My first attempts at a bird picture
Started 1 month ago | Discussions
Alan Sh Senior Member • Posts: 2,774
Took my 70-300 lens - set it on 1/1000 & auto A - later on 1/2000 and F8 and let the camera choose the ISO (which may have been a mistake). I ended up taking 167 pictures and I think I've got around 30 or so I like. Is that normal?
What do you think of these ? They are crops from the original.
Alan
 Alan Sh's gear list:Alan Sh's gear list
Canon EF-M 55-200mm f/4.5-6.3 IS STM Panasonic Lumix DMC-ZS40 (TZ60) Canon EOS M100 Canon EOS M50 Fujifilm X-T5 +13 more
Tim van der Leeuw Senior Member • Posts: 1,364
Re: My first attempts at a bird picture
I get a lot of "outtakes" as well when shooting birds.... So I think your ratio is certainly not abnormal.
But I'm just a beginner at this as well so hey what do I know! 😅
Perhaps f/5.6 would be better than f/8 for getting more light, but of course focus is also more critical then.
A shutter speed of 1/1000 or 1/2000 can really freeze the motion but did you also try 1/500 for a bit more light and lower ISO? To see what the effect of that is on the image and motion?
Anyway, just my 2 cents!
 Tim van der Leeuw's gear list:Tim van der Leeuw's gear list
Canon EOS M5 Fujifilm X-H1 Fujifilm X-T3 Fujifilm X-H2S Sigma 2x EX DG Tele Converter +17 more
OP Alan Sh Senior Member • Posts: 2,774
Thanks for the feedback.
I did try 1/500 the other day, but the birds moved too fast and were not in focus properly.
Alan
baobob
baobob Forum Pro • Posts: 18,248
For the first trial, excelent ! May be a bit of PP to get more light.
In my (now rather long experience) 1/1000 sec is a good choice. leave the 70-300mm at 6.3 at 300mm to get more light.
get the remmendations of Morris for BIF posted a few months ago. Bird recognition is ok if light and contrast are good. Using simple AFC, big single point or zone 3*3 is better when light conditions are not good.
With training and experience with the T5 you can expect 50% tack sharp keepers (same than my XH2).
Try to find what is the best method for you (eye recognition or simple AFC), the best settings in terms of ergonomics and results.
Bird recognition makes life easier and more comfortable, but is in no way compulsory when conditions for its use are not good.
Bon courage !
Bob
Sony RX100 Panasonic ZS200 Fujifilm X-H2S Fujifilm X-H2 Fujifilm XF 35mm F1.4 R +16 more
baobob
Bon courage !
Bob
Thanks Bob. Yours are good - and gives me something to aim for.
I did have it set to a 3 x 3 grid with bird recognition, not eye focus. It seemed to work about 80% of the time (there were some OOF birds, not sure why), so I will probably carry on doing that.
I had it on AF-C with focus priority and used the CL setting using Electronic Shutter.
A lot of what I discarded were just duplicates of the best in the group. And I haven't finished going through to find 'interesting' shots - although I do like the one of the bird with the mouldy bread.
Alan
baobob
Interesting comments ! So the machine works fine, you just have to observe birds to get their habits, the way they take off and land, etc ...
For the first trial your results are excellent. I always shoot quite a lot and the final arte keeper is at best 1/10 usually quite lower, especiallyfor seagulls and their erratic fly.
best
Bob
Thanks Bob.
Here's one more I like - once again, a crop with a bit of adjustment to the light.
Alan
Alan Hewitt Photo
Alan Hewitt Photo Contributing Member • Posts: 909
If you get 30/167 that you like and keep, then that is a very good keeper rate.
Freelance wildlife photographer, filmmaker, photography safari & workshop guide, writer. Fujifilm UK Ex-X-Photographer!
www.alanhewittphotography.co.uk
INSTA1: alanhewittphoto
INSTA2: bts_alanhewittphoto
 Alan Hewitt Photo's gear list:Alan Hewitt Photo's gear list
Fujifilm X-T2 Fujifilm X-H1 Fujifilm X-H2S Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 50-140mm F2.8 +2 more
I think I've ended up with 5 that I would print off and another 20 or so that would be good in a slide slide show.
That X-T5 is amazing. I would not have thought it would be that good.
Alan
Morris0
Morris0 Forum Pro • Posts: 32,175
30 out of 167 is a great start Alan.  I usually shoot aperture priority setting the ISO to a value that will result in shutter speeds that are sufficient.  There are a lot of approaches to exposure for flight images.  You need to find one you like.
Morris
Fujifilm X-T3 Fujifilm X-H2S Canon EF 200mm f/2.8L II USM Nikon AF-S Teleconverter TC-17E II XF 90mm +11 more
Morris0
Alan
It's more about what you do correctly than the camera though a good camera dose help
Morris
Morris0
These is my birds in flight setup for the X-H2s and other Fuji cameras that have subject recognition:
https://www.fredmiranda.com/forum/topic/1772910/0
Have fun,
Morris
Thank you. I used slightly different settings, but I will try some of your ideas next time.
I had release priority set to Focus. It seemed to work OK most of the time.
I had IS mode set to continuous. The battery lasts for ages and I didn't want to miss anything.
My biggest mistake was having Image display set to 1.5 seconds. Every time I took my finger off the shutter, I got the last image - and lost the bird.
Not sure what my tracking sensitivity is set to. I've got to find that in the menu
Alan
Erik Baumgartner Senior Member • Posts: 6,893
I think most folks turn the image review off completely. It wastes battery power and just gets in the way, IMO. I have my front custom button assigned for playback if I ever need to take a quick peek at previous shots while looking through the EVF.
Alan
Sony RX100 Fujifilm X100V Fujifilm X-T2 Fujifilm X-T20 Fujifilm XF 35mm F1.4 R +5 more
DM-CO Forum Member • Posts: 81
Sharp and good, congrats
These images are nice and sharp.  Congrats on that.  I personally find birds in flight very hard to get really sharp.  Well done.
The  lighting is flat though so the birds don’t pop.  That’s a negative to these images.  BUT, you just have to take what God gives you that day.  You did, and you made the most of it.
well done!
