Moving from Canon M system
Started 4 weeks ago | Discussions
navinadvani Forum Member • Posts: 73
Now that Canon has decided not to support the M system, I am considering moving from it.
The options are to move to Canon's R system or another company (Fuji / Sony).
The overall weight of the system is an essential consideration. My current M system (total weight of <1.4kg) includes the following:
Canon M50 (24MP) - 390 gms
Canon EF-M 22mm f/2.0 - 105gm
Canon EF-M 11-22mm f/4-5.6 IS STM - 220gms (my primary lens)
Canon EF-M 32mm f/1.4 STM - 235gms
Canon EF-M 15-45mm f/3.5-6.3 IS STM - 130gms
Canon EF-M 55-200mm f/4.5-6.3 IS STM - 260gms
I want the new system not to exceed 1.5kg (with 3 zoom lenses and 2 primes) and hopefully weigh less than my current system. Additionally, I prefer a body with an EVF (which almost eliminates the Sony ZVE10). Fuji does not have a lightweight lens like the Canon EF-M 11-22mm f/4-5.6 IS STM, Canon EF-S 10-18mm f/4.5-5.6 IS STM or even the Sony E 10-20mm F4 PZ G.
I also use a 50/1.4, which works as a portrait lens, but I don't carry this everywhere as it is very bulky and heavy with the EF to EFM adapter. I'd have to add a Fujifilm XF 50mm F2 R WR or a Sony FE 55mm F1.8 ZA to compensate for this lens.
Option 1: 1.5 kg
Canon EOS R50 - 375 gms
Canon RF 16mm F2.8 STM - 165 gms
Canon EF-S 10-18mm f/4.5-5.6 IS STM - 240 gms
Canon RF 35mm F1.8 IS STM Macro - 305 gms
Canon RF-S 18-45mm F4.5-6.3 IS STM - 130 gms
Canon RF-S 55-210mm F5.0-7.1 IS STM - 270 gms
Option 2: 1.4 kg but no EVF
Sony ZV-E10 - 343 gms
Sony E 15mm F1.4 G - 219 gms
Sony E 10-18mm F4 OSS - 225 gms
Sony E 35mm F1.8 OSS - 155 gms
Sony E 16-50mm F3.5-5.6 PZ OSS - 116 gms
Sony E 55-210mm F4.5-6.3 OSS - 345 gms
I could save 140 gms by replacing the 15/1.4 with the Sony E 16mm F2.8 Pancake (78 gms).
Option 3: 1.6kg, so over my 1.5kg threshold
Fujifilm X-T200 - 370 gms
Fujifilm XF 18mm F2 R - 116 gms
Fujifilm XF 10-24mm F4 R OIS - 385 gms
Fujifilm XF 35mm F1.4 R - 187 gms
Fujifilm XC 15-45mm F3.5-5.6 OIS PZ - 136 gms
Fujifilm XC 50-230mm F4.5-6.7 OIS - 375 gms
I could save about 100 gms by replacing the 35/1.4 with the XF 27mm f/2.8 Pancake.
Should I stick with Canon? If so, should I get the R50 or the R10 (which is a little bigger/heavier)? Or should I continue with my M system till it dies?
If I shift, I'd have the following (in addition to my above system) to offer as a trade-in. These items have not been used since 2019 but have been serviced by Canon annually (every May).
Canon 77D body
Canon EF 28mm f/1.8
Canon EF 70-300mm f/4-5.6 IS
Canon EF 24-105mm f/4 IS
Canon EF 100mm f/2
Canon EF-S 60mm f/2.8 Macro
Canon EF-S 18-55 4-5.6 IS STM
Canon EF-S 10-22mm f/3.5-4.5
Canon EF-S 17-55mm f/2.8 IS
If you think I should continue with the M system, what should I trade in the above 77D-based system for?
