Wide angle lens virtual image = macro mode
Started 3 weeks ago | Discussions
cdubsunderwater New Member • Posts: 1
Hi!
I recently bought a BigEye Lens M67 Mark II for my underwater Canon scuba diving case. This is my first time using a wide-angle lens.
From my understanding, domed wide-angle lens create a "virtual image" that the camera needs to focus on - hence why the camera needs to be in "macro mode" when using the domed wide-angle lens.
1. Because the camera is focused on the overall "virtual image" vs. the actual scene, does that mean the camera will not focus on a particular subject within the scene - therefore meaning it won't have bokeh between the background and foreground in-focus?
2. Would it be possible for the Canon G7xii to take macro video while keeping the wide-angle lens on?
Thanks in advance to the community for your collective wisdom!
PHXAZCRAIG
PHXAZCRAIG Forum Pro • Posts: 19,651
Re: Wide angle lens virtual image = macro mode
cdubsunderwater wrote:
Hi!
OK, what you have there is a 'wet lens', designed to work with water on both sides of the optics.  It adapts your standard lens into wide angle.
It's probably more accurate to say that a virtual image is formed on the inside of the dome, and in order for that image to be in focus, the camera needs to be able to focus that closely.
If this lens is sold as a recommended option for your camera, it's probably safe to assume it works with it.  Don't expect great corners in your shots.
No, you can pick out near and distant objects and the camera will be out of focus for one but not the other.   But you still need close-focus capability.
Not really.  The nice thing about wet lenses is that they can be changed underwater.   It's common to have a flip mount to flip in the wet lens when needed. And you can get dual flip mounts that can flip in a macro wet lens or a wide lens as needed, or none at all.
I admit to rarely trying the wide lens I had for my RX100 II, and I couldn't get the focus right on my macro wet lens.  (Needed to be too close to the subject.)
Phoenix Arizona Craig
www.cjcphoto.net
"I miss the days when I was nostalgic."
Nikon D80 Nikon D200 Nikon D300 Nikon D700 Nikon 1 V1 +45 more
Interceptor121 Veteran Member • Posts: 8,691
The macro mode is only required for compact cameras to change the focus range
A dome increases the depth of field so it is very difficult to blur a background with it in fact most underwater wide angle is sharp throughout
instagram http://instagram.com/interceptor121
My flickr sets http://www.flickr.com/photos/interceptor121/
Youtube channel http://www.youtube.com/interceptor121
Underwater Photo and Video Blog http://interceptor121.com
Deer Photography workshops https://interceptor121.com/2021/09/26/2021-22-deer-photography-workshops-in-woburn/
If you want to get in touch don't send me a PM rather contact me directly at my website/social media
 Interceptor121's gear list:Interceptor121's gear list
Sony a1 Panasonic Lumix DC-GH5 II Panasonic Lumix DC-GH6 Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Canon EF 8-15mm f/4L Fisheye USM +24 more
