXO for the 16 F2.8. The results are remarkable. You get sharpness pretty much across the whole frame. I have DXO Photolab set up so that lens corrections are automatically applied to all camera/lens combinations. I don't have to turn anything on.
“When I die, I want to go peacefully in my sleep like my grandfather. Not screaming in terror, like the passengers in his car.” Jack Handey
Alastair
http://anorcross.smugmug.com
Equipment in profile
 Alastair Norcross's gear list:Alastair Norcross's gear list
Canon G7 X II Canon EOS M6 II Canon EOS R7 Canon EOS R6 Mark II Canon RF 35mm F1.8 IS STM Macro +24 more
RDM5546
RDM5546 Senior Member • Posts: 3,654
With DXO you can correct in DXO  to any degree desired.  They do great job so none of the new lenses with horrid corners are dealt with no intervention.  DXO is my goto editor for RAW files.
 RDM5546's gear list:RDM5546's gear list
Canon RF 100-500mm F4.5-7.1L IS USM Canon G5 X II Canon EOS 70D Canon EOS 7D Mark II Canon EOS 5D Mark IV +47 more
