New R5 firmware in the works?
Started 3 weeks ago | Discussions
JoeSchmoe007 Contributing Member • Posts: 502
Re: My wish list.
RDM5546 wrote:
JoeSchmoe007 wrote:
I just want to be able to turn on the sound when in e-shutter burst mode. I think some of the newer R cameras can do that.
Also would like for the frame rate to be selectable in e-shutter mode - 20/10/5 fps would be perfect.
Since I shoot sports any kind of focus improvement would be welcome.
I expect you will get both the sound and the 20/10/5.....
You are much more of an optimist than I am. I predict we get NOTHING! If there are no further firmware upgrades for an R5 I wouldn't be surprised.
palombian Contributing Member • Posts: 637
Re: New R5 mk2 delayed?
Kokopelli_Rocks wrote:
My guess is Canon is doing a new sensor for the R5 II and it is not ready. I don't think Canon had any plans for a 2023 release of the R5Ii. The release of the R6 II made people think an R5II was coming soon. I think the next R5 will be announced about this time next year. I also think competition and market challenges is forcing Canon to finally do a big R5 firmware update. The R5 has the memory and processing power to support additional features. I personally would like to seem more options for ES beyond the 1 image and 20.
The only body ever receiving a decent midlife kicker was the 7DII.
Maybe the parallel is indeed that Canon has other market segments to fill first and existing users can be kept satisfied for a while.
I will be very glad to use my R5 as long as the 7DII.
 palombian's gear list:palombian's gear list
Canon EOS 7D Canon EOS M6 Canon EOS M100 Canon EOS M6 II Canon EOS R5 +25 more
I am really looking forward to...
... the screen to flip in 2 directions, like a Sony A7 R5. Sony can do that on their R5, why can't Canon??? Should be an easy firmware fix.
Ephemeris
Ephemeris Senior Member • Posts: 1,186
Re: New R5 firmware in the works?
Victor Engel wrote:
Ephemeris wrote:
Victor Engel wrote:
Ephemeris wrote:
Victor Engel wrote:
Ephemeris wrote:
Victor Engel wrote:
How about the ability to turn on lens IS with body IS turned off? It seems it would be so simple to implement.
Do you not think many of the systems would be affected?
How so? The IBIS already is locked if lens IS is turned off. So what would be so difficult about keeping it locked if some firmware switch were enabled instead? Six of one, half a dozen of the other, it seems to me. What am I missing?
If the IS is on does the IBIS have to run?
Obviously not, since it doesn't have to run on my 5DS.
This is a question regarding the R5.
So, for the R5, if the IS is on does the IBIS have to run?
Yes, the way the firmware is written - so update the firmware.
Do you know how the firmware is written? And, if I may, you are absolutely certain of this?
Your 5Ds and my old 5DS I've found IBIS not very beneficial but fantastic battery life.
My R5 disappointingly runs out of battery just sitting on the shelf with the switch turned off. They should fix that, too.
Interestingly batteries discharge on a shelf as well but hopefully one day that will be fixed.
Out cameras are almost used daily and I've never measured it's Q current. Keep it cool and low humidity may help (may not becuase if the Q current is high then it won't be relavant).
Victor Engel
Ephemeris
Re: I am really looking forward to...
You could maybe remove it and make it totally portable 🙈
Victor Engel Forum Pro • Posts: 20,968
No.
Does it matter?
The batteries last WAY longer in my unused 5DS than in my unused R5. Like a couple orders of magnitude longer. What in the world is the R5 doing when not in use that uses so much battery?
I have two 5DSs and one R5. I sometimes go for a period of several days using only one or the other. That's when the battery runs down while the camera is off.
Victor Engel
 Victor Engel's gear list:Victor Engel's gear list
Canon EOS 5D Canon EOS 5D Mark II Canon EOS 600D Canon EOS 5DS Canon EF 50mm F1.8 II +13 more
Edymagno Veteran Member • Posts: 3,694
The ability to go up to 4 minutes in Tv.
Easy.
But not gonna happpen
Edu
 Edymagno's gear list:Edymagno's gear list
Sony RX100 III Sony a6000 Canon EOS R5 Sony E 30mm F3.5 Macro Sony E 50mm F1.8 OSS +6 more
SigZero
SigZero Contributing Member • Posts: 686
No.
Does it matter?
Because in R5 there is a lot of functions that can stay enabled even with switch set to OFF (it's a soft switch). Bluetooth and wireless is just an example. Can be disabled.
In DSLR the battery is used to power mechanics and electronics mostly during taking a shot. In Mirrorless its much more systems that work continuously.
Accept that ML take much more power or stay with DSLR. Your choice. Not much to change in firmware.
