My KF Concept PK-FX adapter wobbles
Started 1 month ago | Discussions
John Atkinson Junior New Member • Posts: 17
Hi!
So, when on, this adapter (Pro Series) wobbles right/left about 1mm...
Is yours behaving the same?
Just trying to figure out if I should contact them for a replacement.
wantfastcars Regular Member • Posts: 206
Re: My KF Concept PK-FX adapter wobbles
I have the Pro II (recently purchased). Using it with my X-S10 and my handful of vintage K-mount glass I've had no wobbles.
 wantfastcars's gear list:wantfastcars's gear list
Fujifilm X-S10 Fujifilm 50-230mm II Fujifilm 15-45mm F3.5-5.6 OIS PZ Fujifilm XF 16-80mm F4 Fujifilm XF 70-300 F4-5.6 R LM OIS WR +8 more
OP John Atkinson Junior New Member • Posts: 17
https://www.youtube.com/watch?v=ICeQ9rpgOVA
See that?
All of them are like that.....
Ughhh.... more paper weights from China.
Pay more for the Pro and get a crap product.... classic
photo_404 New Member • Posts: 9
I fixed once a adapter from a different brand by tightening the screws.
If you have a small screwdriver, that fits, try to tighten the screws on the mount.
Maybe it improves.
 photo_404's gear list:photo_404's gear list
Fujifilm X-T4 Nikon Z5 Fujifilm XF 56mm F1.2 R Fujifilm XF 50-140mm F2.8 Sigma 50-100mm F1.8 DC HSM Art +14 more
21William Contributing Member • Posts: 866
KF now seem to offer three different PK-FX adapters. Anyone know what the differences are? I have this type and it fits fine.
 21William's gear list:21William's gear list
Pentax K-5 Fujifilm X-H1 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 10-24mm F4 R OIS
yayatosorus Senior Member • Posts: 2,021
See that?
Got a cheap adapter I got for about 10 bucks. Rock solid on the PK mount, but a bit loose on the X-mount. Pretty much in line with the behavior exhibited in the video.
If you want something really solid, consider getting one from Novoflex: https://www.novoflex.de/en/products-637/lens-adapters//adapterfinder-products/camera/fuji-x-mount-mirrorless/objectiv/43.html
 yayatosorus's gear list:yayatosorus's gear list
Fujifilm X-H1 Fujifilm XF 35mm F2 R WR
Maybe it improves.
Which mount, the adapter?
The camera is very tight, evidently with Fuji lenses there is zero play no matter how much you try to wobble it...
Something is off with the KF - they are made by 5 year olds  or something
See that?
Also, are those 10$ adapters from ali express? Just so I know to avoid these as well :))
See that?
No idea, got it from a local shop when I first entered the system to play around with some Pentax lenses I had lying around. The adapter did its job well and the play wasn't really noticeable most of the time. If you want something top notch, there are options on the market, but be ready to pay a hefty amount.
If anybody bought a cheap adapter that has zero play on the camera side I'd love a link!
JNR
JNR Veteran Member • Posts: 4,652
The smoothest, most precision adapter I own is K&F PK/DA-FX - the more expensive one that allows you to do a mechanical stop down of the newer PK lenses (that don't have an aperture ring). The adapter is definitely more precise than the fitting on my Fringer (EF-FX) - admittedly the non-Pro version; it doesn't wobble, but there is very little friction.
I'm pretty sure that K&F put a little more precision into the design with the thought that the ones without the proper mechanism for all PK lenses were those planning one-off or casual-occasional use.
JNR
 JNR's gear list:JNR's gear list
Fujifilm X-T2 Fujifilm 50mm F2 R WR Phase One Capture One Pro Pentax K-01 Pentax K-3 +22 more
As I said, I’ve got this one and it’s fine.
https://www.amazon.co.uk/Adapter-Concept-Aperture-Fujifilm-Mirrorless/dp/B076V77Z6Y
I meant the adapter on the side that connects with the camera. There should be some screws. I would just try it. Of course the camera mount is fine.
I don't have your adapter, but just try to tighten every visible outside screw on the adapter.
This issue is often just some loose screws on the adapter. I wouldn't lose any time with refunds or returns. Just try to fix it yourself.
As I have seen your video, that wobble was similar to my adapter (Canon FD-FX). And my adapter was apparently  also from KF but named different. There are even some cheaper options as KF, with sub brands.
I use or had almost 4-6 adapters made from a KF sub brand and the quality is decent for the price. I can't complain at all.
Maybe I’ve been lucky but my K&F FD/FX adapter is also fine.
Adapter replaced by amazon, new one is the same ol' story
What I take from this thread is that the Pro series adapters are inferior in stability to the older ones.
I would just buy the older one, and stay away from the loose Pro series. I think they tried to make it looser to satisfy customers who see tightness an issue - but went too far in tolerances.
