Moving from Canon M system
Started 4 weeks ago | Discussions
OP navinadvani Forum Member • Posts: 73
Re: Moving from Canon M system
MAC wrote:
yes, but RF 100-400 does BIF -- your M doesn't do well
What is BIF?
Of course, you cannot compare a FF equipped with fast, expensive, heavy glass with a much poorer APSC camera. The question is do I need this level of performance?
Based on what you have written until now, I very much doubt that you do.
The only time I have felt my system's limitations are in very low light; when I have to push the ISO over 3200. I assume the new Digic X sensor even in APS-C bodies would outperform older Digic 8 sensors of the older FF cameras.
I am just wondering. In what situations was your current system not good enough to take the photos you wanted?
My 11-22 isn't fast enough in low light. I only have the 22/2 and heavy EF 50/1.4 (which is heavy) to cover low light.
the issue is that the op has to chase new money into older technology that is being sunset
Agreed which is why I started this thread in the EOR R section.
The R8 will crush the ops technology, just as your R6II - otherwise, why did you get R6II
Agreed. The R8 will crush my system with the only challenge being above 100mm (FF equivalent). With an EF-M 55-200, I'd be able to go to 300mm (FF equivalent). I think 300mm should be all range I should need.
 navinadvani's gear list:navinadvani's gear list
Canon EOS 77D Canon EOS M50 Canon EF 28mm f/1.8 USM Canon EF 50mm F1.4 USM Canon EF 100mm f/2.0 USM +9 more
JustUs7 Senior Member • Posts: 4,327
navinadvani wrote:
MAC wrote:
And I would miss the EF-M 11-22mm UWA zoom. That is my most used lens when traveling.
one needs to separate traveling kit, from everything else, and yes, op could get both m and RF. Op could keep m50 and 11-22 and get m32 and sell everything else
I only use my camera when travelling or at family functions. For everything else I use an iPhone.
Yeah. I find it odd that people buy the tiny stuff for travel and keep the big stuff at home. The only time I really get to enjoy my hobby is when I’m traveling.
But I suppose if it’s your job, your perspective will be different.
 JustUs7's gear list:JustUs7's gear list
Canon EOS 1000D Canon EOS Rebel SL1 Canon EOS RP Canon EOS M6 II Canon EF 75-300mm f/4.0-5.6 III +10 more
MAC Forum Pro • Posts: 18,487
navinadvani wrote:
What is BIF?
bird in flight
the R8 would resolve that as well as give you a better look with shallow dof to remove the clutter in the backdrop
the RF 35 and RF 85 on R8 would be the answer
you started the thread in the m section and the moderator moved it to the R section
there are FF answers here including adapting EF/EF-s lenses like the 70-300 II
though it reduces the mpxl down to 10, I sometimes adapt my 55-250 stm on my RP
the RF 70-200 f4L is a dream lens, pop can size
the RF 100-400 gets you to 400
the RF 24-240 is a nice lens
and you can consider adapted third party long lenses
 MAC's gear list:MAC's gear list
Canon EOS 7D Mark II Canon EOS RP Canon EOS M6 II Canon EOS R8 Canon EF 70-200mm f/2.8L USM +7 more
it sounds like you have your mind made up to invest more into a dead system
I got my big stuff (40D, 60D, 77D, EF lenses etc) before mirrorless was the norm. I find if it's too heavy, I'd seldom carry it, so the object is to have something that I will tolerate carrying. Which in my case is 1.8kg.
