That is how fuji treats customers!!!
Started 1 month ago | Discussions
Raphaello88 Regular Member • Posts: 104
So recently i reported problems with my lens 18-55. straight after uodating to newest firmware lens started buzzing, never have had problems before. i emailed fuji support letting them know about issue(not only me but lots of users) and fuji response was disgusting. They offered paid technician assistance as theybrhink my lens developed fault!!
it’s obviously their foult but trying to blame who nows what!!
Cadder Senior Member • Posts: 1,847
Re: That is how fuji treats customers!!!
I have found Fuji support in Canada to be excellent.
Cadder
P.S. What exactly was their "disgusting response"?
 Cadder's gear list:Cadder's gear list
Fujifilm XF 18-55mm F2.8-4 R LM OIS
Raymond L
Raymond L Contributing Member • Posts: 674
is it still under warranty ? If not, I am not surprised. The   firmware update didn’t “break” my 18-55.
Unfortunately an issue only affecting a handful of people might not trigger the response you are after from Fujifilm.
Here in Australia, fujifilm can inspect the equipment without a fee, however like most places the servicing fee isn’t “cheap”.
 Raymond L's gear list:Raymond L's gear list
Sony RX100 IV Sony RX1R II Leica M9 Nikon D800 Fujifilm X-E1 +29 more
SenicPhoto
SenicPhoto Regular Member • Posts: 293
Fujifilm Canada support blows! I had front focusing 56mm f/1.2. They quoted me $820 for a fix and 2-3 months of wait. Great support...whatever.
Branislav Senic
Toronto, ON Canada
http://www.senicphoto.com
 SenicPhoto's gear list:SenicPhoto's gear list
Fujifilm X70 Canon EOS 5D Nikon D700 Fujifilm X-T1 Fujifilm X-T2 +5 more
Canadianguy Senior Member • Posts: 2,910
Re: No more Canadian support - outsourced to US
There is no more Fujifilm Canada support for digital cameras - it used to be great, now - everything is sent to Fujifilm US, hence the high prices and long wait times.
I had a GFX 23-64mm lens repaired for the Turn off and on camera error. It came back working but a little loose on the zoom ring - I didn't think anything of it until a few months later when the lens broke into 2 pieces when I turned the zoom ring. Had to pay them again for another repair.
Morris0
Morris0 Forum Pro • Posts: 32,175
As you think many are experiencing this.  Wait a few days and call again.  I've found Fuji support to be rather inconsistent.
Morris
Fujifilm X-T3 Fujifilm X-H2S Canon EF 200mm f/2.8L II USM Nikon AF-S Teleconverter TC-17E II XF 90mm +11 more
texasfz8
texasfz8 Regular Member • Posts: 270
Raphaello,
I have updated my 18-55 to the latest firmware which is version 3.24.  I have none of the problems you listed.  I am using an X-E3 however, so this may be different from you.  So not all lenses/camera combinations appear to be affected.  Does the version 3.24 show when you turn the camera on while holding the back button?  Sounds like a bad firmware flash.
 texasfz8's gear list:texasfz8's gear list
Fujifilm X-S1 Fujifilm X30 Fujifilm X-E3 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm 50-230mm II +2 more
Morris0
texasfz8 wrote:
Raphaello,
If it is a bad flash, I think he can flash again and correct.
Morris
noorhe Forum Member • Posts: 56
Fuji Canada support used to be good, until Fujifilm decided to shut it down and get all the support handled by the US. Hence the long wait and higher cost, which is unfortunate for us consumers.
Perhaps Fuji should compensate this for it's consumers  by pricing their camera and lens lower, or offer longer warranty.
Xh2S is $3200+ 13% tax= ~3600$. Heaven forbid if something should go wrong, then it's a long repair wait time, and only 1 year warranty.
 noorhe's gear list:noorhe's gear list
Fujifilm X-T1
John Gellings
John Gellings Veteran Member • Posts: 9,741
Outrageous!  Why not grow a backbone and go up their food chain in support?  Ask for a manager and demand they fix it.  I know Karen’s etc.  This is when you need to rightfully complain.  It’ll work.
https://www.johngellings.com
Instagram = @johngellings0
 John Gellings's gear list:John Gellings's gear list
Ricoh GR IIIx Fujifilm X-E1 Leica M Typ 240 Fujifilm GFX 50R Fujifilm X-Pro3 +6 more
Pesca Regular Member • Posts: 148
I'm curious if your lens is still under warranty? If not I don't know what Fuji's policy is re firmware update issues for gear that's out of warranty. .. ie. if it's an update at your own risk situation, etc.
I've only dealt with them once here in Australia and I was pretty impressed. I had an X-T20 that I sent to them due to sand getting caught in the internals of the shutter button and on/off switch. It was still under warranty, but I assumed I would still have to pay a service fee since the X-T20 isn't a weather sealed camera and mine had been used quite a bit in rough weather conditions. They serviced it, cleaned it all up, tested it and sent it back to me free of charge, no questions asked. I was pleasantly surprised.
 Pesca's gear list:Pesca's gear list
Fujifilm X-T4 Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 10-24mm F4 R OIS +2 more
McWoodley
McWoodley Contributing Member • Posts: 647
It would be better to call and speak with someone rather than emailing. I’ve generally found calling their technicians positive.  Also this seems like a singular incident and not a class action lawsuit.   Upgrading firmware on anything presents some level of risk. There are ways to minimize it.
