Don't sleep on the Viltrox 75mm 1.2!
Started 1 month ago | Discussions
RobertMachin Contributing Member • Posts: 531
14
Had the lens for some time now.  Well known that the IQ is stellar but I often seen mentioned that the AF is lacking.
This doesn't match my experience. Long focus throw were slow indeed but the lens did very good at tracking and felt quite swift if the focus was already close... almost better than native lenses it seems...
Few days ago a firmware got released and it clearly improved the speed. Coincidentally,  I then took the lens to my ultimate test which is indoor sport. Mounted on the X-H2S.  (AF-C, Tracking mode, 30-40 fps)
I would usually get the XF 90 2.0 or the XF 50-140 2.8. They did okay-ish, but the results would be erratic. I could almost never get an entire sequence in focus... Lacked consistency, which disappointed me quite a bit.
The Viltrox on the other hand transformed my H2-S. I got a significant higher amount of keepers. Missed shots were due, most often, to "wrong" acquisition of the tracking target. Barring that, I could finally get sequences of action in focus from start to finish.  A much more predictable tool overall.
So happy that Viltrox made this lens (and the 13 1.4 before that).  They really are improving and putting quality out there.
It sounds unexpected, but give it a try, you might get surprised
 RobertMachin's gear list:RobertMachin's gear list
Sony RX100 III Canon EOS RP Fujifilm X-H2S Canon EF 50mm f/1.2L USM Canon EF 135mm F2L USM +17 more
Erik Baumgartner Senior Member • Posts: 6,893
Re: Don't sleep on the Viltrox 75mm 1.2!
Sounds great, but i really wished it focused closer.
Sony RX100 Fujifilm X100V Fujifilm X-T2 Fujifilm X-T20 Fujifilm XF 35mm F1.4 R +5 more
fernandojval
fernandojval Regular Member • Posts: 428
Re: ¡No duermas en el Viltrox 75mm 1.2!
Where can I see your indoor sports photographs? Thanks
I read and write in english using a web translator.
 fernandojval's gear list:fernandojval's gear list
Fujifilm X-T4 Fujifilm XF 50-140mm F2.8 Fujifilm XF 70-300 F4-5.6 R LM OIS WR Tamron 17–70mm F2.8 Di III-A VC RXD +3 more
Fuji Maine Senior Member • Posts: 1,702
I hadn't heard about the firmware update yet so thanks for the heads up. When I did a quick Google search for it I found a fuji rumors article about the FW update which FR says is a beta firmware and the comments section is filled with people saying it bricked their lens and had to restore the original FW. You didn't have any of those issues?
BeatX
BeatX Regular Member • Posts: 374
I would like to see them also Hard to belive, that stepping motor in Viltrox 75/1.2 outperforms quad LM from 90/2 in action shots
 BeatX's gear list:BeatX's gear list
Fujifilm X-S10 Fujifilm XF 33mm F1.4 R LM WR Fujifilm XF 23mm F1.4 R LM WR
OP RobertMachin Contributing Member • Posts: 531
Yes I've seen that. Took a risk but I made sure to have the original firmware at hand in case something went wrong.
Have nothing bad to report so far.
I don't post them publicly unfortunately as it's mostly children (following my daughter's tournaments)
If I get a chance to photograph an adult session, I'll be sure to post
fernandojval
What aperture are you shooting at?
The lens is great at 1.2, so 1.2
Gives 800 ISO  and 1/800 as shutter speed.
Samuraidog Senior Member • Posts: 1,672
This is exactly the reason why I'm waiting for the non-beta version to be released.
The lens focuses fairly well for me so far on my X-H2S. There were times where, immediately after I took the shot, I'd question whether the image would be slightly out of focus, but ends up being perfectly in focus.
 Samuraidog's gear list:Samuraidog's gear list
Fujifilm X-T30 Fujifilm X-H2S Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 27mm F2.8 +13 more
fernandojval
From where can I download this beta firmware?
5
https://www.viltrox.com/newsinfo/5554154.html
For good measure, here is the original firmware if need to backtrack:
https://www.viltrox.com/newsinfo/5556206.html
Nemofoto New Member • Posts: 24
Hi all,
Could you please tell me how this kind of focal length works on a body which is not stabilized? I am really interested in this lens but i have an x-t2 and i am afraid that it might be hard to use such a long focal lenght without stab. What do you think about that?
Thanks for your help.
BeatX
5
Nemofoto wrote:
Hi all,
If You will follow the rule of shutter speed = 1/focal length (multiplied by x1.5), there is nothing to worry about. Image Stabilisation is an quite modern invention. People did use telephoto lenses without stabilisation, back in the times with no problems
Thanks for your reply. I would be less worried with a Dslr, but i don't know what it would do with an electronic viewfinder. The image tends to move more with telephoto lenses.
MichaelFrederickPhoto
MichaelFrederickPhoto Contributing Member • Posts: 638
I have mine on order,  I got the 13mm on Friday as well.  Didn’t really have time to test it but looking fwd to shortly.
https://www.instagram.com/michaelfrederickphotography/
https://www.flickr.com/photos/159695193@N02/albums
Canon R6, Canon 16-35 F4, Sigma 40mm 1.4, Sigma 105 1.4,, and Tamron G2 70-200 2.8. Fuji X100v, Fuji X-H1 - Viltrox 33mm 1.4
nuramori
nuramori Regular Member • Posts: 118
It seems most if not all of the "bricking" was due to pushing the update with a mac platform, instead of a PC.  The suggested fix that seems to work, is to update the lens with an intel machine after going back to FW 1.0.0.
 nuramori's gear list:nuramori's gear list
Canon EOS 5D Mark III Fujifilm X-T5 Canon TS-E 17mm f/4L Fujifilm XF 35mm F2 R WR Fujifilm XF 27mm F2.8 R WR +4 more
Thanks for that info. So, use a Windows machine and it should work fine. Maybe I'll give it a try.
fernandojval
The Viltrox 75mm f1.2 focuses faster and better than the Fuji 50-140mm f2.8?
Batdude
Batdude Veteran Member • Posts: 6,544
Really?
I remember reading posts/reviews like this one about the Viltrox 56 1.4 when that Lena came out.  I finally purchased it after many many months and I was disappointed of the AF performance.  Inconsistent and inaccurate when I was shooting outdoors under (plenty) of daylight.  In low light it was unacceptable.  And yes I did load the latest firmware.
Like some poster said in a recent thread, it will be best to stop listening to reviews and for me is better to try that lens first this time and I don’t want to be stuck with another Viltrox lens that I don’t want nor like 😬
 Batdude's gear list:Batdude's gear list
Fujifilm X10 Nikon D4 Fujifilm X-E1 Fujifilm X-T1 Fujifilm GFX 50S +12 more
