X-T5 at 12,800 ISO
Started 1 month ago | Discussions
Franco64 Junior Member • Posts: 41
X-T5 at 12,800 ISO
16
I have often read that the X-T5 must be used at a maximum of ISO 3,200. In this photo - and in others - I did not pay attention to this precept and, accomplice, I shot out in difficult light and in uncomfortable positions (I was lying on the ground, on the floor of the house, with little light), I went far beyond. This, for example, was done at ISO 12,800.
I know, the noise is clearly visible, but in my opinion in the context of the image it is not at all annoying, indeed it gives the photo a "printing on rough paper" effect that I find pleasant. What do you think?
 Franco64's gear list:Franco64's gear list
Fujifilm X-T5 Fujifilm XF 16-80mm F4
GMacF Contributing Member • Posts: 999
Re: X-T5 at 12,800 ISO
Agreed. I find the noise argument a little tiring these days. On a global level noise just shouldn’t be an issue any more - unless perhaps for fine art photography or some such. I often shoot my sports stuff at 6400 and the images are excellent.
I find noise only becomes an issue when you have to crop into a high ISO image so it’s something to bear in mind, but at full resolution it just isn’t an issue in the modern day.
And to echo what you eluded to, as noise goes, I quite like Fuji’s rendering - it gives that sort of vintage grain look.
 GMacF's gear list:GMacF's gear list
Fujifilm X-E3 Fujifilm X-H2S Fujifilm X-T5 Fujifilm XF 27mm F2.8 Fujifilm XF 10-24mm F4 R OIS +9 more
baobob
baobob Forum Pro • Posts: 18,248
and if reducing the noise is important expose to the right ETTR with +2/3 to 1 EV then in PP adjust highlights.
Sony RX100 Panasonic ZS200 Fujifilm X-H2S Fujifilm X-H2 Fujifilm XF 35mm F1.4 R +16 more
a_c_skinner Forum Pro • Posts: 13,047
This means little of course but having spent a bit of time on old slides the noise on that looks comparable with Kodachrome 200 a full six stops.
Andrew Skinner
Fujifilm X-T2 Fujifilm X-E3 Fujifilm X-H2 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R +7 more
lexvo Regular Member • Posts: 465
I sometimes think people have different tolerances/preferences regarding noise. Like you, I don't mind some noise in high ISO shots. Often it gives character to the image.
And like another poster said: compared to slides I used to shoot decades ago, todays camera's have very little noise. I recently looked at some Kodachrome slides and was surprised how noisy they were, which I didn't find a problem back then.
 lexvo's gear list:lexvo's gear list
Canon EOS-1D Fujifilm X-T2 Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 14mm F2.8 R Fujifilm XF 18-55mm F2.8-4 R LM OIS +3 more
Erik Baumgartner Senior Member • Posts: 6,893
9
Actually, as Fuji sensors are quite ISO invariant in that range, so long as you are maximizing the sensor exposure, it doesn’t much matter where you set the ISO beyond 1600 or so. You can shoot at -3EV (ISO 1600 instead of 12800) and just push the brightness where it needs to go in post - no significant noise penalty, and you get significantly more highlight headroom to work with. ETTR is really only relevant at base ISO.
Sony RX100 Fujifilm X100V Fujifilm X-T2 Fujifilm X-T20 Fujifilm XF 35mm F1.4 R +5 more
DarnGoodPhotos Forum Pro • Posts: 11,881
I’ve never had a problem shooting any of my Fujis at their Raw-support max ISO, but what I usually try to do is manually shoot lower and push in post.
www.darngoodphotos.com
 DarnGoodPhotos's gear list:DarnGoodPhotos's gear list
Fujifilm X100V Fujifilm X-T5 Fujifilm XF 18mm F2 R Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 27mm F2.8 +3 more
sluggy_warrior Veteran Member • Posts: 3,204
nind-denoise
I used to like having grains in my high ISO shots, too, as the grains provide a focus point for the eyes and increase perceived sharpness, and coming from film myself ...
... until I'm spoiled by nind-denoise, and feel like being a fox that can now reach the grapes. It's still an early prototype, but it's a modern approach that utilizes neural-network/AI at the RAW level. Unlike other AI denoisers that have to deal with variations of different NR algorithms already applied to the image, nind-denoise has the advantage of dealing with noises in their original form (non-denoised RAW) for maximized data and consistency.
https://github.com/trougnouf/nind-denoise
I don't have a live subject so these two will have to do If you share the RAF of your shot, I can feed it through nind-denoise for comparison.
SOOC JPG
non-NR image exported from darktable just before feeding to nind-denoise, which has been trained to recognize these raw noise patterns and replace them with the clean-equivalence.