 McWoodley's gear list:McWoodley's gear list
Fujifilm X-E1 Fujifilm X-T30 Fujifilm X-T4 Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R +10 more
X-RayJunk New Member • Posts: 6
It’s not just Fuji although they left a lot of owners of their prepress scanners high and dry. I bought a Fuji Lanovia Quattro prepress scanner direct from Fuji. They were in the neighborhood of $50K. Everything went great until Fuji discontinued their pro scanners and then all support stopped including repair parts. No updates on software ( proprietary software ), no tech support, no field support and no parts. I had to buy a junker to keep mine running plus maintain an old Mac to run it on.
Same situation with a rebuilt Hasselblad / Imacon 848 scanner I bought from Hasselblad. It developed a problem under warranty and I had to ship it at my expense to Hasselblad, $500. They never found the problem until it was out of warranty and then the repair was north of $2000. Hasselblad no longer services their scanners and they have to go to Denmark for service now.
Leica did it to me after 45 years of using and buying their cameras. I bought my M9 new and a set of new lenses, $25K roughly. The camera went back to Leica 5 times in 2-1/2 years at an average of 7 weeks each time. I used or at least tried to use the M9 in my work but it was too unreliable.
Leica provided loaners to select customers, wealthy dentists, but even explaining I use my equipment to make a living and I’d bought probably a dozen new Leica bodies and couple dozen lenses for my studio over nearly 5 decades but was never able to get a loaner. The last trip up to Leica I had to threaten a lawsuit and finally got a replacement on a 90 Apo Summicron and the camera fixed. I took it immediately and sold all of the digital gear. Never again!!!
I had 2 Rollei 3003 bodies, 7 backs and full set of Zeiss glass from 15 to 400mm. Great concept but poorly built. I had one body and a couple of backs in for repairs all the time, literally. Rollei was excellent! I had the direct number of the repair tech and had an indefinite loaner on another body and backs. I had the loaner for several years. Rollei knew how to take care of pro customers.
I’ve been a Nikon user for almost 60 years. Leica and Nikon were the backbone of my business when I got started in the mid 60’s. Nikon has top notch service for pros, NPS. Nikon provides labels for shipping, file a repair on line and one day turnaround on repairs unless there’s a parts issue and a 10% discount on repairs. They ship FedEx 1 day too.
In addition they have an entire loaner bank of essentially everything they make at no charge. There’s a limit to how many loans on the same item but they’re trying to sell gear. Also they take vans full of bodies and lenses to pro events for loan to NPS members at events like the Kentucky Derby, Olympics and other major photo events. They also have repair techs and do onsite repairs. Canon has similar. Both know how to treat the people that keep them in business.
I bought a new Porsche a few years ago and had great luck with it. Loved it! I was going to buy another a couple years ago until I found out about their intermediate shaft and main bearing failures in an undisclosed number of cars. The short story, it took a class action law suit to get it resolved. Usually the failure occurred between 8-45K miles and the engine was totally trashed when it failed. Porsche was trying to stick customers with a $40K engine replacement even though the failure was a design issue.
The moral to this story, pretty much all companies with a rare exception or two are more than happy to screw the customer every opportunity. And no, I didn’t buy another Porsche. I don’t want to do business with a company that tried to do customers that way and no I’ll never buy another new Leica or lens.
OP Raphaello88 Regular Member • Posts: 104
texasfz8 wrote:
Raphaello,
yes it does. lens was flashed correctly
it might sound silly but “cheap” companies sometimes treat customers better and even afterwarranty service goes without any hassle
Nielk Mike Senior Member • Posts: 1,480
Don't if it would work: But have you tried to downgrade the firmware to the previous  version?
fernandojval
fernandojval Regular Member • Posts: 428
Re: ¡Así es como Fuji trata a los clientes!
In Spain the relationship with Fujifilm is fast and efficient.
Recently my 50-140mm started making a loud and constant noise when I put it on the X-T4, it was a noise it had never made before. I wrote to Fujifilm Spain and they responded quickly, recommending that I update the firmwares (the camera and lens firmwares). The firmwares were updated, but I reinstalled them and the noise disappeared.
I read and write in english using a web translator.
 fernandojval's gear list:fernandojval's gear list
Fujifilm X-T4 Fujifilm XF 50-140mm F2.8 Fujifilm XF 70-300 F4-5.6 R LM OIS WR Tamron 17–70mm F2.8 Di III-A VC RXD +3 more
ViMa
ViMa Senior Member • Posts: 2,150
I struggled to follow this out of the amount of envy I felt reading about your gear!
Vittorio
_________________________________________________
https://www.flickr.com/photos/155724624@N06/
 ViMa's gear list:ViMa's gear list
Ricoh GR III Ricoh GR IIIx
My business was dependent on good reliable equipment. Clients get really unhappy if you’re fiddling with equipment rather than shooting their assignment. I invested in premium equipment expecting reliability and performance and as a rule over the nearly 55 years owning my business had very good luck. The Porsche was a reward for hard work and keeping a business alive during hard times.
ViMa
My post was tongue in cheek.
Vittorio
