XT-4 autofocus advice please
Started 1 month ago | Discussions
Shadwellal Regular Member • Posts: 152
Please could someone have a look at he attached photos. The crop is from a successful shot of a bee-eater (just to show that I got there in the end), but the other shot which wsa taken a few seconds earlier, is typical of a problem I occasionally encounter when trying to focus on a small subject - the focus point is showing as being on the bird if I use a plug-in to show the focus point in Lightroom, but actually the camera just wouldn't find the subject and focus on it. I appreciate that this is a difficult scenario, with a green bird against a green background, but I'd really like some advice regarding the best settings to deal with this. I was using AF-S, and tried both zone and spot focus modes.
I'd also be interested to know whether the XT-5 would be better in his situation (without using subject recognition). I'm not thinking of changing my XT-4, but might buy a second body for a safari holiday later in the year.
Erik Baumgartner Senior Member • Posts: 6,893
Re: XT-4 autofocus advice please
I use an X-T2, but I’d do the same with any camera (and with almost any subject) - AF-S single point, box on the subject, full-press the shutter button. If the subject is just too tiny, I would just flip to M mode and focus manually with max magnification.
Sony RX100 Fujifilm X100V Fujifilm X-T2 Fujifilm X-T20 Fujifilm XF 35mm F1.4 R +5 more
Alan Hewitt Photo
Alan Hewitt Photo Contributing Member • Posts: 909
I'd always be in AF-C for wildlife. I work on the assumption that if it can move, it does move and with a telephoto, depth of field can be very fine. Also, this would facilitate using the AF-C custom settings to adjust sensitivity.
If this is not for you, then a work around would be to grab focus off the perch then refocus on the bird. It's probably more likely to find the subject.
Freelance wildlife photographer, filmmaker, photography safari & workshop guide, writer. Fujifilm UK Ex-X-Photographer!
www.alanhewittphotography.co.uk
INSTA1: alanhewittphoto
INSTA2: bts_alanhewittphoto
 Alan Hewitt Photo's gear list:Alan Hewitt Photo's gear list
Fujifilm X-T2 Fujifilm X-H1 Fujifilm X-H2S Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 50-140mm F2.8 +2 more
OP Shadwellal Regular Member • Posts: 152
Thanks both of you. Clearly no magic solution that I'm missing then - I suppose it makes the successful shots that bit more rewarding!
FujiJon
FujiJon Contributing Member • Posts: 580
I have the same problem with my X‐H1 sometimes.  It seems as if the camera decides that you don't really want to focus on a relatively low contrast blob (green bird) and goes for the background instead.  Prefocus on something in the same area and hope it then gets tempted by the sublect you want.  Alan suggested the branch for example.
Don't complain about growing old, it's a privilege denied to many.
 FujiJon's gear list:FujiJon's gear list
Fujifilm X-H1 Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 10-24mm F4 R OIS Fujifilm 16-55mm F2.8R LM WR Fujifilm 16-50mm F3.5-5.6 II +1 more
Morris0
Morris0 Forum Pro • Posts: 32,175
My X-T3 setup BIF is reported to work well with the X-T4. It includes custom AF-C settings as Alan suggested.
https://www.fredmiranda.com/forum/topic/1594539/0
Morris
Fujifilm X-T3 Fujifilm X-H2S Canon EF 200mm f/2.8L II USM Nikon AF-S Teleconverter TC-17E II XF 90mm +11 more
Morris
Thanks Morris,
I'll try that.
Rightsaidfred
Rightsaidfred Senior Member • Posts: 2,179
AF-S & focus box
To be honest, the photo of the green bird does not look too good. It is much softer than I would actually expect. I see that the image resolution is strongly reduced. Is it a heavy crop, or did you reduce IQ in any way before posting, or what happened?
The AF system will always go for contrast. If there is not much contrast in the subject, and if there is at the same time some contrasty background w/in the focus box, there is a high risk that the system will focus on the background. Choose your focus box size carefully.
My general advice is similar to Erik's. If the subject is not moving fast, use AF-S. Use an appropriate box size, not smaller than necessary. Press the shutter button fully through. Make sure to have focus priority, not release priority. Turn AF + MF off. This is my way. I have virtually no OOF shots with my X-T4 (and X-T20).
Martin
 Rightsaidfred's gear list:Rightsaidfred's gear list
Fujifilm X-T20 Fujifilm X-T4 Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS +5 more
biza43 Forum Pro • Posts: 15,074
Green on green is challenging. You can always try MF with image zoom on the EVF to double check.
www.paulobizarro.com
http://blog.paulobizarro.com/
 biza43's gear list:biza43's gear list
Fujifilm X-T3 Fujifilm X-T4 Fujifilm XF 16mm F1.4 R WR Fujifilm XF 70-300 F4-5.6 R LM OIS WR Fujifilm XF 33mm F1.4 R LM WR +1 more
DarnGoodPhotos Forum Pro • Posts: 11,881
The bird looks like the background so it’s not surprising it missed it. I would have focused on the branch at its feet, shot, and then refocused on the bird since it would have been close to in focus. Also, angling the camera like 15-30 deg still helps acquire focus when it wont otherwise.
www.darngoodphotos.com
 DarnGoodPhotos's gear list:DarnGoodPhotos's gear list
Fujifilm X100V Fujifilm X-T5 Fujifilm XF 18mm F2 R Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 27mm F2.8 +3 more
Rightsaidfred
MF in this case
Ah I understand now the second photo is a heavy crop of a second attempt of the same scene.
Of course I had similar subjects already.
For me: clearly a case for MF.
Martin
Alan Hewitt Photo
Which lens were you using? Something with more reach will give you greater detail on the subject to find contrast to focus on.
Thanks everyone for your help and advice. The second (in focus) photo is a heavy crop.
I was using a 70 - 300 lens from a boat and yes, a lens with longer reach, or possibly a teleconverter would have helped.