RAF processed in darktable, passed through nind-denoise, then RL-deblur
Maoby
Maoby Veteran Member • Posts: 5,479
Your cat doesn't seem to agree with you, I hear his menacing sound
 Maoby's gear list:Maoby's gear list
Olympus E-10 Fujifilm FinePix X100 Canon EOS-1D Canon EOS-1D Mark II N Canon EOS-1Ds +81 more
John Gellings
John Gellings Veteran Member • Posts: 9,742
Exactly.  However, I guess it depends on what type of photography you do.  I honestly do not care about noise until it gets really ugly and discolored.  Some people cannot handle just a little.
https://www.johngellings.com
Instagram = @johngellings0
 John Gellings's gear list:John Gellings's gear list
Ricoh GR IIIx Fujifilm X-E1 Leica M Typ 240 Fujifilm GFX 50R Fujifilm X-Pro3 +6 more
jim mij Senior Member • Posts: 1,062
If it was so dark you had to use high iso then it’s  moot point, but if you can take pics at iso 100, 3200, 12800 and then ask which one is preferred it’ll unlikely be the latter
Jim
 jim mij's gear list:jim mij's gear list
Canon EOS M6 II Canon EF 100-400mm f/4.5-5.6L IS USM Canon EF-S 60mm f/2.8 Macro USM Kenko Teleplus Pro 300 AF 1.4x Canon EF-M 22mm f/2 STM
JNR
JNR Veteran Member • Posts: 4,652
Agreed about everything here other than the last sentence. This week I got an opportunity to shoot at a club where the lighting has been pretty much the same as it had been for the past decade (very dark) and so got to do some good comparisons going back not only to the X-T2/20 shots, but earlier Pentax shots (on the 24mp sensor).
To the extent that I had "maximized sensor exposure" correctly, the ultimate processing in the 2000 to 6400 range from the X-T5 showed less noise and equal or slightly better sharpness. Of course, that involved a bit less sharpening and more NR than with the older sensor. A few times the sensor got tricked and lowered the ISO too far (yes, I use auto ISO in these variable light situations) - and the lack of maximized exposure resulted in slightly greater noise issues than with the old sensor. So, proper exposure is more critical with the 40mp sensor - as there seems to be more of a distinct shadow cliff.
It is likely that Erik and I have somewhat different understandings of ETTR... but to me it really does mean "maximizing the sensor exposure" and that should include low-light situations when you aren't filling the well.
JNR
 JNR's gear list:JNR's gear list
Fujifilm X-T2 Fujifilm 50mm F2 R WR Phase One Capture One Pro Pentax K-01 Pentax K-3 +22 more
PeterLeyssens Senior Member • Posts: 1,691
People who complain about noise at Fuji 12800 ISO never worked with HP5 film. That one had grain like bullets, and then I liked to push it to 800ISO which made it worse. Still, I made the only photo I ever sold this way so if the subject is right, who cares?
 PeterLeyssens's gear list:PeterLeyssens's gear list
Fujifilm X-Pro2 Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Samyang 12mm F2.0 NCS CS Fujifilm XF 35mm F2 R WR
redisred Regular Member • Posts: 119
Agreed with everyone, 12,800 can be totally fine in many scenarios. I've also been floored by what can be done with 12,800 and DXO PL5/6. I don't make an effort to shoot that high, but I don't completely avoid it either. The ISO 3200 shot you never took because it was too dark will always be worse than the 12,800 shot you did take!
 redisred's gear list:redisred's gear list
Fujifilm X-Pro3 Fujifilm XF 35mm F2 R WR Fujifilm XF 23mm F2 R WR Sigma 56mm F1.4 DC DN | C (X-mount) Fujifilm XF 18mm F1.4 R LM WR +1 more
John Gellings
Or Ilford 3200! That said, film grain looks a little nicer than noise typically, but yes, we are spoiled these days thinking 3200-12800 should be noiseless.
"film grain looks a little nicer than noise"
I think that is just nostalgia!
Andrew Skinner
John Gellings
No it really isn’t… I actually prefer digital for color photography.
baobob
Well this is not my experience Indoors at ISO 1600, in some shots I get say too much noise Exposing in ETTR at +2/3 to 1 EV gives much better results i tyerms of noise because I get a stronger signal thus a better SNR.
JNR
Doesn't it really come down to the particular film, the type of developer used, the extent of push processing, not to mention the even-greater variables involved in working with digital processing?
You really have a great deal more latitude on the digital side because the type of grain can be selected (six very different formulations in Capture One alone), and highly variable inputs relating to intensity and granularity. Most importantly, with film you're relying on a chemical process that doesn't give you do-over ability (as far as I recall).
I'm not saying that digital grain is "better," but certainly we have greater control to get the best possible result to our particular liking. If more of us used the option more regularly (using quality inputs), we might collectively have a greater affection for it.
JNR
baobob
Agree
Maximising exposure sensor = what exactly ?? What I do with the XH2 in dim light is having EV +2/3 to 1. Is it ETTR or maximization of sensor exposure ??
OTH I am not sure as well that the 40 mpx sensor is as ISO invariant as the 26 mpx is ??
