R7 from my car ?! What the heck ?!?!
Started 3 weeks ago | Discussions
Chris Wolfgram
Chris Wolfgram Veteran Member • Posts: 6,619
So I know I've discussed the subject of shooting from a car before, and I'm well aware of things like 1) heat from a warm car, mixing with cold air outside, 2) vibration of a running motor, 3) hand holding as I can't really use a tripod (I have a window attachment, but it's kind of a pain)
Anyway, here's my point > I've shot quite a bit from my car, as we have a couple of places where we go that have auto routes that you are not allowed to get out (one time, my GF and I got out to switch drivers, and immediately, every bird in a 1 mile radius took off ! Oops ๐Ÿ˜€)
Long story short, I've gotten quite a few pretty nice shots from my car "With my R5" and a few different lenses......
But my new and beloved R7 SUCKS shooting from the car ?
Why ??? The only difference I can think of, is that I shoot 100% mechanical with my R5, and 100% electronic shutter with the R7, but I don't see how this in itself should make such a huge difference ? Am I overlooking something here ?
Oh and btw, I've even been in good light and had my shutter speed as high as 1/2000th, for perched birds ! And they were still blurry !? I don't get it.
Your thoughts ?
Photos are my paintings. The camera is my brush.
Website
www.LightInEveryCorner.com
DPreview gallery; http://www.dpreview.com/galleries/5075216809
No time or attention given for negativity or trolls.
 Chris Wolfgram's gear list:Chris Wolfgram's gear list
Canon EOS R7 Canon EF 16-35mm F2.8L II USM Canon EF 24-70mm F2.8L II USM Canon RF 600mm F11 IS STM Canon RF 800mm F11 IS STM +1 more
Canon EOS R5 Canon EOS R7
JustUs7 Senior Member • Posts: 4,327
Re: R7 from my car ?! What the heck ?!?!
18
100% electronic shutter with a slow read speed for the R7 seems explanatory enough without any pictures attached showing what constitutes terrible.
What I donโ€™t get is why people post questions like this without at least testing like shooting conditions first to determine if that might be the issue. Switch to mechanical shutter on the R7 and see if itโ€™s better.  Or at least EFCS if trying to avoid shutter shock
 JustUs7's gear list:JustUs7's gear list
Canon EOS 1000D Canon EOS Rebel SL1 Canon EOS RP Canon EOS M6 II Canon EF 75-300mm f/4.0-5.6 III +10 more
MarshallG
MarshallG Veteran Member • Posts: 8,951
What I don’t get is why people post questions like this without at least testing like shooting conditions first to determine if that might be the issue. Switch to mechanical shutter on the R7 and see if it’s better. Or at least EFCS if trying to avoid shutter shock
I think the Electronic Shutter artifacts may be difficult to see on the rear screen, especially the ones that happen under artificial light.
 MarshallG's gear list:MarshallG's gear list
Canon EOS R5 Canon EF 50mm F1.4 USM Canon EF 85mm F1.8 USM Canon EF 16-35mm F2.8L II USM Canon Extender EF 1.4x II +4 more
Canon_Guy
Canon_Guy Senior Member • Posts: 1,486
7
You ask us if your R7 sucks shooting from the car? Or it is rather an information than a question? In that case why it sucks?
What difference? Why don't you demonstraze what you mean on couple of samples.
Yeah - explaining what is your point.
It can be point No. 1) from your list above, or just atmospheric density, or shooting through the car windows, or....
With such a lack of factual information nothing can be determined clearly.
Your thoughts ?
Website
 Canon_Guy's gear list:Canon_Guy's gear list
Canon EOS R6 Canon EF 70-200mm F2.8L IS II USM Sigma 14-24mm F2.8 DG HSM Art Sigma 105mm F1.4 DG HSM Art Canon RF 24-105mm F4L IS USM +6 more
Max5150 Senior Member • Posts: 1,045
How about a couple pictures, same lens, same settings, mechanical sutter then electric shutter?
Chris Wolfgram
OP Chris Wolfgram Veteran Member • Posts: 6,619
Impo, the R7 is practically useless in Mechanical Shutter mode. I’ve heard a few people say it imparts some amount of shutter shake at practically ALL shutter speeds, and in my brief trial of MS, that seems to be true. If I need to shoot something with MS, I’ll use my R5.
Website
Chris Wolfgram
How about, forget I asked ๐Ÿ™‚ Freaking DPR ๐Ÿ˜€ lol
Website
BirdShooter7 Veteran Member • Posts: 9,127
Iโ€™m not sure what is causing the issue youโ€™re experiencing but I definitely get great results shooting from my car with the R7 and various long telephoto lenses and I also mostly use ES.  I wish I could offer some helpful advice but I canโ€™t think of any at the moment other than keep trying and hopefully you can figure out what is causing the problem.
Some of my bird photos can be viewed here: https://www.flickr.com/photos/gregsbirds/
I feel like Iโ€™ve done quite well with EFCS on the R7.  I know some people have had issues with EFCS at slower shutter speeds and 15fps with certain lenses but I really havenโ€™t observed problems wen using my trusty old EF 500mm f/4L IS USM.
