Laowa 100mm 2.8 on Fuji x mount ?
Started 1 month ago | Questions
Rod McD Veteran Member • Posts: 8,589
Re: Laowa 100mm 2.8 on Fuji x mount ?
eladrill2 wrote:
Thank you all for your suggestions. Now, a couple of additional questions.
In terms only of sharpness,
(1) Is the canon ef 180 3.5 mounted on fuji the sharpest of the listed primes?
I can't offer any advice on that question.
(2) comparing categories, overall, are the fuji zoom lenses (xf 50-200 and 70-300) sharper than the above primes (mounted on a fuji camera via adapter)?
I owned the 55-200 for some years but sold it for the 70-300 to get the extra reach.  The 55-200 from about 55-150 is really very sharp - excellent.    The 70-300 is better than the 55-200 at the longer FLs and offers great close-focusing at all FLs.  It's also sealed, and TC compatible.
I would rate both zooms as little different in sharpness from primes in the central area.  In the outer image, good FF telephoto primes used on APSC tend to give very good IQ because they were designed to cover FF - so well beyond the APSC corners.  That's a general observation, but I can tell you that it applies to a comparison between my FF Canon FD 300mm f4 prime and the XF70-300.  It's only an incremental difference, but it's there.
Having acknowledged that, I don't think it would make much difference at all in applied photography - for two reasons. The first is that telephoto subjects tend to be in the central part of the image - people are less concerned with corners when using telephotos than when using WA lenses for subjects like landscapes.  The second is that the difference would be irrelevant in anything other than very large prints - larger than I actually make.   I compared them and kept the zoom despite the difference.
I would look to reasons other than sharpness when considering modern zooms.  Whatever slight differences might be detectable under very controlled conditions, you have to hand it to the native zooms compared to adapted lenses for integration (depending on the prime lens in question and adapter).  That's for some or all of....
  • FL flexibility
  • OIS
  • AF
  • close-focusing
  • focus bracketing/stacking
  • LMO, and
  • EXIF
Personally I find FL flexibility and OIS to be the great benefits of using a telephoto zoom.  Primes may offer higher speed, but with telephotos you often can't change position or change it far enough to alter composition significantly.  So then a prime may not meet your needs.  And good zooms are so sharp that they easily out-resolve a crop from a shorter prime.
Primes win for aperture if you want subject/background separation.  They can also offer a smaller and lighter option than a 600g zoom.  That's if you keep to adapting a short FL - say a 100-135mm and you deliberately pick a small, light option from the many legacy lenses available.   If you start adapting longer lenses -  180mm, 200mm and 300mm lenses -  primes (+adapter) are no lighter than the 70-300 and may well be heavier.
Hope that helps.
Cheers, Rod
 Rod McD's gear list:Rod McD's gear list
Fujifilm X-T4 Voigtlander 90mm F3.5 APO-Lanthar SL II Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 18-55mm F2.8-4 R LM OIS +13 more
Artur Darulewski Senior Member • Posts: 1,209
a_c_skinner wrote:
The Canon 180 on APS-C will be a very specialised and rather unwieldy lens. The only reason to buy it is if you want both a macro lens and long focal length.
I have considered EF180/3.5, but it was unavaiable - had no opportunity to try it. Have you used it? If so, what can you say about AF (is it really so slow)?
Long FL seems very tempting for skittish insects.
For flowers and landscape the 70-300 will probably be your best bet accepting it won't get into the really close range. Longer than 90mm is a focal length where OIS becomes a huge boon. As a flower snapper of 45 years a good zoom avoids a lot of crawling around in the dirt.
My experience with long zooms and insects or flowers is also very positive.
If you want close and money and weight not object then the 80mm plus the 1.4TC is very good. That is how I will avoid buying the Canon 180 and an adaptor.
In my country used EF 100/2.8L IS 1:1 macro is cheaper than used XF80. Can be also used with 1.4xTC and is known as very sharp lens, so it seems to be worth considering as well.
Artur
 Artur Darulewski's gear list:Artur Darulewski's gear list
Fujifilm X-T20 Fujifilm X-T3 Fujifilm X-H2S Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS +16 more
a_c_skinner Forum Pro • Posts: 13,047
No, sorry.  But long macro lenses are in short supply as are macro zooms.  I'm tempted by the 70-300 which gets to 0.33 at 300mm.
The main gain for me would be the narrow field of view which makes backgounds more uniform.
Zoom helps you crawk around in the dirt less for flowers.  So for me the 80 and 1.4TC will be as far as I go.
Andrew Skinner
Fujifilm X-T2 Fujifilm X-E3 Fujifilm X-H2 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R +7 more
AndyH44
AndyH44 Veteran Member • Posts: 3,107
FWIW .....
Haven't tried the Laowa, but I do have the Tokina atx-i 100 f2.8 macro for Nikon F that is simply superb adapted on my Fuji X-E4.  M/F of course but no problem with that.  These are really great lenses that deserve a close look for anyone looking for a reasonably low priced, high I.Q. macro lens.
"True craftsmen never blame their tools, but strive to use them properly"
Emile15 Senior Member • Posts: 1,769
If we are talking about the Canon EF version then yes it does have electronics (which is why I bought it for my R5, because the RF version does not).
 Emile15's gear list:Emile15's gear list
Fujifilm X100T Fujifilm X-T4 Canon EOS R5 Canon EOS R7 Fujifilm XF 55-200mm F3.5-4.8 R LM OIS +12 more
