The best laid plans
Started 4 weeks ago | Discussions
silversportsman Forum Member • Posts: 76
The best laid plans
So I have had the plan to capture a photo of a sail boat that has run up on to a gravel bar on the lake near me, and has been there all winter. The sails have shredded from the weather and wind, and the water levels have been a little to high for me to get the position I want - until today. I normally just snap photos that are more opportunistic rather than planned. But this one was worth a little more thought. So I noticed the water levels were perfect when I was at the lake yesterday. I checked the sunrise time and planned my arrival and position with 15 minutes to spare. The sunlight was surreal this morning as it crested the top of the cedars behind me and the scene was spectacular. I proceeded to mount my 16mm/1.4 and make sure my settings were exactly where I wanted them, when... Nooooooooooooooooo!!!! No memory card, please insert a new card!!
I never do this, but I had pulled the card to look at a couple of shots I took the day before and the card was home mounted in my mac. Lesson learned.
Maybe the weather and water levels will cooperate later in the week, and I can share a capture. What a sinking feeling (pun intended) that was.
 silversportsman's gear list:silversportsman's gear list
Fujifilm X-S10 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 16mm F1.4 R WR XF 90mm
DarnGoodPhotos Forum Pro • Posts: 11,881
Re: The best laid plans
www.darngoodphotos.com
 DarnGoodPhotos's gear list:DarnGoodPhotos's gear list
Fujifilm X100V Fujifilm X-T5 Fujifilm XF 18mm F2 R Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 27mm F2.8 +3 more
ViMa
ViMa Senior Member • Posts: 2,150
When I first read the GR III has internal memory I thought that was pointless, back then. In this case it'd have been a lifesaver.
Vittorio
_________________________________________________
https://www.flickr.com/photos/155724624@N06/
 ViMa's gear list:ViMa's gear list
Ricoh GR III Ricoh GR IIIx
Coldpaw Contributing Member • Posts: 772
Lesson learned :)
I experienced something similar. Packed all my stuff for a day trip to a city in order to do some shooting. Arrived there and noticed the memory card was missing - not too bad, as shops opened and I could buy one. But ever since then I have a spare memory card in each of my camera bags as well as one in my small battery pouch. Those aren't really the highest speed or capacity, but better something with just 16 gigs than nothing at all
Gringostarr Regular Member • Posts: 481
At least you didn't do this when you were hiking in the high sierras all day and you never noticed the warning about no memory card inserted until you were heading back to your campsite.
 Gringostarr's gear list:Gringostarr's gear list
Fujifilm X-E4 Fujifilm XF 16mm F1.4 R WR Fujifilm XF 27mm F2.8 R WR Fujifilm XF 70-300 F4-5.6 R LM OIS WR Fujifilm XF 30mm F2.8 R LM WR +1 more
OP silversportsman Forum Member • Posts: 76
For sure. I feel like the reminder was a gentle one. It stung nonetheless.
Zinch Senior Member • Posts: 1,122
I have 2 SD cards in my X-T5 and never remove both at the same time. With a camera with 2 card slots is as simple as that.
 Zinch's gear list:Zinch's gear list
Fujifilm X-T4 Voigtlander 35mm F1.2 Nokton Fujifilm XF 23mm F1.4 R Fujifilm XF 56mm F1.2 R Fujifilm XF 16-80mm F4 +3 more
a_c_skinner Forum Pro • Posts: 13,047
5
I have an SD card in my wallet against this eventuality.
Andrew Skinner
Fujifilm X-T2 Fujifilm X-E3 Fujifilm X-H2 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R +7 more
Erik Baumgartner Senior Member • Posts: 6,893
For this and other reasons, I’ve been transferring images to the computer directly from all my cameras via a cable since 2003. Never a single problem, and the card never leaves the camera.
Sony RX100 Fujifilm X100V Fujifilm X-T2 Fujifilm X-T20 Fujifilm XF 35mm F1.4 R +5 more
Craig268
Craig268 Senior Member • Posts: 2,005
Not just SD cards; suddenly non-responsive camera/lens, missing or dead battery, etc.
Or the shot no longer exists.  I do a lot of planned shots similar to the OP in that I have visions of a certain shots which are often seasonally and/or weather and/or light dependent.
I set out to do such a shot once when the conditions were right.  Geared up and got to the spot and the scenic decades old steel girder bridge I wanted to frame my perfectly planned shot had been torn down.
 Craig268's gear list:Craig268's gear list
Fujifilm X-T1 Fujifilm X-T10 Fujifilm X-T4 Samyang 85mm F1.4 Aspherical IF Fujifilm XC 16-50mm F3.5-5.6 OIS +11 more
sir_c Contributing Member • Posts: 740
I have the option enabled 'don't shoot without card'. On my xt4 it shows a message on screen when no card is present.
Usually if have enough OCD to flick on and off the camera before I leave, so it happened to me only once that i brought all but an SD.
 sir_c's gear list:sir_c's gear list
Fujifilm X-T1 Fujifilm X-T4 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R Fujifilm XF 18-55mm F2.8-4 R LM OIS +5 more
Now that's a great strategy. Sounds pretty foolproof.
xtm Senior Member • Posts: 1,405
Out comes the cellphone to save the day!
 xtm's gear list:xtm's gear list
Nikon Df Leica M10 Fujifilm X-Pro3
sprouty115
sprouty115 Contributing Member • Posts: 618
Have to give Ricoh credit for that. Like you say, it seems pointless until you need it.
 sprouty115's gear list:sprouty115's gear list
Ricoh GR III
Montanawildlives Senior Member • Posts: 1,845
The first thing I do with a new Fujifilm camera is to turn off "shoot without card."
 Montanawildlives's gear list:Montanawildlives's gear list
Fujifilm X-T1 Nikon D500 Fujifilm X-T3 Nikon AF-S DX Nikkor 35mm F1.8G Nikon AF Nikkor 50mm f/1.8D +7 more
