XT-4: LCD black with flash mounted
Started 1 month ago | Discussions
Antone
Antone Senior Member • Posts: 1,287
OK, I'm sure there's a simple solution that I cannot locate in the manual, so hopefully someone can chime in. I need to take a passport photo using my shoe-mounted flash (bounced off white ceiling). I have the aperture set to f/5.6 and shutter speed manually set to 1/125. The room is dim and this is causing the LCD on back of the X-T4 to be completely black (viewfinder, too). If I press the shutter button half way, the image appears for about half a second, then disappears and the focus lock warning appears that the camera is unable to focus. So, I cannot compose, nor can the camera focus.
If I set the shutter dial to 'A' the image appears on the LCD but the shutter speed is set to 1.6 seconds.
I don't want to turn up the room lights because that will cause hot spots on the photos.
What am I missing here?
Tony-S
 Antone's gear list:Antone's gear list
Sigma DP1 Merrill Sigma DP3 Merrill Sigma SD15 Sony a7 Sigma sd Quattro +15 more
Rightsaidfred
Rightsaidfred Senior Member • Posts: 2,179
Exposure preview must be off
That's a frequently asked question here.
The latest reply to it was just 3 days ago.
See here, https://www.dpreview.com/forums/post/66907865
Martin
 Rightsaidfred's gear list:Rightsaidfred's gear list
Fujifilm X-T20 Fujifilm X-T4 Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS +5 more