Thanks.
 navinadvani's gear list:navinadvani's gear list
Canon EOS 77D Canon EOS M50 Canon EF 28mm f/1.8 USM Canon EF 50mm F1.4 USM Canon EF 100mm f/2.0 USM +9 more
Canon EOS 77D / EOS 9000D Canon EOS M50 (EOS Kiss M) Canon EOS R10 Canon EOS R50 Fujifilm X-T200 Sony ZV-E10
Photobygms
Photobygms Regular Member • Posts: 293
Re: Moving from Canon M system
navinadvani wrote:
Option 1: 1.5 kg
You'll need an RF to EF adapter for that  EF-s 10-18mm lens this will ad another 110grms for the basic EF-RF adapter
.....Of course I'm out of my mind. It's dark and scary in there.....
Mostly analog at: https://www.flickr.com/photos/photobygms
Digital and some analog at: https://www.instagram.com/photobygms/
 Photobygms's gear list:Photobygms's gear list
Canon PowerShot SX740 HS Canon EOS 5D Mark IV Canon 6D Mark II Canon EOS R Canon EOS RP +46 more
MAC Forum Pro • Posts: 18,487
navinadvani wrote:
Canon EOS R8 Specifications (the-digital-picture.com)
Instead, are you open to selling about everything and spending $1499 and changing to an R8 FF body weighing CIPA Weight16.3 oz (461g) ???
Option 1: 1.5 kg
Canon 77D body
Canon EF 28mm f/1.8
Canon EF 100mm f/2
Thanks.
 MAC's gear list:MAC's gear list
Canon EOS 7D Mark II Canon EOS RP Canon EOS M6 II Canon EOS R8 Canon EF 70-200mm f/2.8L USM +7 more
RLight Senior Member • Posts: 4,418
Option 1: 1.5 kg
Canon 77D body
Canon EF 28mm f/1.8
Canon EF 100mm f/2
Thanks.
Wait a bit, that RF-S 11-22 is rumored to arrive by Q2 this year. The M is a fine system even now.
If you must? Option 1 is the most logical. Sony’s APS-C system has maturity issue. Fujis is big and heavy, expensive; going R8 is more logical.
I’m making the jump now because the 28-300 range is my used lengths. Ultra wide is something that’s a problem as you’d have to adapt.
 RLight's gear list:RLight's gear list
Canon EOS R3 Canon EOS R50 Canon RF 28-70mm F2L USM Canon RF-S 18-45mm Canon RF-S 55-210mm F5.0-7.1 IS STM
Laqup Regular Member • Posts: 351
If you get the R8 + 24-240 (414g + 750g), you can pretty much replace:
with a single lens. Of course with the execption of the tele range beyond 240mm.
In pure terms of "optical output" the zoom will be somewhat similar to the 22 f/2.0 that is actually an 35 f/3.2 in FF terms (only image look, for exposure f/2.0 is f/2.0, to be clear!)
Wide angle can be covered with the Canon RF 15-30mm (390g) or RF 16mm f/2.8 (165g), and the EF-M 32mm is logically replaced by the RF 50mm 1.8 (160g).
R8 + RF 24-240 + RF 16 + RF 50 will net you a total of 1489g.
Of course all of this is a trade-off. The R8 will be much more capable and the better body compared to the R50, but you have to lug around more weight "in hand" in combination with those FF lenses and you gain some volume. On the other side, the zoom gives you additional creative possibilities (as f/4.0 - f/6.3 cleary outperforms f/3.5 -f/6.3 on APS-C in the overlapping range) with the 50mm not being an exception (50mm 1.8 will yield shallower depth of field than 32mm 1.4). Build quality and some of the optical attributes of the 32mm 1.4 might be better though. Overall image quality will probably be slightly better, as the 15-45 and 55-200 are nothing to write home about (allthough performance of the 55-200 is solid for it's size and volume).
From my point of view I would not "rebuy" all of those to a certain degree similar RF-S lenses (yes I know that there are slight differences to EF-M) but I would rather try to seek an actual solid upgrade. If it has to be APS-C due to weight limitations I would not hesitate to buy a fuji body. The APS-C RF bodies are either sold as "complementary" to their bigger brothers (e.g. R7 for wildlife) or meant as some kind of "affordable bait" to lure you into the RF fullframe system (R50, R10) and to have an upgrade path. I see no clear intention from Canon to actually put out a full fledged RF-S system, this will probably be similar to the EF-M system, aka 1-2 new lenses per year and a few body upgrades in between.