Br, Pawel
My photo-blog: http://pawel.online
 SigZero's gear list:SigZero's gear list
Canon EOS R5 Canon RF 100-500mm F4.5-7.1L IS USM Canon RF 70-200 F4 L Canon RF 14-35mm F4L IS USM Apple iPhone 13 Pro
SigZero wrote:
No.
Does it matter?
Br, Pawel
Hmm - I'll look into disabling those. I got my work phone (used for iOS development) which doesn't even have a SIM card to last much longer by putting it in airplane mode. It turned out most of the battery was used in trying to acquire a signal.
When I'm not using my camera, the only function I need to work is the clock, which should use no more power than a watch uses. It should last for weeks.
Victor Engel
antonio-salieri Regular Member • Posts: 208
I keep my R5 in airplane mode, except when I am actively using its wireless features (which I do, for example, when using my phone as a trigger while having it on a stand doing preservation photography, so I can just manipulate the object and save the time of getting up).
I know it's possible to use your phone as a GPS, too, or a dedicated accessory. Some people may use that. For me, it's never been a concern and I'd rather not spend the battery on that.
R5 batteries usually last me a good long time, though I also have the grip, which I use more for its physical attributes with the battery life coming as a bonus.
 antonio-salieri's gear list:antonio-salieri's gear list
Canon EOS 5D Mark III Canon EOS R5 Canon EOS R7 Canon EF-S 18-55mm f/3.5-5.6 IS STM Sigma 50mm F1.4 DG HSM | A +14 more
Tazz93
Tazz93 Veteran Member • Posts: 3,473
Getting the life I got out of the 7D2 would be great, but honestly, I bet the next few years will see significantly more advancement, so that might be tough.
Which update are you referring to on the 7D2, I don't remember any significant updates other than the WiFi card compatibility?
 Tazz93's gear list:Tazz93's gear list
Canon EOS-1D Mark II N Canon EOS 5DS Canon EOS R5 Canon Extender EF 2x II Canon EF 70-200mm F2.8L IS II USM +11 more
I just turned on airplane mode. I hadn't seen it before because the options on that menu didn't interest me. I'd have been happier if it was airplane mode on by default. I guess I should check all menus whether or not I'm interested.
Also, it's counterintuitive that the camera uses those radios when the switch is turned off.
Victor Engel
Ephemeris
No.
Does it matter?
I am trying to understand if what you have said is known to be correct or it's something else.
I am also trying to understand if we can ask you other software/system questions relating to the R5.
So for that yes.
I was hoping you would be able to tell us 🤗
Do you have any data on how long a single full battery will last in your R5 without use? I would guess I've gone 7 days on a rare occasion.
Do you have airplane mode on?
Victor Engel
I do now. I did not until today. Until now I was working on the maybe erroneous assumption that with the camera turned off, this setting was irrelevant. I can't think of any use to use any radio when the camera is turned off. Turning the camera off should turn off the radios. An exception would be a GPS, which may need time to acquire satellites, but the R5 has no GPS.
Victor Engel
Ephemeris
Like many devices it's similar to a standby. In this case the camera allows the WiFi connection to stay connected when off. To do this it must keep the BT radio on.
See page 597 of the advanced user manual.
I would suggest this is a majority of the power usage when off but not all.
Victor Engel
Agreed -nt
Victor Engel
Kokopelli_Rocks
Kokopelli_Rocks Veteran Member • Posts: 3,661
Canon is planning a dealer meeting to announce new R5 firmware
Latest rumor is that Canon is planning dealer meetings about the new R5 firmware.  First time Canon has held dealer meetings for a firmware update in many years.
 Kokopelli_Rocks's gear list:Kokopelli_Rocks's gear list
Canon EOS R5 Canon EF 70-200mm F2.8L IS II USM Sigma 14mm F1.8 Art Canon RF 24-105mm F4L IS USM Canon RF 15-35mm F2.8L IS USM +15 more
David Hull
David Hull Veteran Member • Posts: 6,831
As someone already pointed out, the camera is still using power even when the switch is turned off. Check to make sure you don't have things like WiFi and BT activated in the menus. The camera never completely turns off unless you remove the battery altogether.
 David Hull's gear list:David Hull's gear list
Canon EOS R Canon EF 100mm F2.8L Macro IS USM Canon RF 35mm F1.8 IS STM Macro Canon RF 24-105mm F4L IS USM Canon RF 15-35mm F2.8L IS USM +1 more
Rey G Regular Member • Posts: 139
Hopefully the rumor is true and they eliminate the 30 minute time limit for video. They should have done it with the last firmware.
 Rey G's gear list:Rey G's gear list
Canon EOS 5D Mark II Canon EOS M Canon EOS M3 Canon EOS RP Canon EOS R5 +17 more
Already addressed .
Victor Engel