I could not find a suitable bag, so I made a 4-pocket insert. I copied the 3 pocket inserts linked below but extended the length to a 4th pocket. Each pocket can accommodate either 2 compact lenses (2.5" x 2.5"), a single telephoto zoom (2.5" x 5"), a body with a small zoom attached + a pancake lens or a big prime with EF adapter.
https://apecase.com/product/cubeze-33/
http://www.koolertron.com/koolertron-new-shockproof-dslr-slr-camera-bag-partition-padded-insert-protection-case-for-sony-canon-nikon-dslr-shot-or-flash-light.html
The homemade insert fits nicely into the small sling linked below, which also has a small water bottle pocket, a pocket for a 9.7" iPad, and a pocket for a wallet and keys or two mobile phones.
https://www.flipkart.com/kooltopp-classy-cross-body-bag-13-l-backpack/p/itm7809b74cb0945?pid=BKPFHC3ZQ6FRVFEG&lid=LSTBKPFHC3ZQ6FRVFEGIY752X&marketplace=FLIPKART
Edit: found a link that has instructions to make your own custom camera inserts.
https://www.howjoyful.com/camera-carrier-insert-tutorial/
On the contrary, the reason I am vacillating is that the M system is dead (we won't see any more additions), and I was looking for a compact system that offers:
  1. fast primes (22/2, 50/1.4 EF-S)
  2. zoom from 18-300 (FF equivalent) 11-22, 15-45, 55-200
I do not need the extra resolution of a FF sensor but could use some low-light capability. The closest viable option is a kit based on an R10.
Canon EOS R10 + RF-S 18-45mm F4.5-6.3 IS STM kit
Canon RF 15-30mm F4.5-6.3 IS STM (replaces the 11-22)
Canon RF-S 55-210mm F5.0-7.1 IS STM (replaces the EF-S 55-250)
Canon RF 50mm f/1.8 STM (replaces the EF 50/1.4)
Canon RF 24mm IS STM F1.8 (replaces the 22/2)
optionally
I could add a Canon RF 16mm f/2.8 STM (165 gms) to total up to 1.8kg. This kit (with the 16mm) would cost me around $3000 minus whatever I can get for my old Canon equipment.
The RF 35mm f/1.8 replaces the EF-M 32/1.4 rather nicely too.
optionally
not on apsc the 32 is a great lens
I disagree with where you've been with gear and where you keep going here, including your bag
I had a sling bag on my back and couldn't access my gear quickly enough - a shoulder bag for quick access is what I use
It is nuts to buy a lot of gear for travel
keep your m50 + 11-22 + 22
the 15 -30 is not a lens I'd buy
nor is the 18-46
run with two cameras and three lenses in a shoulder bag and get this
Canon EOS R10 Mirrorless Camera with 18-150mm Lens 5331C016 B&H (bhphotovideo.com)
and add to your RF down the road
MyM6II Senior Member • Posts: 2,424
I give up on this. You seem to be going around in circles.
Good luck with your decision . And take care.
 MyM6II's gear list:MyM6II's gear list
Canon EOS M6 II Canon EOS M6 Canon EOS M200 Canon EOS M50 II +1 more
PerfectMark Regular Member • Posts: 281
optionally
I am in a similar situation as you, but personally don't think it is the time to replace the M6ii yet.  For me to upgrade, Canon ether need to release a smaller version of the R7 or Sony needs to come out with an APSC camera that uses the same sensor as the FX30.
So I suspect I will be keeping the M6ii until the next round of Canon APSC cameras get released in a few years time.
 PerfectMark's gear list:PerfectMark's gear list
Canon EOS 600D Canon EOS M6 II Canon EF 50mm F1.4 USM Canon EF-S 18-55mm f/3.5-5.6 Canon EF-M 22mm f/2 STM +5 more
JRET
JRET Contributing Member • Posts: 840
optionally
This thread has been an interesting read, albeit a bit convoluted at times.
Unless I've misunderstood your goal(s), you are searching for the perfect travel kit.  If so, perhaps the question should be what's most important - the gear or the memories?  To capture memories all one needs is a decent point 'n' shoot to avoid fumbling with bags, zippers, lens changes, etc. ... plus a single camera greatly simplifies travel photography, enabling one to actually enjoy the journey.  Just a thought.
GENESIS 1:3
 JRET's gear list:JRET's gear list
Canon EOS M6 II Canon EF 100mm F2.8L Macro IS USM Canon EF-M 11-22mm f/4-5.6 IS STM Canon EF-M 18-150mm F3.5-6.3 IS STM Canon EF-M 32mm F1.4 +7 more