Alastair Norcross
Alastair Norcross Veteran Member • Posts: 9,874
Iโ€™ve shot thousands of shots in EFCS (why would you use full mechanical?) with my R7, and not a single one had any trace of shutter shock.
Website
“When I die, I want to go peacefully in my sleep like my grandfather. Not screaming in terror, like the passengers in his car.” Jack Handey
Alastair
http://anorcross.smugmug.com
Equipment in profile
 Alastair Norcross's gear list:Alastair Norcross's gear list
Canon G7 X II Canon EOS M6 II Canon EOS R7 Canon EOS R6 Mark II Canon RF 35mm F1.8 IS STM Macro +24 more
Chris Wolfgram
I feel like I’ve done quite well with EFCS on the R7. I know some people have had issues with EFCS at slower shutter speeds and 15fps with certain lenses but I really haven’t observed problems wen using my trusty old EF 500mm f/4L IS USM.
TBH, that's the one shutter mode I hadn't even tried. I've just had such great results with the ES "outside of my car" on a tripod...
Website
Chris Wolfgram
BirdShooter7 wrote:
I’m not sure what is causing the issue you’re experiencing but I definitely get great results shooting from my car with the R7 and various long telephoto lenses and I also mostly use ES. I wish I could offer some helpful advice but I can’t think of any at the moment other than keep trying and hopefully you can figure out what is causing the problem.
TY Birdshooter. Ya know, the more I think about, maybe even with my R5, my results from inside of the car, were not as good as they have been shooting outside of the car, certainly when using a tripod. Last year, I used to blame that all on focus pulsing with my Sigma 150-600. Now that I'm using my 800 F11 almost exclusively, my sharp perfectly focused shots are way up.... But I haven't done auto routes with it, like I did last Winter. Instead, the little bit of shooting I've done from the car, has not produced many sharp shots with the 800 F11 either. Hmmm.
I'll keep trying with birds that are not super important to me if I miss them. But for important birds, I'm getting out and using the tripod.
Website
Canon_Guy
That is as nonsenscical as it can be.Physically impossible.
Many people have no clue how camera works which creates opportunities for such revealing statements.
Website
expro Senior Member • Posts: 2,273
Well there is only one common denominator…..
๐Ÿ˜‚๐Ÿ˜‚
 expro's gear list:expro's gear list
Canon EOS R3 Canon RF 24-70mm F2.8L IS USM Canon RF 70-200mm F2.8L IS USM Canon RF 100-500mm F4.5-7.1L IS USM Canon RF 14-35mm F4L IS USM
Ephemeris
Ephemeris Senior Member • Posts: 1,186
I’ve shot thousands of shots in EFCS (why would you use full mechanical?) with my R7, and not a single one had any trace of shutter shock.-
For this scenario (I'm not clear exactly what it is but can guess) what advantages exist for Mechanical and what negatives are there for ECFS.
As it happens I often shoot Mechanical on the R5 but that may purely be to have feedback the shot was taken at the moment of button press (noise).
Website
Alastair
Bernie_King Senior Member • Posts: 2,131
I'm not much of an APS-C fan, but do remember that you are effectively increasing your magnification by a factor of 1.6.  That means any movement is going to be magnified.  Add to that the high pixel density of your camera and it gets even worse.  IBIS and IS can only do so much.  I'd imagine you're seeing what amounts to micro-motion blur in your photos.  My first suggestion is to be sure to shut off the engine while you shoot.  It may not seem like it, but the entire car is gently vibrating from the engine.  Make sure anyone in the car sits still, including you.  One a lower density sensor it may work fine, but you're getting blur between pixels.  The second is to up your shutter speed.  1/2000 is likely not enough without a solid base (tripod).  You also might want to use that window attachment if you can't get your shutter speed over 1/3200s (that's my sweet spot on the R5) .  I have also noticed that the higher density sensors sometimes fight a bit with the IS in older adapted lenses.  I used to have to turn it off with my R5 and 600 vII.  I shoot almost exclusively in electronic shutter and with the exception of a lower bit-depth on my R5 (and no exceptions on my R3) using mechanical shutter isn't going to make a difference here.
Steve Balcombe Forum Pro • Posts: 15,571
Sure, if that's your experience I wouldn't argue with you. But to solve the problem you need to be comparing like with like. Regardless of what you will revert to once the test is done, you need to use similar settings on both cameras, and equivalent focal lengths (or crop and normalise), and see what difference there is.
Alastair Norcross
The only negative I’ve ever heard about for EFCS is the possibility of cut-off bokeh with very wide apertures (F1.8 or faster) at very fast shutter speeds. I presume that the OP was shooting birds from a car with a lens slower than F1.8, so this wouldn’t apply here.
EFCS gives the same feedback. It’s e-shutter that doesn’t make a noise (unless you set the camera to give you a noise, which you can do with the latest Canons).
Website
Alastair
Alastair
Alastair Norcross
Give it a try.
Website
Alastair
MarshallG
Chris, are you shooting with image stabilization on while bracing the lens or camera against the car with the engine running?  With an 800mm lens, any high frequency vibration will show up in the photo. Sometimes itโ€™s better to turn IS off, believe it or not.
I think you have a solvable problem.
