R6 or R8
Started 4 weeks ago | Discussions
McT65 Junior Member • Posts: 25
R6 or R8
In the UK the new Canon R8 will be £1700 body only, however, the original R6 can now be purchased for £1899.
Is the R6 a better buy for someone using it 75% photo/25% video?
I'm struggling to decide between these cameras or an R7, but I don't need beyond 200mm so probably better to go with the full frame cameras. For only £200 more the R6 seems like a bargain compared to the R8 spec for the price but I'm not so sure.
Canon EOS R6 Canon EOS R7 Ricoh Caplio R8
MarshallG
MarshallG Veteran Member • Posts: 8,951
Re: R6 or R8
I’d generally say that the R6 is a better camera. The R8 has higher resolution and a better autofocus system. However, R8 lacks IBIS, which is very useful for video. R8 also has lower viewfinder resolution, and lower frame rate for shooting bursts.
With that said, understand that there are a lot of photographers who highly value fast autofocus and high frame rates, which is very important in shooting sports and fast moving wildlife… but not so much for other forms of photography.  The R8 is smaller and uses a smaller battery which won’t last as long. If small size is important, that’s a consideration. Most serious photographers prefer a larger body, because we rely upon using the controls as we shoot.
My sincere answer is try to swing the R6 II, but we all have our budgets.  The R6 owners here have been very happy with their cameras, so you can be confident that you won’t have regrets.  I have the very similar, higher resolution R5 and I’m very satisfied.
 MarshallG's gear list:MarshallG's gear list
Canon EOS R5 Canon EF 50mm F1.4 USM Canon EF 85mm F1.8 USM Canon EF 16-35mm F2.8L II USM Canon Extender EF 1.4x II +4 more
koenkooi Contributing Member • Posts: 920
Re: R6 or R8
The R8 will likely be backordered the first few months, so it might be well into August before you are able to get one.
 koenkooi's gear list:koenkooi's gear list
Canon EOS 7D Canon EOS M Canon EOS M6 II Canon EOS R5 Canon EF 85mm F1.8 USM +20 more
OP McT65 Junior Member • Posts: 25
Re: R6 or R8
I know that is likely, but I’m not in a hurry so can wait. I just need to make the right decision as the camera will last me a minimum 4 or 5 years.
Re: R6 or R8
MarshallG wrote:
HI’d generally say that the R6 is a better camera. The R8 has higher resolution and a better autofocus system. However, R8 lacks IBIS, which is very useful for video. R8 also has lower viewfinder resolution, and lower frame rate for shooting bursts.
I would rather put the money into lenses so the cost of the R6II is out of reach for me.
I don’t photograph wildlife/birds or sport so don’t need fast autofocus, frame rates, or a lot of reach. I just need a camera for travel, portraits and family stuff.
I prefer larger bodies as I’m used to DSLR size, but the R6 is similar in size to the APSC Canon Dxx  series which I have mainly used in the past. The R8 is quite a bit smaller so I’d probably need the extension plate for the bottom.
The deal breaker may be the single card slot. I once had an SD card failure following a trip to another country and lost everything that was on the card. Now I always use lots of smaller capacity cards so I don’t have all my photos on the one card; that way I would only lose some of them.
Canon_Guy
Canon_Guy Senior Member • Posts: 1,486
Re: R6 or R8
The R6 is simply more advanced camera than the R8. More versatile especially for your use, where two card slots and almost twice as long lasting battery together with the IBIS will be you daily helpers.
 Canon_Guy's gear list:Canon_Guy's gear list
Canon EOS R6 Canon EF 70-200mm F2.8L IS II USM Sigma 14-24mm F2.8 DG HSM Art Sigma 105mm F1.4 DG HSM Art Canon RF 24-105mm F4L IS USM +6 more
MarshallG
Re: R6 or R8
Then I’d say the R6 will make you happier. Owners here love them.
Steve_tEkGuY Contributing Member • Posts: 599
Re: R6 or R8
I used the RP (same form factor as R8 ) and the 6D Mk2 for about a year. For travel to Iceland and Eastern Europe the RP was my main camera and the 6D stayed locked away. Every night I backed up the SD card into one of those large 4TB portable backup systems. I never needed more than 2 batteries daily for photography. I also had the extended grip for my pinkie finger. Sure for video only static shots were taken. All the moving videos even with IS lens were jarring.
Overall it was a fine camera and very capable and now same form factor with better guts for $1500 . Served me well and after about a year and a half I moved to the R.
I didn't shoot sports or birds  just mostly family outings and travel.  It was coupled with the RF 24-105 L and the RF 35 F1.8 and at the time had some F1.4 Sigma EF lenses.
@tekguyphoto
 Steve_tEkGuY's gear list:Steve_tEkGuY's gear list
Canon EOS R5 Canon EOS R6 Mark II Sony FE 28-70mm F3.5-5.6 OSS Sony FE 28mm F2 Canon RF 35mm F1.8 IS STM Macro +8 more