 Laqup's gear list:Laqup's gear list
Canon EOS M6 Canon EOS M100 Nikon Z7 Nikon Z6 Canon EOS R +38 more
koenkooi Contributing Member • Posts: 920
I'm planning to replace my M6II with an R8, I will use it mostly as a 2nd body for my R5. I wanted something relatively small and I loathe the M50 form factor and pitiful excuse for an EVF, but loved the RP when I owned it.
My plan is to mostly use the RF16 and RF50 to keep the size down. If Canon had published a roadmap listing RF equivalents for the EF-M22, EF-M 11-22 and not-going-to-happen-but-I-can-hope EF-M32, I'd have looked real hard at the R10.
Your picks for the R50 lenses are well reasoned, but I wonder how you are going to like using the 10-18+adapter when coming from the tiny 11-22mm. I don't have a better recommendation, though.
 koenkooi's gear list:koenkooi's gear list
Canon EOS 7D Canon EOS M Canon EOS M6 II Canon EOS R5 Canon EF 85mm F1.8 USM +20 more
I think the RF-S 10/11-something is gonna happen.
Everything else? Hard to say
Alastair Norcross
Alastair Norcross Veteran Member • Posts: 9,874
10
I would stick with your current system for now, and see what Canon releases in RF-S. I think it’s quite likely that they’ll release the 22 pancake and the 11-22 (or close equivalents). Both the RF 16 and 50 are small and light too, and work very well on crop RF (I use them on my R7). Your current M kit still works well, though doesn’t it? I use my M6II and EF-M lenses alongside my R gear. I don’t care that Canon isn’t making more M stuff. That doesn’t stop what I have working.
“When I die, I want to go peacefully in my sleep like my grandfather. Not screaming in terror, like the passengers in his car.” Jack Handey
Alastair
http://anorcross.smugmug.com
Equipment in profile
 Alastair Norcross's gear list:Alastair Norcross's gear list
Canon G7 X II Canon EOS M6 II Canon EOS R7 Canon EOS R6 Mark II Canon RF 35mm F1.8 IS STM Macro +24 more
I advise against the 24-240, I owned it, it was not a “fun” lens. Too bulky. Consider the RF24-105, either or the 24-50. It’s more M-like. Trust me as a former M owner, fun factor is a thing. The 24-240 struggled indoors with AF, couldn’t do macro distances, swung around a ton, and had clinical rendering. It’s certainly sharp, reach, but fun? Nope. Consider the RF-S 18-150 instead.
This is a valid point. But this is highly subjective too.
As a current M owner and former user I still have a lot of fun with e.g. the R5 and 28-70, although I could probably carry several M bodies for the same net weight and volume. In contrast I actually would rate the EF-M 18-150 not that spectactular either.
But for sure, if size and weight "in hand" is the top criterion then don't go this route.
Llop Forum Member • Posts: 50
Fully agree, unless there is something that does not really work for you with your current setup (which does not seem the case), keep it and wait till (or if) there is a real alternative in the RFs ecosystem, and in the meantime think of what you really want to get from the change from the M system setup you have to whichever option you choose.
LXI_Martin Regular Member • Posts: 125
Am I missing something here?  When did Canon make this decision, and when does it take effect?
They may no longer be developing it, but that is not the same thing.
Canon EF 28mm f/1.8
Canon EF 100mm f/2
Thanks.
If you don't use it, cash.
Alastair Norcross
Yes, I second the RF-S 18-150 for all-in-one zoom. It's sharp, light, affordable, fast focusing.
Alastair
JustUs7 Senior Member • Posts: 4,327
7
What do you mean, “They’ve decided not to support…”?   They won’t repair them?  They won’t honor warranties?  You can’t buy accessories?
