R7 firmware update
Started 4 weeks ago | Discussions
Marceppy Forum Member • Posts: 58
R7 firmware update
5
After processing the download on a good SD card, installing firmware 1.2 was not moving/installing beyond the update screen which was frozen, or so I thought.  I did everything by the instructions, advice from successful postings, but couldn’t get beyond the install screen.  So I called CPS and we found that if I pressed the lower directional button to the right, the greyed out OK tab lit-up !  And that made it install correctly.
thought I’d share a potential solution
M
 Marceppy's gear list:Marceppy's gear list
Canon EOS-1D Mark IV Canon EOS R7 Canon EF 100mm F2.8L Macro IS USM Canon MP-E 65mm f/2.5 1-5x Macro Canon EF 24-70mm F2.8L II USM +1 more
Canon EOS R7
JasonS70 Contributing Member • Posts: 654
Re: R7 firmware update
Ah man, saw the heading and thought Oh wow firmware update, nice. But I suppose that firmware update will be in the form of a R7ii or something
Cheers
Jason
koenkooi Contributing Member • Posts: 920
JasonS70 wrote:
Ah man, saw the heading and thought Oh wow firmware update, nice. But I suppose that firmware update will be in the form of a R7ii or something.
You're in luck!
https://www.canonrumors.com/canon-releases-firmware-v1-3-0-for-the-eos-r7/
 koenkooi's gear list:koenkooi's gear list
Canon EOS 7D Canon EOS M Canon EOS M6 II Canon EOS R5 Canon EF 85mm F1.8 USM +20 more
apersson850 Senior Member • Posts: 2,076
Yes, the heading should have been Updating the R7's firmware.
Anders
 apersson850's gear list:apersson850's gear list
Canon EOS 40D Canon EOS 400D Canon EOS 7D Canon EOS-1D X Canon EOS-1D X Mark II +26 more
drsnoopy Senior Member • Posts: 1,216
The touchscreen doesn’t work during firmware updates.  You must use the D-pad and Set button.  This has always been the case.
 drsnoopy's gear list:drsnoopy's gear list
Canon EOS RP Canon EOS R5 Canon EOS R10 Canon EF 100mm F2.8L Macro IS USM Canon RF 35mm F1.8 IS STM Macro +10 more
Zeee Forum Pro • Posts: 25,627
M
I didn’t see this thread but but I had the same thing happen. I just got lucky and pressed that button.
Don't Look Up.
 Zeee's gear list:Zeee's gear list
Canon EOS R7 Canon EOS R6 Mark II Canon RF 24-105mm F4L IS USM Canon RF 100-500mm F4.5-7.1L IS USM +1 more