Our M6II and all the lenses work just fine.  And should the body fail and repairs prove too costly, well hope that some new inventory is still floating around, or perhaps a refurb at least.  But it should be years before any of that proves a real issue.  By then, we’ll make a decision based on what’s available.  People are still happily shooting with M’s and M3’s years after they were originally released.
 JustUs7's gear list:JustUs7's gear list
Canon EOS 1000D Canon EOS Rebel SL1 Canon EOS RP Canon EOS M6 II Canon EF 75-300mm f/4.0-5.6 III +10 more
the R8 (-6.5 EV) has a whopping 2.5 EV stop focus acquisition advantage over the R50 (-4 EV).
that is 6.25 times more light (2.5x2.5) to focus that the R50 needs in low light
get the R8 kit ($1699) plus the pop can size RF 70-200 F4L ($1399)
$3000 - 2 lens, slam dunk!
Swerky Contributing Member • Posts: 793
Option 1: 1.5 kg
Canon 77D body
Canon EF 28mm f/1.8
Canon EF 100mm f/2
Thanks.
If you have everything you need with your current gear, I don’t see why you should get rid of it. Canon has already issued firmware updates for the body and Canon just works anyway. And they bring new features to a brand new body, not like Fujifilm that bring new features to older bodies.
So there’s no rush for you to change gear now. If I were you I’d wait a bit until more lenses are released for RF-S, maybe an RF-S 11-22 will show up, and thus have the R50 as a logical successor to your setup, with desired lenses. You wouldn’t prefer to have the RF-S 18-150 to replace the two 18-45 and 55-210 zooms?
Nothing to read here.
 Swerky's gear list:Swerky's gear list
Canon G1 X III Canon EOS 6D Fujifilm X-A10 Voigtlander 20mm F3.5 Color Skopar SL II Voigtlander 90mm F3.5 APO-Lanthar SL II +1 more
tkbslc Forum Pro • Posts: 17,522
m43?
6
Have you considered m4/3?  It's very close to Canon 1.6x in image quality and often you can get faster lenses in the same weight class overcoming any sensor size disadvantage.
The nice thing is that they have a more full range of lightweight crop-specific lenses, so you would have a lot more options to go higher end and still maintain your weight requirements.    Maybe you picked 22mm and 32mm because they were the only prime options, not because that's what you actually want, as they are very close together.   m4/3 has like a dozen compact primes to choose from.    They have pro-grade lenses that are not much heavier than the variable kit zooms you have been using.  Stuff like that.  Worth a look at least, and there are really no holes in the lens lineup.
KEG
KEG Veteran Member • Posts: 4,909
There is an active market for apple ][ from 1979 and people pay good money for 00s powershots.
Support will continue for 7 years at least from this point in time.
Option 1: 1.5 kg
Canon 77D body
Canon EF 28mm f/1.8
Canon EF 100mm f/2
Thanks.
KEG
 KEG's gear list:KEG's gear list
Canon EOS M6 Canon EOS R Canon EOS M6 II Canon EF-M 32mm F1.4 Canon RF 50mm F1.8 STM +21 more
5
Would be hard to hit all OPs boxes with the weight requirements.
R8 or Rp is about 460g
16mm f2.8 165g
24-105 STM 395g
100-400 635g
50mm f1.8  160g
Already up to 1800g and we didn't even get a 35mm to replace their 22mm f2.   I guess you could go with the 24-50mm to shave 200g, but that's a really boring lens the OP prob doesn't want.
FF is heavier.  Even light FF is heavier since we are comparing to some of the lighter APS-C out there.   And this is pretty slow aperture FF, so not much advantage in terms of noise vs current kit.   It's not really going to be an upgrade unless they want to shoot wildlife with the 100-400.
16mm f2.8 165g
24-105 STM 395g
100-400 635g
50mm f1.8 160g
for me, the great framework to build upon and great upgrade for only 1850 g
R8                            460 g
RF 24-105 F4L IS    695 g
RF 70-200 F4L IS    695 g
Two Pop Can Lenses + body with great IQ
focusing -3.4 EV @F4 in moonlight with dxo PL NR = 1850 g
